Old 19th April 2008, 00:07   #21  |  Link
Wilbert
New version (v1.30) out with write support!
Old 20th May 2008, 17:24   #22  |  Link
Wilbert
If anybody is still interested. v1.31 contains animation/multipage write support. Next version will have read/write sequence support.
edit: Does anyone know whether alpha is supported in BMP3? ImageMagick automatically creates BMP4 when feeding RGB32 (and BMP3 for RGB24), but i'm not convinced that alpha is not supported in BMP3.
Old 20th May 2008, 22:51   #23  |  Link
Archimedes
Originally Posted by Wilbert View Post
This package includes some ImageMagick dll's which are needed to use this plugin. They need to be in the same folder as the pictures you want to open (for some reason, putting them into your system folder doesn't work).
Do you also offer a static build? Copying the pictures to the ImageMagick DLL folder are not allways very comfortable.
Archimedes is offline   Reply With Quote
Old 21st May 2008, 05:00   #24  |  Link
gzarkadas
gzarkadas's Avatar
You can put the image magic dlls in the system32 folder and just copy the avisynth script inside the images folder, so that you can use filenames without paths when calling Imma... functions (if you use paths you will get an error).
Just tested with Immaread; had immaavs.dll in another folder, image magick dlls in system32 and used various jpeg images in various folders.
@Wilbert,
The problem has to do with path handling, but I don't know exactly where; I may have time to search deeper later.
AVSLib, a free extension library for Avisynth. Current version: 1.1.0 (beta), 14/05/2007.
[ Home page | Download page ]
gzarkadas is offline   Reply With Quote
Old 21st May 2008, 22:59   #25  |  Link
Wilbert
Yes, that works Thanks !!!
@Wilbert,
Let me know if you have figured this out!
I still have to figure out how to do that gzarkadas, how do i do that? Do i need to add all ImageMagick libs (not just CORE_RL_magick_.lib) as lib modules in the link tab of the project settings? Or do I need to add all the libs to the project (Add to Project -> Files), just as i did with the source files.
Old 22nd May 2008, 00:22   #26  |  Link
gzarkadas
gzarkadas's Avatar
...Do i need to add all ImageMagick libs (not just CORE_RL_magick_.lib) as lib modules in the link tab of the project settings?...
Yes, all 49 libs (that's the number of dlls I counted with IM_MOD_... dlls included; a lot of work ) - at Configuration properties | Linker | Input | Additional Dependencies. This will create a large dll; around 6MB.
I will send a PM with some of my test-runs; they may be of use.
Old 28th May 2008, 00:26   #27  |  Link
Wilbert
Version 1.32 is out.
Changelog:
* changed license from "GPL v2 or later" to "GPL V2" (in order to be able to use sequence support from ImageReader/ImageWriter and AppyMessage);
* ImmaWrite: added sequence writing;
* fixed the path problem (by changing the working directory internally to the place of the image(s) and passing only the filename to the ImageMagick libs; won't work for W98) (thanks gzarkadas!);
* ImmaRead: added sequence reading and info;
* added the necessary info for compiling this plugin.
Syntax:
ImmaRead (string filename, int start, int end, bool animation, bool info)
ImmaWrite (string filename, int start, int end, string type, string mode, bool animation)
Old 28th May 2008, 13:14   #28  |  Link
Archimedes
LoadDLL doesn't work, so have to copy the ImageMagick dll's to the program directory of Fritz Photo. This works now.
Is there a way to tell immaavs where to find the ImageMagick dll's (as a new parameter)? It's because, i like to copy all dll's in a subfolder of the program directory.
Old 28th May 2008, 13:21   #29  |  Link
Wilbert
LoadDLL doesnít work
Yes i know, but i don't know why.
What don't you include that subfolder as PATH environment variable?
Old 28th May 2008, 13:33   #30  |  Link
Archimedes
The program itself should work without any changes to the system configuration (only AviSynth have to be installed). Is there a way within AviSynth to do that (setting a path environment for dll's)? If no, i will live with the dll’s in the main directory. That was the reason (handling of the dll's), why i asked for a static build.
Old 28th May 2008, 13:44   #31  |  Link
Wilbert
Is there a way within AviSynth to do that (setting a path environment for dll's)? If no, i will live with the dllís in the main directory.
I will ask Stickboy to add this to his GetSystemEnv plugin
Old 30th May 2008, 10:28   #32  |  Link
stickboy
AviSynth Enthusiast
Okay, but it might take me a couple of days since I don't have a build environment set up anymore.
stickboy is offline   Reply With Quote
Old 1st June 2008, 15:18   #33  |  Link
tacman1123
This was originally a question about installing immaavs, I've deleted the question but will provide the answer to anyone who comes across this thead.
immaavs is dependent on the ImageMagick dlls, which must be installed in the system directory. Those dlls can be found at
http://www.geocities.com/wilbertdijk...Magick_dll.zip
Wilbert -- maybe add a README file to the zip that includes this?
Thanks for providing this great tool!
Tac
tacman1123 is offline   Reply With Quote
Old 1st June 2008, 15:27   #34  |  Link
Wilbert
You need to put the following dll's:
in your system folder, and immaavs.dll in your plugin folder. Does that work?
Old 9th June 2008, 12:25   #35  |  Link
stickboy
AviSynth Enthusiast
I've updated my GetSystemEnv plug-in to include a SetWorkingDir function. Sorry for the delay. Let me know if there are any problems.
Old 9th June 2008, 15:23   #36  |  Link
Archimedes
I canít benefit from SetWorkingDir so far. My working directory has to be the program directory. All plugins, libaries and DLLís are in sub folders under the program directory. A typical script looks like this (simple example with Rotate):
LoadPlugin("plugins\Rotate\Rotate.dll")
Import("lib\FritzPhoto\FritzPhoto.avs")
angle  = 1.0
width  = 0
height = 0
color  = 0
isYV12() ? YV12toRGB() : last
Rotate(angle, width, height, color)
As you can see, iím working with relative path names.
Old 9th June 2008, 17:40   #37  |  Link
Wilbert
I guess i need to make a static build then.
Old 22nd June 2008, 00:20   #38  |  Link
Maxiuca
I've tried plugin today to load a sequence of TIFFs but unfortunatelly the image sequence reading does not work properly.
For example if you use file matrix like "name.%04d.tif" and "start=1000, end=3000" parameters, the plugin will just read first 2000 tiffs starting from "name.0000.tif" and ending with "name.1999.tif" instead of reading from "name.1000.tif" to "name.3000.tiff"
Maxiuca is offline   Reply With Quote
Old 22nd June 2008, 00:31   #39  |  Link
Wilbert
For example if you use file matrix like file.%04d.tif and "start=1000, end=3000" parameters, the plugin will just read first 2000 tiffs starting from file.0000.tif and ending with file.1999.tif
I'll report the bug to the author of this plugin in the other thread.
Thanks for the bugreport! I will fix it for the next release.
Old 22nd June 2008, 07:00   #40  |  Link
Mug Funky
interlace this!
Mug Funky's Avatar
that's weird - i could have sworn i read an image sequence that way a few days ago. i may have been using vanilla imagesource though.
btw - write support is the bomb. i can make dpx's directly now, and with a little finessing can maintain timecodes in the filenames (though the headers are all stamped 00:00:00:00 and the files are flagged as log, i can work around this). thanks heaps Wilbert! being able to work from a mov in pc range saved my arse (and the highlights/shadows).
