4th September 2008, 09:14 | #6061 | Link |
I tested tebasuna51's samples with Sonic. The updated list is below:
With the help of Elektra999 I have dts samples with atypical channel map. The samples was encoded with DTS PRO SERIES SURROUND ENCODER. Only 3/2.0 and 3/2.1 was encoded with Surcode. AMODE Ch Arrangement+lfe Mask and MS channels order Detect-MaskCh eac3to libav remap ArcSoft problems Sonic Problems -------- - --------------- -------------------------- -------------------- ----------- ---------------- -------------- 0b000010 2 L R 0x0003 FL FR 2.0 0x000B (1) not needed ok ok 0b000110 3 L R S 0x0103 FL FR BC 2/1 0x0103 ok not needed BC ch empty FL & FR present in BC, BC only present in FL & FR 4 L R S LFE 0x010B FL FR LF BC 2/1.1 0x010B (2) -0,1,3,2,4,5 BC ch empty (3) FL & FR present in BC, BC only present in FL & FR, LFE empty, maybe remap needed 0b001000 4 L R Ls Rs 0x0033 FL FR BL BR 2/2 0x0033 ok not needed BL+BR ch's empty ok 5 L R Ls Rs LFE 0x003B FL FR LF BL BR 2/2.1 0x003B (2) -0,1,4,2,3,5 LF ch empty ok 0b000101 3 C L R 0x0007 FL FR FC 3/0 0x000F (1)(2) -1,2,0,3,4,5 ok ok 4 C L R LFE 0x000F FL FR FC LF 3.1 0x000F (2) -1,2,0,3,4,5 ok ok 0b000111 4 C L R S 0x0107 FL FR FC BC 3/1 0x0107 (2) -1,2,0,3,4,5 BC ch empty BC empty, BC only presesnt in FL & FR 5 C L R S LFE 0x010F FL FR FC LF BC 3/1.1 0x010F (2) -1,2,0,4,3,5 LF same than BC eac3to crashes 0b001001 5 C L R Ls Rs 0x0037 FL FR FC BL BR 5.0 0x003F (1)(2) -1,2,0,3,4,5 ok ok 6 C L R Ls Rs LFE 0x003F FL FR FC LF BL BR 5.1 0x003F ok already done ok ok (1) Wrong mask, the correct mask can be easyly put based in detection (2) When decoded with libav need remapping channels. (3) Same remap than libav needed. |
4th September 2008, 09:27 | #6062 | Link | |
4th September 2008, 10:00 | #6064 | Link |
Welcome. One thing I can suggest also, is to add -down16 to the command line if you want to save some space and you don't mind (or you can't hear) the quality loss of the 24 bit to 16 bit conversion. That's of course in case the source TrueHD track is 24 bit and not already 16 bit.
As already saint-francis pointed out, you need SUPread to convert HD DVD .sup to Blu-ray .sup, without any OCR. That's because subtitles in these two media are little different. Last edited by nautilus7; 4th September 2008 at 10:05. |
4th September 2008, 10:17 | #6065 | Link |
Things are coming slowly to my mind...
Since version 2.59 eac3to can also convert HD DVD TrueHD tracks to Blu-ray style TrueHD tracks with AC3 track interleaved. So there's no need to convert to pcm anymore. Except you don't have a TrueHD decoder. |
4th September 2008, 11:36 | #6066 | Link |
nautilus7
In my case I also have to convert TrueHD to PCM for tsMuxeR to create a correct Blu-Ray structure split into 4gig chunks to be played in AVCHD format on HDD on PS3. As you know tsMuxeR does not do proper TrueHD muxing in blu-ray structure and PCM is a good workaround. Thanks. |
4th September 2008, 12:01 | #6067 | Link | |
Also look at the tsMuxeR thread; http://forum.doom9.org/showthread.ph...82#post1170182 |
4th September 2008, 12:15 | #6068 | Link |
G_M_C
Thanks for that. This is actually me who posted that and made those tests. Currently there is no solution to mux TrueHD in Blu-Ray structure split in 4 gig chunks due to tsMuxeR problems. TsRemux does work with TrueHD but cannot split the file in 4 gig chunks which is necessary for fat32 disks on PS3 in AVCHD format. |
4th September 2008, 12:22 | #6069 | Link | |
----- Can you not burn to a DVD-DL in UDF 2.5 ? Or split before muxing i.e. "split manually" ? |
4th September 2008, 12:36 | #6070 | Link |
G_M_C
Yes you can burn to a DVD-DL in UDF 2.5 and it works. But the idea is to take one big (20-30gig) m2ts file open it with a muxer select the required tracks and generate a Blu-Ray structure with one playlist on fat32 (4gig chunks) convert the Blu-Ray structure to AVCHD and play the complete film from HDD on PS3 without writing a couple of DVD's. This requires alot of disk space but it is better than having alot of DVD's and changing the DVD's a couple of times during playpack of one movie. |
4th September 2008, 18:34 | #6071 | Link | |
b4k3d
4th September 2008, 22:27 | #6072 | Link | |
Location: The Great North (the better half of North America)
The only drawback is you need your own BD burner. Duppie, do you use AVCHD-ME, or is there something else out there that can produce the same media type... possibly that doesn't cause the slight pause between the 4GB chunks? |
5th September 2008, 20:27 | #6074 | Link | |
Remuxing Welcome to Dongmakgol Blu-ray to mkv results in async audio.
