Old 8th December 2017, 16:40   #541  |  Link
Ghitulescu
Ghitulescu's Avatar
Originally Posted by thinredline View Post
Thanks. With what software?
I do not know, as I do not use ASS/SSA.
However, if you use them, you should be aware of the tools that process such files. Because, me thinks, this is why you use ASS in the first place, that you can work with them....
But once you have them as XML+PNG, you can convert them easily to BD sups. Ans tsmuxer accepts them, too.
Why do we put 00:10:00.00 in the IN in BDedit?
The film started from the 10 minute mark from the beginning and it cut the last 10 minutes.
Why starts at 10 was explained in the corresponding thread. You should not need to change it, in particular when you do not know what you are doing.
Born in the USB (not USA)
Old 12th April 2018, 11:08   #542  |  Link
goal1664
Without a working bluray.bat link, all the guide is useless
goal1664 is offline   Reply With Quote
Old 22nd June 2018, 16:24   #543  |  Link
ccsoon
Hello.
thank you very much for this guide, I'm just doing my first effort and will see how that goes.
I have a question:
it seems tsmuxer can't add ASS files for the subtitles.
But I have some such files where the subtitle is stylised or it may contain some subtitles for a sign or something in another part of the screen.
What happens with such files?
Can i convert them to image files and load those to tsmuxer?
Use easySUP https://www.videohelp.com/software/easySUP and add your srt file in it and export it as "BD SUP"
ccsoon is offline   Reply With Quote
Old 20th September 2018, 21:27   #544  |  Link
tandi
hi, got problem here
which mpls shoud tsmuxer use ?
if use 00099.mpls ( the original didn't have 00099 to replace after remux )
if use 00813.mpls the duration is 02:00:14 , the right duration is 02:14:46
tandi is offline   Reply With Quote
Old 21st September 2018, 07:56   #545  |  Link
Ghitulescu
Ghitulescu's Avatar
which one you want - tsmuxer is not smart enough to read your mind and select the right movie according to your criteria.
These being said, in many movies, the 800 corresponds to the main movie in english, whereas the subsequent vary according to the edition of the movie, being wither versions in foreign languages or alternative cuts.
Old 21st September 2018, 12:11   #546  |  Link
tandi
it only contain 1 movie
that why i confused
bdedit said 00099 ( the movie duration is correct 02:14:46 )
but if i tsmuxer using 00099, i should copy dan replace the original right ?, but in original it didnt have 00099.m2ts and didnt have 00099.clpi
if i using 00813 ( the duration only 02:00:14 )
Old 21st September 2018, 13:27   #547  |  Link
ocean
Hi tandi, as he said Ghitulescu it is generally 00800.mpls, rename 00099.mpls in 00800.mpls, delete 00800.mpls original, do the same thing with the clpi file.
ocean is offline   Reply With Quote
Old 21st September 2018, 15:42   #548  |  Link
tandi
ocean, sorry still confused
so like this
in original file, there were :
- 00099.mpls
- 00800.mpls
- 00813.m2ts
in original file , didn't have :
- 00099.clpi
- 00800.clpi
so i delete 00800.mpls and rename 00099.mpls become 00800.mpls ?
then i add 00800.mpls in tsmuxer ( then add new subtitle )
after muxing,
- copy 00800.clpi to original file
- delete 00813.m2ts original dan copy 00800.m2ts to original file
is it that way ? or i am wrong ?
Old 21st September 2018, 16:24   #549  |  Link
ocean
Yes, always make a save.
after muxing, copy 00800.clpi to original file
Yes, delete after muxing: 00813.m2ts+00812.m2ts+00811.m2ts+00810.m2ts and clpi same number.
