24th March 2008, 06:01 | #81 | Link | |
PERL LIVES!
You can actually look at the m2ts files in the streams folder and figure out what they did. 001**.m2ts are the movie, 004**.m2ts files are the ones with the trivia/extras. And, every 004** file in the playlist, has a skipped 001** file that has the correct 'movie only' content. So the correct order should be: 00120, 00121, 00122, 00123, 00124, 00125, 00126, 00127, 00128, 00130, 00131, 00132, 00133, 00134, 00135, 00136, 00137, 00138, 00139, 00140, 00141, 00142
Schizophrenia, its not a sickness, its a way of life... |
24th March 2008, 18:10 | #82 | Link | |
Pelican, Any way this can be incorporated into you program so that it is easier to figure out the correct order for these seamless branching movies? Thanks for a great program!! |
27th March 2008, 10:35 | #84 | Link |
Important notes: Step 3 is not always trivial! When searching for the main movie look for xxxx.mpls that contain many PlayListMark entries. Currently Chapter export will NOT work correctly when the main movie consists of multiple m2ts files. This is the case when "file" under playlist does not always point to the same filenumber (eg. 0017). |
28th March 2008, 11:12 | #86 | Link |
@Pelican or everyone else who has fundamental knowledge of Blu-rays: Do you know whether I can replace a m2ts file by another one where only the video is reencoded in a Blu-ray compliant way (+ resolution unchanged) and muxed in the exact structure like the original m2ts? Or are there somewhere information stored about the m2ts (e.g. size) which I would have to change?
28th March 2008, 11:45 | #87 | Link | |
28th March 2008, 11:52 | #88 | Link |
Yep... I know of DVDs that there is the number of sectors stored somewhere which has to do with file size... Something like 1 sector = 2048 byte or so. But I have had a look at Pelican's tool and couldn't find any indication on a similar information in the Blu-ray files.
28th March 2008, 13:40 | #89 | Link |
Coder
Could somebody check this chapter info coming from Ratatouille?
00:00:00.000 00:01:16.201 00:06:29.430 00:09:22.895 00:10:58.074 00:13:30.976 00:17:40.017 00:19:37.551 00:24:48.320 00:28:55.233 00:33:05.066 00:38:13.416 00:40:33.138 00:44:11.231 00:46:59.316 00:51:27.667 00:57:02.168 00:59:32.318 01:00:53.524 01:07:19.743 01:11:25.656 01:15:28.231 01:19:25.093 01:23:30.129 01:25:34.462 01:28:18.334 01:32:39.011 01:35:41.443 01:38:49.715 01:40:54.673 01:42:58.964 01:50:33.126 |
28th March 2008, 20:09 | #90 | Link |
Hi Pelican,
Checked every single one with PowerDVD and they are correct to the seconds (can't say for milliseconds). Good work! First and last one are not really chapters but begin and end of stream (okay, you know that)... |
29th March 2008, 19:58 | #91 | Link |
hi, I believe BDedit is a rich tool, if you know what to do with it. Unfortunately i don't. Also it does not seem straight forward.
For example I read in a disc and it suggests that first playback is 00001.m2ts - which is the main movie and what i would want. in fact it goes to the menu first, then after selecting the movie to all kind of copy right screes and discalimer clips and then to the movie. Is there any way to figure out what the preset (original) actually does and then a guide how to change it, e.g. do not go to copyright screens ? thanks for any help |
31st March 2008, 02:11 | #92 | Link |
Just wanted to say this is a great tool. I have found it very useful, especially the chapter export function.
Now I'm working with a Blu-ray disc with subtitles. Is it possible to set the subtitle stream to automatically start by using the SetStream command? I tried, but couldn't get it to work. |
3rd April 2008, 13:21 | #93 | Link | |
Coder
Changes for v0.17 - Load/Save Chapter info can handle multiple PlayItems - Hotkeys - Check new version - Link to pel.hu I think it is possible, but I didn't try. Last edited by Pelican9; 3rd April 2008 at 13:24. |
3rd April 2008, 15:33 | #94 | Link |
Menu authoring - need help
Hello,
I hope someone can help me. BDedit do that ? The situation: I created a blu ray disc with 3 movies and a simple menue; menue is still picture but I want to have a sound (music) play whilst it is on. I used Nero 8. everything works fine, except I have no sound. The m2ts-file for the menue (00003.m2ts) plays no picture but sound, when played as file in e.g. Nero showtime. BDedit shows the stream length to be basically 0 (1 frame length actually) as opposed to 4.13 min which is the length of the song. I ran the mt2s-file through tsremux, which crashes, withTsmuxer it omitts the graphics stream and creates a blu ray structure reporting correct length of playback. unfortunately i cannot identify from hex editing the playlist files of both versions how and where to change lenght of this clip. I assume that the nero created menue file shows it at 0 lenght, hence no audio playback. can this type of entry (lenght of clip) be manipulated with BDEdit ? thanks for any help! |
4th April 2008, 08:30 | #96 | Link | |
Spielberger
SetStream x, y x first value -> 4 bytes, 2 bytes pg_text stream, 2 bytes audio stream y second value -> 4 bytes, 2 bytes ig stream, 2 bytes angle stream first value pg_text and audio stream 00000000 00000000 10000000 00000001 - 32769 disp off pg stream 1 (red=display on / off) 00000000 00000000 10000000 00000010 - 32770 disp off pg stream 2 .... 00000000 00000000 11000000 00000001 - 49153 disp on pg stream 1 00000000 00000000 11000000 00000010 - 49154 disp on pg stream 2 .... 10000000 00000001 00000000 00000000 - 2147549184 set audio stream 1 10000000 00000010 00000000 00000000 - 2147614720 set audio stream 2 10000000 00000011 00000000 00000000 - 2147680256 set audio stream 3 .... 10000000 00000011 11000000 00000010 - 2147729410 set audio stream 3 + pg disp on pg stream 2 .... second value ig and angle stream 00000000 00000000 10000000 00000001 - 32769 set angle stream 1 00000000 00000000 10000000 00000010 - 32770 set angle stream 2 .... 10000000 00000001 00000000 00000000 - 2147549184 set ig stream 1 10000000 00000010 00000000 00000000 - 2147614720 set ig stream 2 ... 10000000 00000010 10000000 00000010 - 2147647490 set ig stream 2 + angle stream 2 10000000 00000011 10000000 00000111 - 2147713031 set ig stream 3 + angle stream 7 so if you want to set subtitle stream 5 start automatically add SetStream 49157, 0 Last edited by bigotti5; 4th April 2008 at 08:36. |
6th April 2008, 01:39 | #97 | Link | |
could somebody please give me a hint as to how the coding for time stamps works - I can take it from there. Looks like there are 4 bytes for every time stamp - they just seem to make no sense to me. Please help me - thanks |
7th April 2008, 00:13 | #99 | Link |
thanks, I figured that in the mean time, but didn't make sense to me.
But with your confirmation I feel much better. Couldn't solve my problem though lol (still menue incl. 4.31 min sound still keeps lenght at 0.3 sec...) |
7th April 2008, 14:00 | #100 | Link |
I have a self authored (using Sonic Scenarist) mini Blu-ray disc (DVD-9) but when the movie finishes, it loops over and over again.
- Can I use BDedit to stop this from happening? - If yes, how would I go about it? |
bd menu, bdedit, blu-ray |