Remarkably, the WMV decoder is not capable of proper playback of the m2ts, artefacts all over. Ffdshow however, has no problems with the video. A sample can be found at: http://www.sendspace.com/file/71uipv |
5th September 2008, 21:00 | #6075 | Link | |
I think you remuxed that sample with TSMuxer, did you? _ _ _ _ _ |
5th September 2008, 21:13 | #6077 | Link |
Hmm, getting the weirdest error (see below for full output): "The channel modder was started with incorrect parameters." What is up with that? And how do I fix it? :)
E:\migrate\devils_rejects\BDMV>eac3to 1) 3: c:\video\devils.ac3 M2TS, 1 video track, 4 audio tracks, 2 subtitle tracks, 1:50:54 1: Chapters, 15 chapters 2: MPEG2, 1080p24 /1.001 (16:9) 3: DTS Hi-Res, English, 6.1 channels, 24 bits, 3093kbps, 48khz, dialnorm: -4dB 4: AC3, English, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB 5: AC3, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB 6: AC3, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB 7: Subtitle (PGS), English 8: Subtitle (PGS), Spanish [a03] The ArcSoft decoder doesn't seem to work, will use Sonic instead. [a03] AC3 encoding only supports 6 channels. Will mix the surround channels. [a03] Extracting audio track number 3... [a03] Removing DTS dialog normalization... [a03] Decoding with DirectShow (Sonic Audio Decoder)... [a03] DirectShow reports 5.1 channels, 24 bits, 48khz [a03] Mixing surround channels... [a03] The channel modder was started with incorrect parameters. Aborted at file position 21967306752. E:\migrate\devils_rejects\BDMV>
Gorgeous, delicious, deculture! |
5th September 2008, 21:31 | #6078 | Link |
eac3to "E:\migrate\devils_rejects\BDMV\*.m2ts" 3: "c:\video\devils.ac3"
Check that. EDIT: Sorry i've misssed the source is DTS-HD and libav doesn't work in this case-corrected. Just install TMT trial and give it a go and compare. Last edited by rica; 5th September 2008 at 21:55. |
5th September 2008, 22:27 | #6079 | Link | |
eac3to v2.60 command line: eac3to 1) 3: c:\video\devils.ac3 ------------------------------------------------------------------------------ M2TS, 1 video track, 4 audio tracks, 2 subtitle tracks, 1:50:54 1: Chapters, 15 chapters 2: MPEG2, 1080p24 /1.001 (16:9) 3: DTS Hi-Res, English, 6.1 channels, 24 bits, 3093kbps, 48khz, dialnorm: -4dB 4: AC3, English, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB 5: AC3, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB 6: AC3, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB 7: Subtitle (PGS), English 8: Subtitle (PGS), Spanish [a03] AC3 encoding only supports 6 channels. Will mix the surround channels. [a03] Extracting audio track number 3... [a03] Mixing surround channels... Loading white noise (needed for dithering)... [a03] Decoding with ArcSoft DTS Decoder... [a03] Removing DTS dialog normalization... [a03] Encoding AC3 <640kbps> with libAften... [a03] Creating file "c:\video\devils.ac3"... Video track 2 contains 159528 frames. eac3to processing took 21 minutes, 28 seconds. Done.
eac3to |
