Old 1st March 2008, 10:15   #381  |  Link
yonta
Originally Posted by napalm-187 View Post
hi
great tool
but i have an question
i have demuxxed an true hd track from batman beginns hd dvd
smartlabs cant detect the streamtype?
what can i do
i use version 1.3.5
thx
TrueHD from HD DVD is not yet supported.
Only TrueHD from Blu-ray is supported including on-the-fly DDcore extraction.
yonta is offline   Reply With Quote
Old 1st March 2008, 11:36   #382  |  Link
kleen
Originally Posted by n0mag!c View Post
when demuxing through GUI with multiple "append"ed TS-files tsmuxer attempts to create elementary stream files with "+" in their names and fails.
Demux option is a little buggy. Sometimes it gives extension ".ts", and creates transport stream, instead separate audio and video files.
To overcome this problem it's necessary to remove file name or select target folder for the stream files.
kleen is offline   Reply With Quote
Old 1st March 2008, 12:21   #383  |  Link
roman76r
Pelican9
Anyway, why do you call the PGS (Presentation Graphics Stream) to PSG?
It is a typing error.
What players understand PGS format?
roman76r is offline   Reply With Quote
Old 1st March 2008, 12:32   #384  |  Link
Pelican9
Coder
Pelican9's Avatar
Originally Posted by roman76r View Post
Pelican9
None of them.
It is a non existing format created by me and drmpeg based on the old SD sup format.
It contains
'PG', PTS, DTS, streamdata,
The file extension is .SUP
The PTS and DTS values have modified (decremented) by the first video PTS.
Only tsRemux and SUPread can export this format (drmpeg has removed this function from xport ).
Pelican9 is offline   Reply With Quote
Old 1st March 2008, 12:47   #385  |  Link
roman76r
Pelican9
I can add demuxing to same format.
'PG', PTS, DTS, inserted before "Presentation Composition Segment" (code 0x16) element only? Or it 10 bytes inserted before each element with different PTS/DTS values?
Old 1st March 2008, 13:13   #386  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Can PS3 play M2TS files with PSG subtitles?
Subtitles must be in BluRay Structure in order to work.
Old 1st March 2008, 13:42   #387  |  Link
Pelican9
Coder
Pelican9's Avatar
Pelican9
It would be great.
Insert this 10 bytes before every segment with different PTS/DTS (and decrement the PTS/DTS values).
Old 1st March 2008, 16:05   #388  |  Link
oldpainless
I hope this is not off topic...is it possible to take a h.264 AC3 mkv and mux it into something and burn it to disk (dvd5/dvd9) to play in a toshiba hd-dvd player?
Cheers
K
oldpainless is offline   Reply With Quote
Old 2nd March 2008, 09:13   #389  |  Link
hero88
roman76r: Really looking forward to the new version, what I really like is that you show the language also. I have not been able to locate anything else which can do that to a m2ts file.
hero88 is offline   Reply With Quote
Old 2nd March 2008, 10:34   #390  |  Link
ultratoto14
@Roman76r
Thanks for this really good and fast job. This is all the PS3 users were waiting for.
As the newly created ts is bigger than the original MKV, is it possible to add the ability to cut the files at DVD5/DVD9 size.
PS: I know that this is possible before using TSMUxer but as you put in all that we need to do the process in one pass ...
ultratoto14 is offline   Reply With Quote
Old 2nd March 2008, 14:49   #391  |  Link
McKajVah
Ahhh, after 5 days I can fianlly post...
Roman76r:
I have 5-6 different ts's with 1080i H264 Profile@4.0 DD5.1.
I've been using your SUPERB progam to convert them to profile@4.1 to play them on the PS3, but there seems to be a problem with audio sync...
On all of them I have to adjust the audio delay between -900 to -800 ms by using trial and error method....
Could you please look into this, or is there a better way for me to adjust the audio delay perfect.......?
If I open the original ts in MediaInfo it displays the following
General #0
Complete name
Format : MPEG-4 Transport
Format/Family : MPEG-4
File size : 15.6 GiB
Video #0
MenuID : 1 (0x1)
Codec : AVC
Codec/Family : AVC
Codec/Info : MPEG-4 AVC
Codec profile : Main@L4.0
Codec settings, CABAC : Yes
Width : 1920 pixels
Height : 1088 pixels
Display Aspect ratio : 16/9
Frame rate : 25.000 fps
Chroma : 4:2:0
Audio #0
MenuID : 1 (0x1)
Codec : AC3
Bit rate mode : CBR
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Rear: L R, LFE
Sampling rate : 48 KHz
Video0 delay : -33mn 51s
McKajVah is offline   Reply With Quote
Old 2nd March 2008, 14:54   #392  |  Link
menlvd
http://www.smlabs.net/tsMuxer/tsMuxeR_1.4.0_a.zip
test new ver with subs support, and remember it's alpha version
menlvd is offline   Reply With Quote
Old 2nd March 2008, 15:26   #393  |  Link
Atak_Snajpera
Roman76r:
Use PTSCalc to detect audio delay and then enter delay value in RipBot264
Old 2nd March 2008, 15:56   #394  |  Link
hm10
how to add?
i don't see in "add" any subtitle stream option
hm10 is offline   Reply With Quote
Old 2nd March 2008, 16:11   #395  |  Link
DoomBot
Everytime i try to use PTSCalc and click on Calc i get an error....Index was outside the bounds of the array..what am i doing wrong here?
DoomBot is offline   Reply With Quote
Old 2nd March 2008, 16:30   #396  |  Link
hero88
Roman76r:
The language detection works for m2ts not for evo files
This version doesn't handle subtitles as far as I can see.
Edit:
It detects PGS streams on on some Blu-Rays but not all, if I then select a PGS stream and say Demux, it gives this message SmartLabs tsMuxeR. Version 1.4.0(a) http://www.smlabs.net
Demux complete.
Demuxing time: 0.046403 sec
If I select a True-HD, and select Demux, it comes with these errors, AC3 bad frame detected. Resync stream.
Decoding AC3 stream (track 1): Bitrate: 640Kbps Sample Rate: 48KHz Channels
Old 2nd March 2008, 16:55   #397  |  Link
B4tm4n
Caped Crusader
B4tm4n's Avatar
Try mediainfo.
B4tm4n is offline   Reply With Quote
Old 2nd March 2008, 17:00   #398  |  Link
Atak_Snajpera
PTSCalc does not like large files There is another way. Use h264cutter and cut file on IDR-Frames. If your TS starts at Keyframe audio will be always in sync!
Old 2nd March 2008, 18:52   #399  |  Link
gav1577
gav1577's Avatar
@ hero88 the bad ac3 frames you have are caused by a bug in anydvd i presume thats whats u or the person who ripped the movie used i use any dvd for decryption but dont use it to dump files instead try iso buster to dump the file or files i found this out a few days ago hope this helps anyone getting AC3 bad frame detected. Resync stream.
gav1577 is offline   Reply With Quote
Old 2nd March 2008, 18:54   #400  |  Link
jamos
Hey Now!
will test with subs in bluray.
jamos is offline   Reply With Quote
tsmuxer
