#1501 | Link | |
2. Create a separate topic for your problem. Examples: one and two. 3. Describe your problem in as much detail as possible, specify the exact version numbers of the instruments. 4. Upload the necessary files (scripts and video files) to a file sharing service so that other people can reproduce your problem on their PC.
MPC-BE 1.8.3 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource Last edited by v0lt; 17th December 2024 at 15:55. |
#1502 | Link |
Newbee
Cheers!
![]() I've started a new thread to describe my issue here: https://forum.doom9.org/showthread.p...95#post2011695 |
#1503 | Link |
In version 667 I have a problem with the folder path in the Deshaker v3.1 plugin. I always have to fill it in, and previously I left it empty (in version 44282) and the plugin found the file in the current project directory.
#1504 | Link | |
What is the current project directory?
MPC-BE 1.8.3 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
#1505 | Link |
1. Filter data file (default Deshaker.log).
2. Folder with .vdproject file. I load the project to 44282 -- I can leave the field empty, the plugin uses the current folder. I load the same project to 667 -- I have to fill in the field with the full path (I don't know where it looks for it then, but not in the project path).. Last edited by rgr; 2nd January 2025 at 13:36. |
#1507 | Link | |
Perhaps your video is Variable FrameRate, and VD2 converts to Constant FrameRate. Check FR with MediaInfo.
#1509 | Link | |
But if you first open any video file in this folder, and then drop the project file, the filter will find Deshaker.log. And this does not depend on the VD2 version.
#1510 | Link |
Same way everything else does, insert dupes where timestamps have gaps.
#1512 | Link | |
Not exactly. For timecode VFR, frames can display for different durations in a media player. Functionally VFR is similar to inserted duplicates. The difference is no actual frames are being inserted For CFR equivalent, you are going to have "physically" inserted duplicates. That' s going to be a lot worse compression wise. Think of your apng scenario with 41465 frames is going to consume significantly more disk space than 33765 frames |
#1513 | Link |
Acid fr0g
Would be possible to include nvenc in some way? Some filters unfortunately exists for VirtualDub only and I’d like to create a HEVC lossless mezzanine file for further processing.
@turment on Telegram |
#1518 | Link |
Life's clearer in 4K UHD
Personally, I would round up to 854.
#1520 | Link |
![]() Join Date: Feb 2005
Right click over the image and select the aspect ratio desired.
If you have a correct source DVD (VOB file) VirtualDub2 select the correct aspect ratio for you, see the image. Maybe for your source you need select the aspect ratio manually. |
