1st February 2014, 11:14 | #1941 | Link | |
PgcEdit daemon
BD3D2MK3D v0.34
OK, here is the new beta: BD3D2MK3D.7z
- The MPLS to compute is a multi-angle MPLS - And it has too many SSIF parts to result in a file name compatible with the NTFS limitations. Under NTFS, the maximum length of a file name is theoretically 255 characters. However, the full length of the path\filename is also limited to 260 characters. So, the program checks if the MPLS to demux is multi-angle. If it's not the case, it uses tsMuxeR the normal way (with the MPLS as input file name). Otherwise, it computes the length of the names that tsMuxeR will give to the video files, and if it is greater than 255 characters, then eac3to is used. Otherwise, the path of the output directory is added, and if the total length of the full file name is greater than 260 characters, then eac3to is used. Otherwise, tsMuxeR is used with the "+" syntax, and the two video files are renamed on disc immediately after the demux, to re-create a descent file name. That means that now, tsMuxeR is used anyway in most cases, and the only exception is when the multi-angle SSIF has too many SSIF parts (normally more than 20 to 25 parts). For instance, it is now possible to demux the video streams of Cloudy 2 with tsMuxeR. The Disney BDs can also be demuxed by tsMuxeR, even when they have more than 120 parts in the MPLS, because the SSIFs are always mono-angle. IMO, most BDs will be demuxed by tsMuxeR, and only very rare exceptions will require the additional eac3to pass. Note that to minimize the risk to have to use eac3to instead of tsMuxeR, you should select an output directory with a short name and placed directly in the root of one of your drives. For example, if you use "D:\3D\", you will probably have the possibility to demux a multi-angle MPLS containing up to approx 25 SSIF parts with tsMuxeR. Otherwise, eac3to may be used, and that means that the time necessary to do the demux phase will be multiplied by 2. Not a big deal anyway. AFAIK, eac3to does a good job with the video streams. I think I'll keep that method, unless it doesn't work well with some BDs. Of course, if you find a BD that fails, please let me know. Also, I would like to know if a specific BD needs to be demuxed with eac3to. Currently, I have none. Thanks to jdobbs for having suggested the solution to use tsMuxeR in most cases.
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 1st February 2014 at 11:29. |
1st February 2014, 11:57 | #1942 | Link |
Is it a software to create a MPLS file ? So we could create a MPLS file only to open it in tsMuxeR and remove NTFS limitations
Or edit MPLS file to remove angle information and map SSIF with correct files Last edited by Nico8583; 1st February 2014 at 12:00. |
1st February 2014, 13:22 | #1943 | Link |
PgcEdit daemon
AFAIK, no, but jdobbs suggested to write it.
1st February 2014, 15:45 | #1945 | Link | ||
PgcEdit daemon
I don't understand.
IMO, the problem is due to the lack of an output file name for tsMuxeR. It can demux properly, but it cannot create the files with the (sometimes very) long file names it generates automatically, when there are too many SSIF files. There are several ways to solve that problem, including the remux to a temp file, or using eac3to. But unfortunately, all methods, except the "+", need to write a lot of data on disc, and are therefore slow. It's why I have implemented the "+" method when it's possible. The only method that may work faster than the remux or eac3to is your idea: with a new, mono-angle MPLF file, it should be possible to generate the output file with a short file name. But for that method to work, it is necessary to write that new MPLS in the BD folder BDMV/PLAYLIST. Most of the times, that folder is read only, and you have to copy all BD files (or at least some of them) to your HDD. It's again a waste of time and disc space. It's why I have chosen the eac3to solution. It's a second demux pass, but IMO, it's the fastest of the 3 solutions, and it is reliable. Of course, I would prefer a modification of eac3to to support an output file name. I hope it will be implemented some day. In the meantime, the eac3to solution is sufficient IMO, given the fact that there are very few multi-angle MPLS referencing too many SSIFs. In fact, I don't think there is a single 3D BD having that problem currently available. So I wouldn't worry too much.
1st February 2014, 16:10 | #1946 | Link |
jdobbs suggests a tool to edit an MPLS file, but the best would be to create a new MPLS file (or remove angle information rom existing MPLS) for each angle in order to replace "+" method, so we could use this with infinity SSIF files.
Yes "+" method works perfectly but it can't be used with too many files, and remux to a temp file need time and space so no interest, we are allright. Why new MPLS needs to be write in BD folder and not to a temp folder ? Is it impossible to specify files path ? |
1st February 2014, 16:18 | #1947 | Link |
PgcEdit daemon
Yes. In the MPLS, you can only specify the number of the SSIF (or M2TS) files to include, not their full path. And tsMuxeR finds the containing folder relatively to the path of the MPLS file. In other words, it must be in the PLAYLIST directory of the BD. Pity. It's why I prefer the eac3to method.
