Old 11th November 2019, 04:37   #28981  |  Link
Lathe
Lathe's Avatar
Originally Posted by MrVideo View Post
@Lathe: At this point in time, if you want to take UHD video and create a BD, you are going to have to create a MKV file by using AVISynth tools, x264 & MKVToolnix to recode to 1080p. Then take that MKV file and pass it on to BDRB to create a BD.
Ah, I didn't know that you had to use AVS to do that, thanks!
Lathe is offline   Reply With Quote
Old 11th November 2019, 04:41   #28982  |  Link
Lathe
Lathe's Avatar
At some point I'll add a "Resize 3840x2160 to 1920x1080" to the SETUP/VIDEO dialog. I just haven't gotten around to it.
Oh okay... So, as Mr. Video mentioned, it is simply an AVS resize issue then. That should be pretty easy for me to do using the CMD line then.
Old 11th November 2019, 04:47   #28983  |  Link
Lathe
Lathe's Avatar
So, please excuse me for asking again, but WHAT exactly does BDRB do with 4k files then?
Does it simply compress the file and make it smaller as it does with HD stuff?
Since, apparently there is no conversion between the 2 formats, WHAT does it do...???
Can I import 4k MKV files? If so, then what can I do with it? I would really appreciate an answer to that please.
Old 11th November 2019, 12:55   #28984  |  Link
gonca
It makes the 4K files smaller
UHD to UHD
gonca is offline   Reply With Quote
Old 11th November 2019, 12:56   #28985  |  Link
gonca
And don't forget the tonermapping
Old 11th November 2019, 13:23   #28986  |  Link
gonca
You can use Vapoursynth instead
Old 11th November 2019, 14:01   #28987  |  Link
jdobbs
1. It does the exact same thing it does with 1080p, 720p, or 480/576 files.
2. In most cases, yes. For example, you could create a BD-25 or BD-50 that holds the UHD content from a BD-66 or BD-100. Or it can make a movie-only UHD-BD from it, or it can create an MKV or MP4 from it.
3. Yes you can import 4k MKV files. You can do pretty much anything. You can create a UHD-BD from it. You can recompress it to a different size. You can create a new MKV or MP4. You can resize it while creating the new ALTERNATE format.
In other words, it has now extended its support for BDs so that it also processes UHD-BDs. The most substantial change is that it now supports for HEVC/UHD/4K encoding as well as AVC/SD/HD, as is now included in the updated BD specification.
Website: www.jdobbs.net
Old 11th November 2019, 20:56   #28988  |  Link
AmigaFuture
AmigaFuture's Avatar
... and, I am STILL not getting any notifications when someone posts here. What do I hafta do, sacrifice a goat in my backyard or something...?!
Leave Pagans alone, we/they haven't done the Mayan thing for many, many generations, that's a smear job by the other organized one. I hung a rabbit in front of my door for "Rabbit celebration", and it didn't help..never does. But it was funny to watch neighbors expressions...especially door thumpers.
You have to reply a times then doom9.net seems to "remember" for a little while. Laughing!
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!!
AmigaFuture is offline   Reply With Quote
Old 12th November 2019, 19:50   #28989  |  Link
gamete
The download of bdrebuilder from first page dont work
gamete is offline   Reply With Quote
Old 12th November 2019, 22:40   #28990  |  Link
cartman0208
Download server broke down last night
I hope I can fix it tomorrow
cartman0208 is offline   Reply With Quote
Old 13th November 2019, 00:18   #28991  |  Link
gonca
Try VideoHelp
Old 13th November 2019, 07:17   #28992  |  Link
gamete
Thank you guys
Old 13th November 2019, 16:10   #28993  |  Link
Michi
Muxing Error on DV UHD Disc Daddys Home 2:
[11.13.19] BD Rebuilder v0.60.29
[15:55:43] Source:  DADDYS_HOME_2
  - Input BD size: 55,33 GB
  - Approximate total content: [01:49:15.674]
  - Target BD size: 46,26 GB
  - Windows Version: 6.2 [9200]
  - Quality: Good (Fastest, BD-25+), ABR
  - Decoding/Frame serving: FFMPEG
  - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448
- Resuming from previously started job.
[15:55:44] PHASE ONE, Encoding
 - [15:55:44] Processing: VID_00010 (2 of 4)
 - [15:56:10] Multiplexing M2TS
 - Error in attempt to multiplex: MUX_00010.meta
 - Bitstream exception Unknown exception. It does not have to be! Please contact application support team for more information.
[15:56:30] - Failed to build structure, aborted
Michi is offline   Reply With Quote
Old 14th November 2019, 06:57   #28994  |  Link
Lathe
Lathe's Avatar
UHD to UHD
Yep, that's what I thought, thanks!
Old 14th November 2019, 06:58   #28995  |  Link
Lathe
Lathe's Avatar
Gotcha, thanks Boss! (and gonca too for the above)
Old 14th November 2019, 07:02   #28996  |  Link
Lathe
Lathe's Avatar
@AF
Poor rabbit...
Old 14th November 2019, 07:19   #28997  |  Link
AmigaFuture
@AF
Poor rabbit...
It was a fake rabbit...artfully done to look real. Not everything is as it seems as typed for Online (Sneeky Laughter). I wouldn't kill one just to mock a religion that has done much worse to a non-organized one. That's against my ethics.
Old 14th November 2019, 19:41   #28998  |  Link
zamengo
I have playback issues with .29.
Every Universal and Sony discs stop after trailers, when a fast forward the discs runs fine.
PS. Only on Xbox One S, I don't have this problem in a native UHD player.
zamengo is offline   Reply With Quote
Old 18th November 2019, 18:41   #28999  |  Link
Michi
Muxing Error on Life of Pi:
[11.18.19] BD Rebuilder v0.60.29
[17:54:21] Source:  LIFE_OF_PI
  - Input BD size: 58,85 GB
  - Approximate total content: [02:17:44.714]
  - Target BD size: 64,45 GB
  - Quality: High Quality (Default), Two Pass
[17:54:22] PHASE ONE, Encoding
 - [17:54:22] Processing: VID_00001 (1 of 3)
 - [17:54:22] Extracting A/V streams [VID_00001]
 - [17:59:11] Reencoding video [VID_00001]
 - [17:59:11] Keeping original video (no reencode)
 - [17:59:11] Processing audio tracks
   - Track 4359 (deu): Keeping original audio
 - [17:59:11] Multiplexing M2TS
 - Buffer overflow in UHD_Correct_M2TS
 - Error in attempt to update UHD M2TS.
[18:18:06] - Failed to build structure, aborted
Old 19th November 2019, 14:06   #29000  |  Link
Mike-uk
noticed when encoding its using the 32bit version of x264 ?? why is it not using 64 bit
also how do you add stuff to the avisynth script, i want to enable the MT mode ?
Thanks
Mike-uk is offline   Reply With Quote
