#8604 | Link |
I don't know if the automated tools can handle this. What I know working reliably, is the manual method:
You extract the audio tracks to separate files. You convert the video in a manual video encoding job via the Queue. If you want the audio tracks converted too, you also create audio conversion jobs for the Queue. You use the manual multiplexer tool (in the "Tools" menu) for your desired container (MP4 or MKV, usually, Ctrl+4 or Ctrl+5). You load the converted video track into the multiplexer window, then you load one audio track after another (may they be original or converted). You finish the multiplexing job and run it in the Queue. Last edited by LigH; 19th August 2018 at 19:51. |
#8605 | Link |
If you're using the OneClick encoder, open it, click the "Config" button next to the OnceClick profile list, select the Audio tab when the configuration window opens, and make sure "use only the first audio tack" is unchecked. I think it's checked by default. Or.....
Open the source with the File/Open menu or the File Indexer. When MeGUI offers to index it you can select audio tracks. By default they're all selected. If MeGUI can do so, the audio will be extracted when you run the indexing job (MKV, vob files etc). For other sources it'll create scripts to encode the audio instead. Either way, they should be loaded into the audio section. If there's two audio tracks, there'll be two tabs at the top of the audio section. If you want MeGUI to automatically combine the video and audio after encoding, instead of adding the video and audio jobs to the job queue individually, click the "AutoEncode" button after the video and audio scripts have been created and loaded. |
#8606 | Link | |
Sent from my P4 using Tapatalk |
#8607 | Link |
Details, details, details... you still did not post any of your scripts, neither a log file including the analysis of your source file.
If you write your own custom scripts, then MeGUI cannot know the attributes of the source file. And using DirectShowSource is discouraged in MeGUI for serious reasons, e.g. there is a risk that first and second pass of a 2-pass encoding don't match frame exactly; and it is even possible that DirectShowSource is unable to decode more than one audio stream, depending on the splitter for the container of your source file, or even in general? MeGUI will offer you the "File Indexer" for FFMS2 or L-SMASH Works as primary source plugins, after analyzing the source file and knowing how many streams it contains and which attributes they have. Furthermore, you may not even need to convert the audio streams, but they have to be extracted to be multiplexed into your newly encoded copy. |
#8608 | Link | |
Thanks i understand this time completely & sorry for irritating you Sir
I'm Requesting You... Quote:
#8609 | Link | |
Of course if the appropriate audio track can't be specified in the scripts you're creating, there's nothing MeGUI can do about that. |
#8610 | Link | |
ohh that's great u r Awesome
#8611 | Link |
DGIndex grayed out in 2875 Update
I just updated to MeGUI 2875 and found that DGIndex, DGIndexIM and DGIndexNV are all grayed out. I tried with both a .vob and a .mkv file and they are grayed out in both formats. I have IM and NV checked in the settings dialogue box and I do have a license for NV but they still show-up gray.
Anyone else experiencing the same problem? Edit: addition I've done a bit more work with .vob files and found that when I drag and drop one onto the main screen I'm no longer provided with an indexer choice, it goes straight into indexing. Then when it finished encoding the last twenty minutes of the movie I was encoding were gone. The time/length of the movie showed correctly but the end of it was not there. Just tried the backup megui.exe file with the same results...might this be a problem with the also updated avisynth files? Edit NEW Tried to update a file at a time from a BU directory and contrary to my above comment about AviSynt those files do not seem to be the problem. BUT...when I update to MeGUI 2875, MeGUI Libraries 2847 and MediaInfo 18.08 the problem re-appears. SO...the problem may be in one of those updated files? At this point I am unable to encode a full movie from .vob files as it only recognize one .vob file at a time and does NOT put them together to create the whole movie. I hope that's clear? EDIT NEW NEW! Whoever fixed it (Zathor?) thank you very much, 2872 is working fine!...thanks again.
Humanity does more than rhyme with insanity...it defines it. Last edited by HOB; 9th September 2018 at 05:32. |
#8613 | Link |
v2836 On-Click Failure
Just "upgraded" to 2836 and am struggling to get it to work. With every attempt to run a one-click job, the resulting video is nothing but a green screen with the words "Bad license" at the top of the screen. The encoding takes 3 minute and should be taking 30 minutes. No errors are returned and the log file shows everything processed perfectly.
#8616 | Link |
You're most welcome...my hats off to you for responding so quickly, as you have in the past...most impressive.
Thanks again
Humanity does more than rhyme with insanity...it defines it. |
#8617 | Link | |
Just to be clear, I have a folder named DGIndexNV in the MeGUI "tools" folder. In the DGindexNV folder are the DGIndexNV.exe, DGIndexNV.dll, DGDecodeNV and license.txt files. |
#8618 | Link |
"the DGIndex people"
videoh = DG ![]() Check your system for stray copies of DGDecodeNV.dll, for example, in your plugin directories. Avisynth+ is not always so transparent about where it picks up the DLL. If you still have the problem after making sure there is only the one DLL there in the folder and nowhere else, then we may have to get Zathor involved. Last edited by videoh; 11th September 2018 at 03:40. |
#8619 | Link | |
![]() Checked around, found a copy in the Avisynth+ plugins folder (but I think I need it there) and removed it (temporarily). Still, the file created was a green screen with the "Bad license" message. So, that rules that possibility out. |
#8620 | Link |
Life looks better in UHD
I recently backed-up my UHD disc version of Blade Runner Final Cut and have been most impressed that its colour doesn't have the blueish tinge that the VC-1 Blu-ray disc release has.
BRD disc [VC-1]:- ![]() UHD disc [HEVC]:- ![]() Anyway, my question is... What are my options to configure MeGUI to generate an 10-bit HEVC encode at 1920x1080 pixels whilst preserving the colour? Cheers
megui |
