Old 6th August 2024, 12:05   #1341  |  Link
jay123210599
Originally Posted by v0lt View Post
Many SDR rips do not have colorimetry data. This is a problem because players and video editors have to guess from the frame size, which can be wrong.
It's a 1080p Blu-Ray remux, so what do I do to fix it?
jay123210599 is offline   Reply With Quote
Old 6th August 2024, 13:15   #1342  |  Link
LigH
LigH's Avatar
Depends on your goal and your methods...
Avisynth has functions to convert between YUV and RGB with different matrices. So at least you could use that to test which conversion matrix fits your needs. And then ... well, maybe a special tool can patch the video stream to add colorimetry metadata.
But that is already way beyond the purpose of VirtualDub2.
New German Gleitz board
Old 6th August 2024, 14:33   #1343  |  Link
v0lt
I don't have your file (or a small sample), so I can't say anything.
I have a BD with this information:
General
Complete name                  : ...\BDMV\STREAM\00011.m2ts
Format                         : BDAV
Format/Info                    : Blu-ray Video
File size                      : 606 MiB
Duration                       : 2 min 42 s
Overall bit rate mode          : Variable
Overall bit rate               : 31.3 Mb/s
Maximum Overall bit rate       : 48.0 Mb/s
Frame rate                     : 29.970 FPS
Video
Menu ID                        : 1 (0x1)
Format                         : AVC
Format/Info                    : Advanced Video Codec
Format profile                 : High@L4.1
Format settings                : CABAC / 4 Ref Frames
Format settings, CABAC         : Yes
Format settings, Reference fra : 4 frames
Format settings, Slice count   : 4 slices per frame
Codec ID                       : 27
Bit rate mode                  : Variable
Maximum bit rate               : 36.0 Mb/s
Width                          : 1 920 pixels
Height                         : 1 080 pixels
Display aspect ratio           : 16:9
Frame rate                     : 29.970 (30000/1001) FPS
Standard                       : NTSC
Color space                    : YUV
Chroma subsampling             : 4:2:0
Bit depth                      : 8 bits
Scan type                      : MBAFF
Scan type, store method        : Interleaved fields
Scan order                     : Top Field First
Color range                    : Limited
Color primaries                : BT.709
Transfer characteristics       : BT.709
Matrix coefficients            : BT.709
Audio
All the necessary data is present: Color range, Color primaries, Transfer characteristics, Matrix coefficients.
v0lt is offline   Reply With Quote
Old 6th August 2024, 14:48   #1344  |  Link
jay123210599
General
Format                         : BDAV
File size                      : 606 MiB
Video
Menu ID                        : 1 (0x1)
Format                         : AVC
Codec ID                       : 27
Standard                       : NTSC
Color space                    : YUV
Bit depth                      : 8 bits
Scan type                      : MBAFF
Audio
Here's a sample.
https://mega.nz/file/cFZUUBqA#W5zPah...2NRObIy3nIqlLM
Old 6th August 2024, 15:33   #1345  |  Link
v0lt
Method of correcting parameters for BT.709:
ffmpeg -i "Blu-Ray Remux Sample.mkv" -map 0 -c copy -bsf:v h264_metadata=colour_primaries=1:transfer_characteristics=1:matrix_coefficients=1 "Blu-Ray Remux Sample_fix.mkv"
Old 6th August 2024, 16:49   #1346  |  Link
jay123210599
It worked! Now how do I do this in VirtualDub2?
Also, another problem that the both and new samples produced this glitched image. How do I fix that?
https://imgur.com/a/7YJsTUX
Old 6th August 2024, 17:56   #1347  |  Link
v0lt
There is no such functionality. You want too much from VirtualDub and do not understand for what purposes it was made.
Old 6th August 2024, 18:01   #1348  |  Link
poisondeathray
When video is unflagged, vdub2 assumes Rec 601 for the RGB conversion. Usually this will be wrong for most HD video
A workaround in vdub2 would be, video => filters => alias format => color space Rec.709
Old 6th August 2024, 18:03   #1349  |  Link
rgr
Why so? In VDub in Video->Decode Format you can change from 601 to 709. Even set 709 as default.
rgr is offline   Reply With Quote
Old 6th August 2024, 18:16   #1350  |  Link
jay123210599
Both solutions worked, but what about my other problem with the faulty image?
Old 6th August 2024, 18:17   #1351  |  Link
poisondeathray
Yes decode format works and is a better workaround
Old 6th August 2024, 18:23   #1352  |  Link
poisondeathray
I don't see the faulty image in vdub2 with your sample video. How did you produce the problem ?
Old 6th August 2024, 21:56   #1353  |  Link
jay123210599
Never mind, I went the program again and it didn't show up, must have had to restart the tool.
Old 7th August 2024, 16:11   #1354  |  Link
jay123210599
Is there a filter for VirtualDub2 that allows you to burn in PGS (.sup) subtitles?
Old 7th August 2024, 16:14   #1355  |  Link
LigH
LigH's Avatar
There is one for AviSynth: SupTitle
Old 7th August 2024, 18:03   #1356  |  Link
jay123210599
Unflagged video? What does that mean?
Old 7th August 2024, 18:29   #1357  |  Link
LigH
LigH's Avatar
"Unflagged" = The video stream contains no set of bits (= bitflag) describing some of its attributes, here its colorimetry.
Old 7th August 2024, 22:07   #1358  |  Link
jay123210599
I want to use ffmpeg as an external encoder to extract frames and make image sequences, and also burn in subtitles. How do I do that while replacing it with the default encoder?
Old 8th August 2024, 04:22   #1359  |  Link
v0lt
I want to use ffmpeg as an external encoder...
Options > External encoders...
after you have everything set up
File > Export > Use external encoder...
Old 8th August 2024, 05:23   #1360  |  Link
jay123210599
and the rest of the my question? to extract frames and make image sequences, and also burn in subtitles?
