Old 12th June 2003, 14:48   #201  |  Link
trbarry
trbarry's Avatar
@cuisinart: Thats because im going straight from yv12 to RGB. I could make it so you can set it either to do interlaced chroma upsampling or not. Or go from yv12 to YUY2 (or 4:4:4) and then goto RGB. Ill look into that for you.
As mentioned, the code upsampling in MPEG2DEC2 seems already to be correct. It's not really a user option but determined by the flags, prog frames, etc.
- Tom
trbarry is offline   Reply With Quote
Old 12th June 2003, 21:44   #202  |  Link
WarpEnterprises
C64
WarpEnterprises's Avatar
I'm too strongly voting for integrated D2V creation:
- There are MANY "bug-reports" coming from version incompatibilities only.
- I can't understand how you can use an inaccurate framecount input
- even without the other goodies (CSS, audio,...) we would have an up-to-date reference mpeg2 decoder.
- maybe you can summarize in the docu the pros and cons of the many many iDCTs
Thanks for your work!
[EDIT]: "Bug Reports" like "it's not working, why? What version of DVD2AVI? Took the wrong one...
framecount: how can you use a source in avisynth if the framecount is not reliable (esp. if the actual count is less than predicted)? Are black frames outputted?
WarpEnterprises is offline   Reply With Quote
Old 12th June 2003, 21:59   #203  |  Link
Nic
"MANY "bug-reports" coming from version incompatibilities only" What bug reports are you referring to?
" can't understand how you can use an inaccurate framecount input" ? What does that one mean too ?
I do need to rewrite the docs, or at least part of them. I explain the pros and cons of the iDCT's. But its reasonably simple. Use 2 if your non-p4 and 5 if you have a p4. Unless you want the slightly (& it is only slight "not magnitudes" as Isibaar puts it ) more accurate idct i.e. SimpleIDCT, which is 7. All others should probably be ignored.
-Nic
Nic is offline   Reply With Quote
Old 12th June 2003, 22:06   #204  |  Link
bond
what will be used if i dont define any idct?
Ogg Theora | Ogg Vorbis
Old 12th June 2003, 22:12   #205  |  Link
Nic
It does it automatically. 2 if your non-p4 and 5 if you are using a p4.
-Nic
Old 12th June 2003, 22:14   #206  |  Link
symonjfox
IUUULEEEENZ
symonjfox's Avatar
The DEFAULT ... =2
Else you can edit your defaults so you won't need any more to write the entire string.
PC1:AMD Athlon II x4, 4GB DDR2, Ati Radeon 4830, 4 hard disks
symonjfox is offline   Reply With Quote
Old 13th June 2003, 00:01   #207  |  Link
V-tec
I have made a comparison between different version of Mpeg2dec3 from 1.00 to 1.08 and Mpegdecoder-YV12
My config is:
Athlon Xp 1800+, 512Mb DDR 2100 cas 2b MB Asus A7V266-E etc...
