24th April 2004, 00:41 | #101 | Link |
Born to Rip
I've had some problems creating the DVD with Scenarist since I switched from ReAuthorist to ScenAid. On two different DVD's I've had overlapping subtitles, causing Scenarist to choke. Unfortunately I haven't been able to recreate the exact error because when I repeat the steps the problem seems to correct itself.
--SmokesLikeaPoet When wrestling alligators the gator only has to win once. Read my Adventures In HDTV Capture Blog. |
25th April 2004, 17:59 | #103 | Link |
ScenAid
Not currently there isn't but you should be able to get there... site is up as far as I can tell
http://sceneaid.com |
25th April 2004, 19:16 | #104 | Link |
i have some problem at Exporting a DVD in Scenarist.
the original dvd has dublicated VOBID, but i have demuxed WITHOUT VOBID. Makeing a Script with ScenAid .5 works fine. Importing also no problems. Only exporting results in a problem: here the log: Error Subpicture[1] (1:VTS_03_VSUB_P5A1-00-F-Eng_136.sp) and (2:VTS_03_VSUB_P5A1-00-F-Eng_137.sp) offset are overlapped (00:00:00;00-00:00:01;04) and (00:00:00;00-00:00:03;02) Error dvd_mux : Open Mux_list File Error Error Terminated Multiplexing (BONUS-VTS03P05_t.vob). Error Wrong mux_list. Mux_list format or stream ID may be wrong. Error Multiplex is failed. Error Multiplexing failed, Track "VTS03P05" Error MuxFromDB:MuxVTS failed Error Multiplex failed Error DVD Video files could not be created makeing a Script with the preBeta .6 i had found at the German Doom9 Forum results in more subtile problems. so what can I do? |
25th April 2004, 21:18 | #105 | Link | |
any word on the new update yet? |
27th April 2004, 05:18 | #107 | Link | |
The Eldest One
After 39 hours (no I'm not kidding 39) it just stoped responding. It was started minimized by DoItFast4U! so I cannot see the error message (which happens when started minimized and for some reason it crashes), but the log doesn't give a clue at all. Has anyone got a clue about this? Either the huge amount of time it took and the reason it fails with this title? Thank you
[b][i]Lazarus[i][b] Last edited by Lazarus Long; 27th April 2004 at 05:20. |
29th April 2004, 12:45 | #108 | Link |
Germanicus
servus...
Can Scenaid 0.9.0.5 handle forced subtitle? I made KillBill VOl. 1 RC2 with it. No errors while rebuilding. but in the player, nothing works like it should. no forced subtitle. Or is IfoUpdate responsible for forced subtitle? Edit: Just checked the scenarist project. the two streams with forced subtitles are inside. but not selected as forced subtitle. I mean it isnīt a problem to select them afterwards with ifoedit or in scenarist, if you have a forced subtitle stream only. But what if you have the forced subtitle inside a normal subtitle stream? Is it possible to set this in the script automatic?
cya fourtyfour Last edited by fourtyfour; 29th April 2004 at 13:00. |
29th April 2004, 15:55 | #109 | Link |
ScenAid
fourty : where you checking to see if it's forced or not?
Forced display is set in the "Data" tab and set PER .bmp. Yes it should be detecting and labeling forced subs. Check if there is in the subs demux directory not only a .sst but also a -forced.sst file - If not then that's why it's not showing them forced |
29th April 2004, 17:44 | #110 | Link |
Germanicus
servus...
Weird. There are no forced subtitle neither in the sub folder nor if I look into the original ifo files. But somehow, this subtitles (english and german stream) are forced, as I can see on standalone player (original DVD) and PowerDVD (mounted Image) My created image has the same problems as the testdvd, so it isnīt a dvd player problem. Iīm doing some testing with subrip and this subtitles then Iīll see whatīs going on. About the Forced Flag Iīm using the simulation window for looking after the forced flag. Itīs actually the same as you wrote above. Actually, I donīt know how I can set 2 forced subtitles (eng for eng menu) (ger for ger menu). First, I have to learn more about the structure of this movie and how forced subtitles are working without setting flags I think itīs something about choosing language x, the menu is setting forced subtitle xx as well. But Iīll see and let you know if I find a solution. If you can give me a hint I appreciate it
cya fourtyfour |
29th April 2004, 19:16 | #111 | Link |
Wewkiee
i can only speak for r1.there are no forced subs
that one has a translation stream (x20W,x21L) that only has english subs where they speak japanese in the film. and that is it. its not forced. although it is default on, it is not Forced then x22WL is the regular english track which includes the translated parts. x23WL+ are japanese, trad chinese, korean, french, spanish (not in that order) the japanese spoken parts (except in the japanese sub track of course) are translated to the according language.
...yeah...but...why on earth would I compare apples with apples? |
30th April 2004, 17:25 | #112 | Link |
Germanicus
servus...
I agree, I canīt find any details about forced subtitle. I think itīs made with a pre-command like: If stream A selected, the always play "subtitle 6" . Otherwise it would be a wonder why I got this "forced" subtitles
cya fourtyfour |
1st May 2004, 18:41 | #114 | Link |
Germanicus
servus...
I made the whole movie with original menu. neither dts detection nor "forced" subtitle are making problems. Everything works like it should I guess, itīs all a problem of NuMenu4U, not for Scenaid.
cya fourtyfour |
2nd May 2004, 11:06 | #116 | Link |
Scenarist crashes (Scenarist shuts down), when I try to import a ScenAid script. It is a multi angles movie so it is demuxed by vobid.
It crashes when Scenarist tries to import the tracks with the multi angles. The last line I see is Code:
Info Importing VTS01_V1_C1-a3 It is so for the last two multi angles dvds. The assets are Ok, as I made then the first multi angles dvd manually. P.S.: Where can I find some Info, how to create the scenarist script ? I found nothing in the scenarist docu.
Only for Germans: <<- Big3 Anleitungen ->> <<- Alles zu DVD2SVCD ->> <<- AviSynth.org auf Deutsch ->> |
2nd May 2004, 13:39 | #117 | Link | ||
ScenAid
The basic script layout is fairly simple but it's these kinds of issues that makes it a little more difficult |
14th May 2004, 07:26 | #119 | Link | |
15th May 2004, 23:33 | #120 | Link |
Success with Independence Day R4
I have been following the development of ScenAid for a while and would like to report successful backup of Independence Day R4, PAL Special Edition (Ripped by VOBID using DIF4U 1.4.7, DoCCE4U, CCE 2.6.7 Trial, Scenaid 0.9.5, and Scenarist 2.6) keeping everything (Special + Theatrical versions, all 3 sound tracks and all subtitle). The main movie was compressed at 3Mb/s. And it looks great on my projection screen. No obvious problem that I can detect. Subs works perfectly. I am very happy!. Keep up the good work all you guys.
