9th March 2009, 09:03 | #8501 | Link | ||
Then just use AC3 encoding instead, which doesn't need any external software. Argh, thanks. One of the bug fixes fired back. |
9th March 2009, 09:41 | #8502 | Link | |
That is expected behaviour due to dithering. test3.wav is 32bit which (AFAIK) the current libFlac encoder does not support. So eac3to has to dither down to 24bit. |
9th March 2009, 09:42 | #8503 | Link |
eac3to v3.14 released
http://madshi.net/eac3to.zip Code:
* WAV reading was broken for all but very small files (introduced in v3.13) |
9th March 2009, 12:04 | #8504 | Link |
does the case that gaps/overlaps of seamless branching do not exist any more apply to all kind of audio tracks? Im sure for flac, as flac framelength is only 1ms, but does this also apply to the other formats? would a DTS track created from a seamless branching movie have more gaps or overlaps in between as a flac track created out of the same movie?
9th March 2009, 16:11 | #8505 | Link | ||
9th March 2009, 20:27 | #8507 | Link | |
Aging Video Hobbyist
DGVC1IndexFileNV2 D:\mamma mia clip\snip.m2ts C:\Program Files (x86)\DGVC1DecNV\ STREAM 1 PKTSIZ 192 VPID 4113 FO 2 YUVRGB 1 LUMFILT 0 0 CLIP 0 0 0 0 RANGE 0 0 20971519 30000 AUDIO 1100 SEQ 798 INTERLACE PULLDOWN ENTRY 820 !BROKEN CLOSED FRM I FRAME FRM I FRAME FRM B FRAME FRM B FRAME FRM I FRAME FRM B FRAME FRM B FRAME FRM I FRAME FRM B FRAME FRM B FRAME FRM I FRAME FRM B FRAME FRM B FRAME FRM I FRAME FRM B FRAME FRM B FRAME FRM I FRAME FRM B FRAME FRM B FRAME FRM I FRAME FRM B FRAME FRM B FRAME FRM I FRAME FRM B FRAME FRM B FRAME FRM I FRAME FRM B FRAME FRM B FRAME FRM I FRAME FRM B FRAME SEQ 224478 INTERLACE PULLDOWN ENTRY 224500 !BROKEN !CLOSED FRM I FRAME FRM B FRAME FRM B FRAME FRM I FRAME FRM B FRAME FRM B FRAME FRM I FRAME FRM B FRAME FRM B FRAME FRM I FRAME FRM B FRAME FRM B FRAME FRM I FRAME FRM B FRAME FRM B FRAME FRM I FRAME FRM B FRAME FRM B FRAME FRM I FRAME FRM B FRAME FRM B FRAME FRM I FRAME FRM B FRAME FRM B FRAME FRM I FRAME FRM B FRAME FRM B FRAME FRM I FRAME FRM B FRAME FRM B FRAME SEQ 603294 INTERLACE PULLDOWN ENTRY 603316 !BROKEN !CLOSED FRM I FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD SEQ 1121694 INTERLACE PULLDOWN ENTRY 1121716 !BROKEN !CLOSED FRM I FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD SEQ 1864542 INTERLACE PULLDOWN ENTRY 1864564 !BROKEN !CLOSED FRM I FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD SEQ 2636766 INTERLACE PULLDOWN ENTRY 2636788 !BROKEN !CLOSED FRM I FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM I FIELD FRM B FIELD FRM B FIELD FRM I FIELD FRM B FIELD FRM B FIELD FRM I FIELD FRM BI FIELD FRM BI FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD SEQ 5919774 INTERLACE PULLDOWN ENTRY 5919796 !BROKEN !CLOSED FRM I FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD SEQ 9033054 INTERLACE PULLDOWN ENTRY 9033076 !BROKEN !CLOSED FRM I FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM P FIELD FRM P FIELD FRM P FIELD SEQ 11802654 INTERLACE PULLDOWN ENTRY 11802676 !BROKEN !CLOSED FRM I FIELD FRM P FIELD FRM P FIELD FRM P FIELD FRM P FIELD FRM P FIELD FRM P FIELD FRM P FIELD FRM BI FIELD FRM P FIELD FRM P FIELD FRM P FIELD FRM P FIELD FRM P FIELD FRM P FRAME FRM P FRAME FRM B FRAME FRM B FRAME FRM P FRAME FRM B FRAME FRM B FRAME FRM P FRAME FRM B FRAME FRM B FRAME FRM P FRAME FRM B FRAME FRM B FRAME FRM P FRAME FRM B FRAME FRM B FRAME SEQ 15010974 INTERLACE PULLDOWN ENTRY 15010996 !BROKEN !CLOSED FRM I FRAME FRM B FRAME FRM B FRAME FRM P FRAME FRM B FRAME FRM B FRAME FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM P FIELD FRM P FIELD FRM P FIELD FRM P FIELD FRM P FIELD FRM P FIELD FRM I FIELD FRM BI FIELD FRM P FIELD FRM P FIELD FRM P FIELD FRM P FIELD FRM P FIELD FRM P FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD SEQ 17703774 INTERLACE PULLDOWN ENTRY 17703796 !BROKEN !CLOSED FRM I FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD SEQ 19860702 INTERLACE PULLDOWN ENTRY 19860724 !BROKEN !CLOSED FRM I FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD SEQ 20299038 INTERLACE PULLDOWN ENTRY 20299060 !BROKEN !CLOSED FRM I FIELD FRM B FIELD FRM B FIELD FRM P FIELD FRM B FIELD FRM B FIELD FRM P FIELD SIZ 1920 x 1080 FPS 30000 / 1001 CODED 274 PLAYBACK 274 Given though that eac3to is "step 1" for any manipulation effort, it would be useful I think if it were to ID these as a mix of interlaced & progressive, if possible (that's where I'd hoped your field/frame count might be way to tell). |
10th March 2009, 01:46 | #8511 | Link | |
Chumbo |
10th March 2009, 08:13 | #8512 | Link | |
I assume that eac3to CLI can handle your files ? |
10th March 2009, 09:07 | #8513 | Link | |
@mrr19121970
Hi! Thanks for getting back to me. Quote:
Like you, based on the information in post #1 of this thread, I also presume that it can handle MKV as input. Any further insight that you can provide will be greatly appreciated. |
10th March 2009, 14:28 | #8515 | Link |
Changed it now. 52k views on the Slysoft forum, and nobody noticed it. @setarip_old like I said, I've no way to test it. you need to try the CLI version: "c:\yourpathto\eac3to.exe" "C:\your.mkv" -demux
Blu-Ray Movie Only Copies : Clown_BD Blu-Ray Movie Only DVD Conversion : Clown_BD Blu-Ray Copies With Menus : Clown_BD BD Copier Last edited by mrr19121970; 10th March 2009 at 14:36. |
10th March 2009, 19:11 | #8517 | Link | |
If the underlying programs cannot handle a particular (for whatever reason) then you need to show logs so that the author can address the issue. |
10th March 2009, 19:55 | #8518 | Link |
Kid for Today
guys, I got a pretty annoying problem....hopefully someone will have an idea
I've got the german Revolver BD, w/ the english track in DTS HD MA....I've tried to extract the core w/ eac3to and I get quite a lot of static in different places(not loud ones, so it's not saturation ) w/ the extracted DTS core, the static is worse in Sonic 4.2 than in AC3filter, I've tried to play the DTSHD file w/ Sonic 4.2 : it's full of glitches but it seems that the static is still there.. a friend of mine tried to play the track in Arcsoft and the static was still there, I guess that's the only way to play DTS HD in its full glory on PC ? I've read that Sonic 4.3 should also play it, but I've never managed to make it open DTS...does it really play DTS HD ? either there's some DRC or whatever that's saturating the audio, or the guys at the mastering studio didn't notice that the english track was full of static before encoding it Last edited by leeperry; 10th March 2009 at 20:21. |
10th March 2009, 21:37 | #8519 | Link | |
@leeperry
Hi! Quote:
10th March 2009, 21:48 | #8520 | Link | |
Kid for Today
only Arcsoft can decode DTSHD fully, as I understand it? I guess I'm SOL, too bad this happens on my favorite movie I wish I could somehow decode it to FLAC w/o the glitches Last edited by leeperry; 10th March 2009 at 21:59. |
eac3to |