Old 21st September 2018, 17:06   #550  |  Link
tandi
hi , ocean
i already follow the steps
- delete 00800.mpls and rename 00099.mpls become 00800.mpls
- delete after muxing: 00813.m2ts+00812.m2ts+00811.m2ts+00810.m2ts and clpi same number
- copy 00800.m2ts to original file
but when i play the movie, it just blank
* thanks Ghitulescu for your help
* special thanks a lot for Ocean , that help me solve all the problem, all good now
Old 18th October 2018, 06:39   #551  |  Link
adamantcheese
Hey all, probably should have posted in this thread when I made that tool for getting around Scenarist. You can find it here. Combined with using a free image editor like GIMP, you should be able to edit IG menus without any commercial tools.
adamantcheese is offline   Reply With Quote
Old 27th October 2018, 21:40   #552  |  Link
mandeajupanu
i had the same problem with a lot of Bluray editing and the solucion was BDFix Pro
mandeajupanu is offline   Reply With Quote
Old 1st December 2018, 15:51   #553  |  Link
psideras
psideras's Avatar
Originally Posted by crl2007 View Post
2. Some discs have the video split across multiple *.m2ts files. This discs are containing the Rated and Unrated version, or some extra titles. When you come across one of them, DO NOT USE tsMuxer directly, because tsMuxer does not handle well seamless branched discs. First demux the streams with CLOWN BD ( it's a pretty intuitive program ) and then feed them into tsMuxer. You'll find the demuxed streams in "eac3to output" folder. For chapters, copy the text from chapters.txt that results after demuxing with CLOWN BD, only the time values. Like this: The rest remains exactly the same. Be sure to insert the streams in the correct order.
[/b]
Hello,
I have a disk with the main movie split at many m2ts. I used the clown bd to demux the streams and now I have to remux them with the subtitle that I want to replace. But how can we make it split at the same multiple files as the original bluray?
psideras is offline   Reply With Quote
Old 24th May 2019, 04:55   #554  |  Link
Treaties Of Warp
Agreed. Can't believe this. It's a batch file. Just paste it to the thread via code tags.
Trying to add subs and am blocked by not having the batch file.
Treaties Of Warp is offline   Reply With Quote
Old 9th September 2019, 04:00   #555  |  Link
maczones
Possible to add Subtitle if movie contains none?
Not sure if this question has been previously addressed but hope it can be answered, so here it is:
I have a movie that originally came without subtitles. I went ahead and added an English subtitle using tsMuxer as instructed but when I play the movie it is very jerky and unstable. Since this movie did not originally have subtitles, is there something extra I need to do when adding the subtitle or is this impossible to do under these circumstances?
TIA
Mac
maczones is offline   Reply With Quote
Old 22nd December 2019, 21:34   #556  |  Link
Gabriel88
Please tell me if there is a similar guide for adding subtitles on a 4k (UHD) Blu-ray Disc and keeping the original menu.
Thank you
Gabriel88 is offline   Reply With Quote
Old 12th January 2020, 09:54   #557  |  Link
FilipeAmadeuO
Originally Posted by Gabriel88 View Post
Thank you
The procedure is exactly the same.
FilipeAmadeuO is offline   Reply With Quote
Old 18th January 2020, 10:22   #558  |  Link
Gabriel88
Many thanks you for your reply.
Please indicate the links for the programs you use and are compatible with 4k (UHD) Blu-ray Disc:
1. Ts Muxer
2. Bd Info
3. BD Edit
4. Other programs.
Thank you.
Old 18th January 2020, 10:59   #559  |  Link
maxibon
The procedure doesn't work; BDedit UHD compatible is needed
I´ve done some works and subtitles and chapter selection doesn´t work properly.
maxibon is offline   Reply With Quote
Old 13th February 2020, 18:00   #560  |  Link
Gabriel88
Today I received BdEdit0.46 - UHD.
I made a 10 Eur donation on the site http://bdedit.pel.hu/.
I sent a follow-up email to info@pel.hu with the donation and I received a download link.
The program is very good.
Now we have 3 programs needed to author UHD Bluray:
BdEdit0.46
BDInfo.exe - v 0.7.5.5
tsMuxeR_2.6.15 Beta
I already added a subtitle to a UHD Bluray and it works fine.
Thank you