Vdubmod 1.5.1a + debug view, Xvid Koepi 14.05.03 quant 2
Mpeg2dec3 1.0x
The Avisynt scripts,
for mpeg2dec 1.0x:
#  SOURCE
mpeg2source("C:\driven\driven.d2v", idct=X)
#  CROPPING
crop(14,74,690,424)
#  SELEZIONE
trim(5000,7999)
#  RESIZING
BicubicResize(608,256,0,0.5)
for MpegDecoder-YV12
#  SOURCE
mpegsource("C:\driven\driven.d2v")
#  CROPPING
crop(14,74,690,424)
#  SELEZIONE
trim(5345,8344)
#  RESIZING
and the results:
mpeg2dec3 1.00
idct1=_________34.21fps_______87.68s_____30.217Ko
idct2=_________34.54fps_______86.86s_____30.217Ko
idct3=_________29.68fps_______101.06s____30.269ko
idct4=_________28.53fps_______105.09s____30.353ko
idct5=_________28.67fps_______104.63s____236.900Ko
mpeg2dec3 1.01
idct1=_________34.25fps_______87.59s_____30.217Ko
idct2=_________34.46fps_______87.03s_____30.217Ko
idct3=_________29.56fps_______101.46s____30.267ko
idct4=_________28.53fps_______105.15s____30.241ko
idct5=_________28.61fps_______104.93s____236.900Ko
mpeg2dec3 1.02
idct2=_________34.20fps_______87.70s_____30.217Ko
idct3=_________29.67fps_______101.11s____30.267ko
idct4=_________28.45fps_______105.46s____30.241ko
idct5=_________28.70fps_______104.54s____236.900Ko
mpeg2dec3 1.03
idct1=_________34.37fps_______87.28______30.217Ko
idct2=_________34.53fps_______86.88s_____30.217Ko
idct3=_________29.71fps_______100.97s____30.267ko
idct4=_________28.64fps_______104.73s____30.241ko
idct5=_________28.75fps_______104.34s____236.900Ko
mpeg2dec3 1.04
idct1=_________33.72fps_______88.97s_____30.217Ko
idct2=_________33.77fps_______88.84s_____30.217Ko
idct3=_________29.39fps_______102.08s____30.240ko
idct4=_________27.15fps_______110.49s____30.241ko
idct5=_________28.49fps_______105.29s____236.900Ko
mpeg2dec3 1.06
idct1=_________34.98fps_______85.77s_____30.217Ko
idct2=_________35.34fps_______84.90s_____30.217Ko
idct3=_________30.28fps_______99.07s_____30.269ko
idct4=_________29.14fps_______102.94s____30.353ko
idct5=_________35.28fps_______85.02s_____30.217ko
idct6=_________35.46fps_______84.60s_____30.330Ko
idct7=_________32.96fps_______91.30s_____30.245ko
mpeg2dec3 1.07
idct1=_________35.07fps_______85.52s_____30.217Ko
idct2=_________35.29fps_______84.98s_____30.217Ko
idct3=_________30.24fps_______99.20s_____30.269ko
idct4=_________29.14fps_______102.93s____30.353ko
idct5=_________35.28fps_______85.04s_____30.217ko
idct6=_________35.33fps_______84.89s_____30.330Ko
idct7=_________32.84fps_______91.34s_____30.245ko
mpeg2dec3 1.08
idct1=_________35.08fps_______85.51s_____30.217Ko
idct2=_________35.33fps_______84.91s_____30.217Ko
idct3=_________30.23fps_______99.22s_____30.269ko
idct4=_________29.13fps_______102.99s____30.353ko
idct5=_________35.32fps_______84.91s_____30.217ko
idct6=_________35.40fps_______84.74s_____30.330Ko
idct7=_________35.61fps_______84.23s_____30.245ko
mpegdecoder YV12
idct2(?)=______37.87fps_______79.21s_____30.216ko
V-tec is offline   Reply With Quote
Old 13th June 2003, 01:48   #208  |  Link
trbarry
trbarry's Avatar
Very interesting results above. It looks like:
1) Prior to release 1.06 idct=5 was busted on Athlons. It should have defaulted to 2.
2) It also looks like Athlon speed for idct=7 is now (v1.08) actually faster than idct=2 or the others. Nifty.
- Tom
Old 13th June 2003, 01:53   #209  |  Link
JohnMK
Tom I'd love to see if idct=5 is actually faster on P4's. I'd run a benchmark if I knew how to isolate it down to two decimal places like he does.
JohnMK is offline   Reply With Quote
Old 13th June 2003, 08:53   #210  |  Link
Nic
@Tom:
"It also looks like Athlon speed for idct=7 is now (v1.08) actually faster than idct=2 or the others. Nifty"
It looked that way in my tests too, but I didn't want to say anything until I was sure (because I said the skal iDCT was the fastest...which obviously isn't correct )
(Very nice work , Oh and I looked into that MPEG2Dec3 parity thing, and couldnt find the problem. Let me know if you can look into it for me (& I hope you enjoyed the film))
@V-tec: Thanks for all those results That must have taken some work and time, so thanks a lot. And it shows that we have made it faster, even if its only fractional. (You were correct in saying MPEGDecoder does use almost exactly the same as iDCT=2)
@John: Im pretty definite that idct=5 is faster on P4s. But anyone that knows different please let me know.
