19th January 2009, 22:12 | #881 | Link |
I confirm, when you stop x264 (by a -hard stop- like two time control C and not let it end "gently") cuvidserver hang and no other encode can be done. Happen in my case too.
24th January 2009, 10:35 | #884 | Link |
Do you have a changelog from 1.0.8 to 1.0.10?
edit: cuvidserver works fine in vista and windows 7 64bit. Or are you requesting a 64bit build menlvd? edit: nevermind, it's in the release notes. Thanks Don.
http://www.7-zip.org/ Last edited by Audionut; 24th January 2009 at 10:38. |
24th January 2009, 17:57 | #888 | Link |
Update on MKV support
Good news...MKV support for video is working all the way through to frame accurate serving via DGAVCDecodeNV.
I want to do some regression testing for ES and TS and then I'll make a test release. Then I need to add audio support. |
25th January 2009, 16:56 | #891 | Link |
MKV support test version
Here's a test version for MKV support. No audio yet. Feedback will be appreciated. Use the same CUVID server and nvcuvid.dll as for 1.0.10. This version uses a revised DGA file format, so you'll have to remake your existing projects if you want to open them with this version.
http://neuron2.net/dgavcdecnv/dgavcdecnv1011test.zip When reporting problems, please provide a stream sample that I can use to duplicate the issue. |
25th January 2009, 20:33 | #895 | Link |
mkv processing seems ok even though it seems to choose 29.97fps unless forced to 23.976fps which the mkv is (original avc video from a bluray + 1 audio stream). also dont skip through the mkv with the slider, it will hang. just load the mkv and process it straight away. you cant skip through the finished avs script either.
25th January 2009, 23:17 | #897 | Link | |
I even asked explicitly for that in my post! |
