Old 8th April 2011, 21:38   #1  |  Link
AlanJames1987
AlanJames1987's Avatar
FFMPEG 5.1 Sound Misplaced
When converting video with FFMPEG on Linux from any 5.1 source to an AAC 5.1 destination my channels get mapped incorrectly. I can't figure out what is causing this because I compiled the latest FFMPEG from source. I'm looking for any command line driven solution to fix this, including using external audio converters.
Here is a zip file containing the input I'm testing and the output I am getting.
http://www.alanjames1987.com/develop...hannelTest.zip
Please help. I'm at my wits end.
Alan James
Editor, Director, Producer
Orlando Video Production, Orlando Film Production Company, 9IronProductions.com
AlanJames1987 is offline   Reply With Quote
Old 9th April 2011, 03:35   #2  |  Link
tebasuna51
tebasuna51's Avatar
Your audio input is DTS 5.1, but the AAC output is only 2.0
Sorry I can't help you with Linux soft.
Old 9th April 2011, 04:00   #3  |  Link
kieranrk
It's because AAC channel order is different to AC-3 channel order. You can use the command line I think to remap the channels.
kieranrk is offline   Reply With Quote
Old 9th April 2011, 12:12   #4  |  Link
tebasuna51
tebasuna51's Avatar
This must be transparent to the user.
Old 9th April 2011, 12:32   #5  |  Link
Brazil2
AFAIK channel order for AAC 5.1 is C, L, R, SL, SR, LFE.
More info in this thread: http://forum.doom9.org/showthread.php?t=148178
Should be but it's not always true depending on the tools being used
Brazil2 is offline   Reply With Quote
Old 9th April 2011, 15:28   #6  |  Link
AlanJames1987
You're right. I must have uploaded the wrong file. Its fixed now though. Both files in the zip are 5.1.
Thank you. I believe that is the correct channel order. Now I just don't know what programs to use to get that channel order in my output file. FFMPEG seems to export all other 5.1 formats correctly, just not AAC.
Alan James
Old 10th April 2011, 15:11   #7  |  Link
kypec
User of free A/V tools
kypec's Avatar
For all my transcoding/encoding needs audio-wise I try to use eac3to - remapping channels between AC3/DTS/AAC (NeroAacEnc used) has never been a problem for me.
kypec is offline   Reply With Quote
Old 10th April 2011, 17:40   #8  |  Link
AlanJames1987
eac3to is a Windows program. I am looking for a Linux solution. I hear SoX does nearly the same thing as eac3to but I don't know how to use it. Does anyone have experience with SoX?
Alan James
Old 10th April 2011, 20:19   #9  |  Link
poisondeathray
audacity is available for linux, so you should be able to specify the channel order in that
Old 11th April 2011, 01:13   #10  |  Link
AlanJames1987
Thanks but I am looking for a command line solution. I should have explained in my op that I am trying to convert a few hundred movies for work. I'm a video editor at an advertising agency and we are trying to put our entire portfolio online.
Alan James
Old 11th April 2011, 06:11   #11  |  Link
kypec
kypec's Avatar
I've no experience with Linux whatsoever but have you tried running eac3to through wine?
Old 11th April 2011, 06:39   #12  |  Link
Midzuki
Unavailable
Midzuki's Avatar
sox has an option called "remix" which may give you what you're looking for...
{ source: sox.pdf }
Midzuki is offline   Reply With Quote
Old 11th April 2011, 16:55   #13  |  Link
AlanJames1987
The remix option is what I am looking for. I can't seem to get it working however and the man pages don't describe how to use it. I also can't find any good documentation online of how to use it.
Also, I submitted a bug report for FFMPEG so hopefully this problem I am getting will be fixed in the trunk.
Alan James
Old 11th April 2011, 20:53   #14  |  Link
J_Darnley
J_Darnley's Avatar
The sox man page on its website is no good?
This would do nothing: sox INPUT OUTPUT remix 1 2 3 4 5 6
This would reverse stereo: ... remix 2 1
So all you have to determine is which channel order your input is then order them correctly for the output
x264 log explained || x264 deblocking how-to
preset -> tune -> user set options -> fast first pass -> profile -> level
Doom10 - Of course it's better, it's one more.
J_Darnley is offline   Reply With Quote
Old 15th April 2011, 14:49   #15  |  Link
AlanJames1987
Thank you. The man page wasn't very helpful. I tried what you suggested before suggesting sox and could not get it to work. I was hoping to get some help from someone who has done it before.
An example of a problem I'm having is that sox only accepts audio files. How can I separate audio from the video while still preserving the quality and correct channel order? What format should I export to and convert to? Then how do I then merge that outputted audio file back with the original video file. I have a decent understanding of all of these questions. I just can't seem to get any of the specifics correct.
Alan James
Old 15th April 2011, 17:58   #16  |  Link
tebasuna51
tebasuna51's Avatar
Demux/Mux streams from a container is specific to the container.
Then to extract/mux from/to mkv you have MkvExtract/MkvMerge (in MkvToolnix, I don't know GUI's for Linux), the quality is always preserved and the channel order isn't changed in this level.
For mp4 you have Mp4Box (I don't know GUI's for Linux)
The ffmpeg dts decoder seems ok (with my windows SVN-r25870-Sherpya version the audio.wav have correct channelmap) with:
ffmpeg -i input.dts -acodec pcm_s16le -ac 6 audio.wav
but converting to aac:
ffmpeg -i input.dts -acodec aac -ac 6 -strict experimental audio.aac
the output is absolutely wrong
I think you can convert the decoded audio.wav with NeroAacEnc (there are a Linux version)
Old 16th April 2011, 06:35   #17  |  Link
AlanJames1987
Thank you for all the help but I have come to the conclusion that I'm not going to get the help I need on here. I have submitted a bug report to FFMPEG. Hopefully they will solve this problem soon.
Alan James
Old 16th April 2011, 10:49   #18  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by AlanJames1987 View Post
...I have submitted a bug report to FFMPEG. Hopefully they will solve this problem soon.
Good luck!
5.1, aac, ac-3, ffmpeg, surround sound