1st February 2014, 16:50 | #1948 | Link |
OK I believed full paths could be indicated, sorry, so I'm agree with your solutions to have a full working demux :
- Add output filename to tsMuxeR - Add angle detection feature to tsMuxeR Last edited by Nico8583; 1st February 2014 at 16:53. |
2nd February 2014, 14:47 | #1949 | Link |
I've perhaps found an tip to use a modified playlist with an ISO or BD :
- Create a folder (ex : D:\BD\) - Create in this folder another folder named PLAYLIST (ex : D:\BD\PLAYLIST) - Create a symbolic link to STREAM folder on ISO (ex : mklink D:\BD\PLAYLIST H:\BDMV\STREAM) - Works only with NTFS file system if I'm not wrong - Copy or create a MPLS into D:\BD\PLAYLIST and open it in tsMuxeR. It works for me with an original MPLS, so it would be good to try with a modified playlist and no need to copy all files to HDD from an ISO or BD Edit : Symbolic link appears in Windows like a classic shortcut, so delete it will delete the symbolic link without delete data. Last edited by Nico8583; 2nd February 2014 at 14:49. |
2nd February 2014, 15:55 | #1950 | Link |
PgcEdit daemon
Nice idea. :-) I'll test it. If it works fine, that could make the CLI tool proposed by jdobbs very interesting.
2nd February 2014, 16:05 | #1951 | Link | |
2nd February 2014, 16:13 | #1952 | Link | |
I've tried, if disc is removed you've got an error message to tell you "Drive is not ready" when you try to open symbolic link but it is allways existent. |
2nd February 2014, 16:19 | #1953 | Link |
PgcEdit daemon
I guess you can simply delete the whole folder. The links will be deleted as well, and nothing wrong should happen.
AFAIK, there is only a strange thing with links: most tools that print the total file size of a directory containing soft or hard links count the space occupied by the real file instead of just the link, and therefore you can end up with strange results like more space occupied by the files on a disc than the total capacity of the disc! That's strange, but it's caused by bugs or limitations of these tools, and that should not have any impact on the possibility to "customize" a BD using links.
2nd February 2014, 17:31 | #1954 | Link | |
2nd February 2014, 18:41 | #1956 | Link | |
It my not even be worth the trouble. When physic returns I'm sure he'll provide the ability to select alternate angles anyhow. I would think it to be a fairly simple change, so it's all academic. Last edited by jdobbs; 2nd February 2014 at 19:18. |
2nd February 2014, 19:39 | #1957 | Link |
Yes I'm agree with you but I believed you wanted to create a symbolic link to BDMV folder or parent folder. If a symbolic link point to BDMV it's not possible to edit any files under this folder, but if link goes to STREAM folder yes it's possible
3rd February 2014, 07:50 | #1958 | Link |
OK, I'm at a loss and need some help here...
As people who've seen my posts on Neuron2's thread will know, I'm having an issue with extracting from some original discs. Not all of them - just 2 for now - but that's enough to be annoying. All I've been able to do with my own experiments is to make things worse, so I'm hoping that someone can find what I'm doing wrong, slap me across the back of the head and point me in the right direction. Steps I've tried:
I've even tried uninstalling and re-installing AnyDVD, as well as uninstalling and reinstalling my ODD drivers - none of it helps. All of these lead to the same results with Pacific Rim: around frame 95,000 about a second of video goes missing with an obvious visual artefact. This occurs a few more times between there and the end of the film, shortening it by a good 6 or so seconds. About the only thing I can think of is Win8.1, but that doesn't make sense as PowerDVD can play back the movies happily under the same OS. Help? |
3rd February 2014, 10:02 | #1960 | Link |
PgcEdit daemon
What have you used to transcode? I suppose it's DGMVCDecode, right? Have you tried also FRIMSource?
If FRIMSource fails too, that means that the problem is in the disc, in the Intel Media library, or in AnyDVD. Otherwise, it's a bug in DGMVCSource. If FRIMSource fails also, try DirectShowMVCSource, as sef recommends. It has some decoding bugs (only with some movies), but afaik not the one you have described. Also, I guess you encode the MPLS directly from the original BD through AnyDVD. Have you tried to rip the BD to the HDD as an ISO, then mount that ISO and decode it? Maybe you have had a timeout problem due to the slow medium. Also, with a mounted ISO, you can verify if it has been correctly ripped to HDD by playing the movie with PowerDVD (but without AnyDVD). If it's not the case, try ripping it to ISO with another method.
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 3rd February 2014 at 10:06. |