-Nic
Old 13th June 2003, 16:26   #211  |  Link
trbarry
trbarry's Avatar
Cruncher posted some results back on page 3 that suggest 5 would still be faster on P4's.
- Tom
Old 14th June 2003, 18:24   #212  |  Link
Th3-S4int
Hi Iam new here and come from Germany, but i hope you will understand what i mean:
1. Which idct is the best for a Athlon Thunderbird (1.2GHZ)? Until now i used standard, but i hope there are some faster! And what is the different form standard (0) to the optimal setting (exp. 7) (i mean is it faster or something else?)
2.For what is Post Processing? does it help to have better compressiblity? Increase it the Picture quality?
I hope someone helps me, Thx!
Th3-S4int is offline   Reply With Quote
Old 14th June 2003, 19:40   #213  |  Link
JohnMK
1: idct=7 on your particular CPU.
Old 15th June 2003, 00:41   #214  |  Link
sapient
Unbeliever
I am a recent convert to the intel CPU's. My limited experience so far with a celeron @ 1.7 and a p4 @ 2.8 w/ HT has shown me that the speed difference between iDCT 2 and 5 is inconcequential. I can't think of a way to test them in an accurate way though. I just try to look at virtualdub's fps count @ a specific time. Obviously this "method" isn't exactly dependable. Does anyone have a simple and accurate method to standardise such a mesurement?
sapient
sapient is offline   Reply With Quote
Old 15th June 2003, 00:47   #215  |  Link
Nic
Well idct=2 & idct=5 produces exactly the same output, so if you've got a p4 id still say use idct=5 over 2. Just because he can't do any harm and won't be slower.
-Nic
Old 15th June 2003, 11:01   #216  |  Link
Blight
Software Developer
Blight's Avatar
Nic:
As someone who wrote a directshow source filter, is there any chance you'd port this effort into a directshow MPEG2 decoder filter, making it the first (and I believe only) freely available such filter?
Not to mention it could be a boon for HDTV decoding as transport support is really bad under directshow at the moment.
Yaron Gur
Zoom Player . Lead Developer
Blight is offline   Reply With Quote
Old 15th June 2003, 11:29   #217  |  Link
Nic
I tried it once with libmpeg2. It worked...almost (not quite Cant remember why not though). Yes I'd forgotten about that. Ill look into that again soon
-Nic
Old 16th June 2003, 12:44   #218  |  Link
colin.findlay
Excuse me if this has already been asked a million times before (Although I couldn't find it on a search). The old v1 of MpegDecoder used to support decryping VOB's on the fly. As far as I can tell, the new version & MPEG2Dec3 don't support this. (Probably because it's based on DVD2Avi now?)
Are there any plans on putting it back in? It really was the core reason I used to use MPEGDecoder/AviSynth, and I loved it, although the speed increase is nice :-)
Regards
C
PS: Yes I know working from the DVD is slower and would probably negate months of processor optimiations - but I like the disk space it saves :-)
colin.findlay is offline   Reply With Quote
Old 16th June 2003, 12:46   #219  |  Link
Wilbert
MpegDecoder <> Mpeg2dec3
mpeg2dec/mpeg2dec3 was never able to import vob files. Why don't you continue with using mpegdecoder?
Old 16th June 2003, 13:10   #220  |  Link
Nic
Hmmmm, ill add D2VCreation support into MPEG2Dec3 into the next release, and reactivate OpenDVD.DLL support (and release my version of OpenDVD.DLL, the original is based on VobDec which I never liked)
So my planned changes for 1.09 are:
  • Compile with MSVC .net 2K3 (I tested it over the weekend and it improved the speed)
  • Add D2V Creation and release a new OpenDVD.DLL, this will keep MPEG2Dec3 still legal as all the DeCSS stuff will be in OpenDVD.
  • Try and make it so that using mpeg2dec3's internal colorspace functions (YV12toYUY2, etc) it will hopefully be able to call avisynth's colorspace routines instead and detect if its interlaced or not without the user having to specify.
  • Make it so that GetParity works ok, trbarry reports that it might not (in the TomsMoComp readme.txt). If anyone can test to see if its working or not that would be a great help
Sound ok? (This might take a while, due to me being busy and not being around next week)
-Nic
