#821 | Link |
I dont care so should you
Well I herd that the zune used a h.264 hardware codec to decode the h.264 videos you put on it...
That it needed to only transcode Divx/xvid mpeg4
My Installer's || |
#823 | Link | |
with 264 (encoded for the ps3) ac3 6ch mux by 1.2.10 the ff and rw doesn't work mux by 1.3.1 ff and rw WORK mux by 1.3.6 ff and rw doesn't work mux by 1.4.0a ff and rw doesn't work |
#827 | Link |
Have at it... I Dont care just know Frequint updates...
And use the new links I just posted in My Signature... new ffdshow Filter ffdshow_rev1882_20080304_clsid.exe
My Installer's || |
#828 | Link |
BUG Report
ResampleAudio() takes two parmeters now, however, you have only specified the bitrate. Can you change that?
http://avisynth.org/ResampleAudio |
#830 | Link |
Hi.
I tried to encode an h.264-encoded BD movie, but right off the bat, when I click on "Start" I get the following message from bepipe.exe: "The application failed to initialize properly (0x0000135). Click on OK to terminate the application". I think have everything that's needed to encode the audio. Please, let me know what may be causing this. |
#831 | Link | ||
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 7th March 2008 at 12:08. |
#832 | Link |
@Atak_Snajpera
is it possible to create the .stats file in the jobx folder and the audio/video too. the reason, is like that I'll be able to get the ripbot_temp folder with all the files from the encoding process. I queued few anime this week, but 1-2 of them didn't look good, so I wanted to change setting to the 2th pass, but the next job overwrite the .stats file, so I had to do the 1th pass again. |
#833 | Link |
ok! .stats will be save in jobs folder in next version
#835 | Link | ||
#836 | Link |
Hi there, I've just installed Vista x64, and seem to be having some problems...
1. The modified MT version of AVIsynth, isn't working with Ripbot264. When I enable MT in the AVIsynth script window (In Ripbot264) then go to encode, it finishes instantly with an "All jobs finished" message... Obviously there's no output, is there a way to go this to work with Vista etc? Thanks. 2. Lots of videos I have ripped on my computer, admittedly old don't seem to work anymore. When I go to load them in Ripbot264, Media Player Classic opens with red text saying "Unable to decode fram 0....." I'm sure these files were fine on my XP installation, and they play with no problems outside of Ripbot264 ![]() I've got latest FFDshow\Haali splitter\Avisynth 2.5.7 installed. Thanks for any help with this ![]() |
#837 | Link | ||
#839 | Link |
1) Decrypt DVD using DVDFab HD decrypter
2) load VTS_01_1.VOB in RipBot264 3) select iPhone profile 4) select bitrate. 512 kbps will be enough. 5) click in properties and select in size section PSP 480x.... 6) Ok ,Done ,Start!
