24th August 2009, 17:27 | #9242 | Link | |
Anyway, I've just been testing eac3to with libFLAC 1.2.1 and I'm not getting any significant filesize differences. I've tried three different movie soundtracks, all 5.1, one 16 bit and two 24 bit. I wonder what's different about your test files, raquete and tebasuna51, that produces such dramatic differences? I'm going to stick with 1.2.1 for the time being anyway and I'll report back if I hit any problems. |
24th August 2009, 18:10 | #9243 | Link | |
libFLAC 1.2.0 -> 172426732 bytes (ratio 78.6%) libFLAC 1.2.1 -> 148297157 bytes (ratio 67.6%)
24th August 2009, 20:20 | #9244 | Link | |
http://forum.doom9.org/showpost.php?...5&postcount=12 now after change to libFLAC 1.2.1 the results are equals. later i will post the result of wave source 5.1 24b/96k with 1:08:00:928 with the "old" and with the "new" libFLAC in eac3to...i still don't know the wave file size, are in seperateds channels(L,R,C...etc) and i need to join(encode) as multichannel. |
25th August 2009, 00:20 | #9245 | Link |
crazy pc, crazy flac, crazy world and now the user is crazy too.
7.050.129.452 source wave 5.1 24b/96K (time 01:08:00) eac3to: 3.752.647.704 old libflac (07/22/2007) Code:
eac3to v3.16 command line: eac3to 01Wave.wav 01Wave.flac ----------------------------------------------------- ------------------------- WAV, 5.1 channels, 1:08:00, 24 bits, 13824kbps, 96khz Reading WAV... Encoding FLAC with libFlac... Creating file "01Wave.flac"... The original audio track has a constant bit depth of 24 bits. eac3to processing took 31 minutes, 33 seconds. Done. Code:
eac3to v3.16 command line: eac3to 01Wave.wav 01Wave.flac ----------------------------------------------------- ------------------------- WAV, 5.1 channels, 1:08:00, 24 bits, 13824kbps, 96khz Reading WAV... Encoding FLAC with libFlac... Creating file "01Wave.flac"... The original audio track has a constant bit depth of 24 bits. eac3to processing took 31 minutes, 24 seconds. Done. but have errors. opening as RaWavesource: Code:
Starting job 01wave.wav->01wave.flac Error: BeHappy.AviSynthException: Script error: there is no function named "RaWavSource" em BeHappy.AviSynthClip..ctor(String func, String arg, AviSynthColorspace forceColorspace, AviSynthScriptEnvironment env) em BeHappy.Encoder.encode() openinig as WavSource error too, run in less than 5 minutes, file size is short but was encoded only 26:34.422(time in minutes) and i did twice, just the same. Code:
Starting job 01wave.wav->01wave.flac Found Audio Stream Channels=6, BitsPerSample=24 int, SampleRate=96000Hz encoder\flac.exe --force -o "H:\eac3to\01wave.flac" --silent --force-raw-format --endian=little --channels=6 --bps=24 --sample-rate=96000 --sign=signed - Writing PCM data to encoder's StdIn Finalizing encoder Complete Last edited by raquete; 25th August 2009 at 00:34. Reason: phrases inside code space was too large. |
25th August 2009, 01:06 | #9246 | Link |
kypec,
sorry, I 've read it but somehow I've mixed it in my mind with some other previous posts. I've already deleted that post because is completelly nonsense. By the way, thanks for your findings. I will also try with new libflac, maybe I can gain some extra space on my backups. |
25th August 2009, 01:48 | #9247 | Link | |
2) RaWavSource function is in NicAudio.dll v2.0. Downnload (see my signature) and put in AviSynth plugins folder
25th August 2009, 03:22 | #9249 | Link | ||
in few hours new result. Quote:
i really don't like. don't happens with your encodes? Last edited by raquete; 25th August 2009 at 03:24. |
25th August 2009, 04:13 | #9250 | Link | |
Unavailable
http://www.true-audio.com/
Are you sure you weren't using the «lossy» compression mode ? Also, if the answer is "yes", are you sure the sound editors you used were decompressing the lossless .WV files correctly??? Last edited by Midzuki; 25th August 2009 at 15:12. Reason: fix typo |
25th August 2009, 05:20 | #9251 | Link | |
first, thanks for the link. i really don't know TTA and need to read about this format. WV lossy? i don't knew that one lossless compression can be "lossy". adjusted "lossless(high)" to encode (no hibrid) 32 bit float and adobe audition to open and check WV. example from audition waveform statistics (selected one channel where have one clip): Code:
Mono Min Sample Value: 21785 Max Sample Value: 32767 Peak Amplitude: -13.87 dB Possibly Clipped: 1 DC Offset: 79.736 Minimum RMS Power: 996.99 dB Maximum RMS Power: -inf dB Average RMS Power: -3.01 dB Total RMS Power: -18.65 dB Actual Bit Depth: 16 Bits Using RMS Window of 50 ms |
25th August 2009, 05:22 | #9252 | Link |
tebasuna51,
after 8 minutes with ~60% of the file encoded i got this message: Error: System.IO.IOException: O pipe foi finalizado. Code:
Starting job 01wave.wav->01wave.flac Found Audio Stream Channels=6, BitsPerSample=24 int, SampleRate=96000Hz encoder\flac.exe --force -o "H:\eac3to\01wave.flac" --silent --force-raw-format --endian=little --channels=6 --bps=24 --sample-rate=96000 --sign=signed - Writing PCM data to encoder's StdIn Error: System.IO.IOException: O pipe foi finalizado. |
25th August 2009, 06:35 | #9253 | Link | |
User of free A/V tools
No, it's not undocumented. FLAC has very extensive support of tagging, look in the documentation, --help switch is your friend.
435 306 274 : 435 640 726 = 99.923%, the real difference is less than 0.1%, no big deal. |
25th August 2009, 13:06 | #9254 | Link | |
Maybe in next v1.2.2... See: http://sourceforge.net/tracker/index...78&atid=363478 http://sourceforge.net/tracker2/?fun...78&atid=113478 Until next flac.exe version you must use only eac3to if flac file output is >2GB. Edit: With an audio track tested don't exist many difference: 8032850564 Pulp.wav 3918536382 Pulp_120.flac 48.8% 3893160387 Pulp_121.flac 48.5%
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 25th August 2009 at 13:49. |
25th August 2009, 14:36 | #9255 | Link | ||
Unavailable
25th August 2009, 14:43 | #9256 | Link | |
thanks so much for the links, hints, suport, big patience and friendship. |
25th August 2009, 15:03 | #9257 | Link | ||
Unavailable
I don't use Adobe Audition, so I can just suppose it doesn't deal very well with 32-bit .WV files... BTW: Did you generate those 32-bit .WV archives from 32-bit sources --- or not ??? I mean: regardless of the possible bugs/imperfections of «WavPack.exe», I see no point in creating 32-bit .WV archives only because Adobe Audition is your favorite sound editor. Last edited by Midzuki; 25th August 2009 at 16:03. Reason: fix typo |
25th August 2009, 15:27 | #9258 | Link | |
audition always open as wave 32bit float but i don't remember if i generate those 32-bit WavPack archives from 32-bit sources ...i don't use WV no more after see that clips. sound forge show exactly the same clips as audition but audition is my favorite, have amazing differents features. i'm using now flacs or apes. flac is my preference. cheers! |
25th August 2009, 17:01 | #9259 | Link |
I've tested with Baraka, the biggest movie audio file I have, 5.1 96kHz 24bit.
wav : 9,452,814,404 1.2.0: 5,279,451,099 (55.85%) 1.2.1: 5,247,885,754 (55.51%) That's not a very big difference. I'm not sure it's worth the effort to reencode all my backups with 1.2.1, I think I will only use it with the new ones... |
25th August 2009, 21:30 | #9260 | Link | |
I just included one of that tags manually in order to obtain one FLAC file as closely similar to another one as possible for testing purposes. |
eac3to |
