Old 7th June 2009, 18:17   #21  |  Link
SEt
Problem solved. Thanks to Dark Shikari for kicking me to actually go see performance counters and IanB for idea what can help.
Placing earlier
mov	al, byte ptr [edi+pitch*1-8]
changed nothing, but gave me idea that worked - i moved problem loads before write of previous iteration. A few more optimizations and new code works as fast as old one and sometimes even a bit faster. Will post it later when other things are done.
IanB, i started to use pitch*? instead of registers because included source had no register for pitch*1.
SEt is offline   Reply With Quote
Old 14th June 2009, 20:11   #22  |  Link
Chainmax
Huh?
Chainmax's Avatar
This is awesome, one of my favorite plugins to use on animated content finally updated and bug-free! Thank you so much, SEt .
One question: in order to achieve the same effects as aWarpSharp(depth=16,cm=1) in MarcFD's original one would have to use aWarpSharp(depth=16,chroma=4) on your version, right?
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it.
Chainmax is offline   Reply With Quote
Old 15th June 2009, 10:22   #23  |  Link
SEt
Yes, and both are defaults btw.
It's not bug free yet - as described here it uses incorrect position in edge map. Next version will be correct one.
I'm interested in usefulness of bm=0/1/2 parameter (choice of internal blur type for edge map) - is it really needed now when you can use external one? There are probably enough blurs for AviSynth already.
Old 17th June 2009, 17:00   #24  |  Link
sh0dan
Retired AviSynth Dev ;)
sh0dan's Avatar
Originally Posted by Dark Shikari View Post
movd	eax, xmm2
				psrldq	xmm2, 4
				pinsrw	xmm3, [eax+esi], 0
				pinsrw	xmm4, [eax+edx], 0
				movd	eax, xmm2
				psrldq	xmm2, 4
				pinsrw	xmm3, [eax+esi+1], 1
				pinsrw	xmm4, [eax+edx+1], 1
				movd	eax, xmm2
				psrldq	xmm2, 4
				pinsrw	xmm3, [eax+esi+2], 2
				pinsrw	xmm4, [eax+edx+2], 2
				movd	eax, xmm2
				pinsrw	xmm3, [eax+esi+3], 3
				pinsrw	xmm4, [eax+edx+3], 3
				movd	eax, xmm7
				psrldq	xmm7, 4
				pinsrw	xmm3, [eax+esi+4], 4
				pinsrw	xmm4, [eax+edx+4], 4
				movd	eax, xmm7
				psrldq	xmm7, 4
				pinsrw	xmm3, [eax+esi+5], 5
				pinsrw	xmm4, [eax+edx+5], 5
				movd	eax, xmm7
				psrldq	xmm7, 4
				pinsrw	xmm3, [eax+esi+6], 6
				pinsrw	xmm4, [eax+edx+6], 6
				movd	eax, xmm7
				pinsrw	xmm3, [eax+esi+7], 7
				pinsrw	xmm4, [eax+edx+7], 7
				mov	eax, [esp]
I'm going to have to start killing kittens if I keep seeing things like this.
I completely agree - while this might seem fast, it isn't. Movd r32,xmm has a latency of 6 cycles on Core2, pinsrw has a latency of 4. Both are eons.
Store the content of xmm2 and xmm7 into memory, do lookups in scalar assembler and read them back:
				movdqa [temp1], xmm2   ; Store all pixels
				; push eax, ebx, ecs on the stack, if you use them already
				xor eax, eax
				xor ebx, ebx
				xor ecx, ecx
				mov ax,[temp1]
				mov bx,[eax+esi]
				mov cx,[eax+edi]
				mov [temp2], bx
				mov [temp3], cx
				mov ax,[temp1+2]
				mov bx,[eax+esi]
				mov cx,[eax+edi]
				mov [temp2+2], bx
				mov [temp3+2], cx
				(you get the picture -use a macro, for nice code)
				movdqa xmm3, [temp2]
				movdqa xmm4, [temp3]
This way you only get the performance hit of the cache lookups, and a Store->Load Forward size mismatch penalty. And for please, use palignr, it is much faster on Core2.
Regards, sh0dan // VoxPod
sh0dan is offline   Reply With Quote
Old 17th June 2009, 23:42   #25  |  Link
SEt
Your numbers seems too high even for Core2. According to http://www.agner.org/optimize/ tables movd has latency/throughput of 2/0.33 on both Core2 and pinsrw 6/1.5 on 65nm and 2/1 on 45nm. On my Nehalem Everest measures "MOVD r32, xmm+MOVD xmm, r32" to have latency 4, "PEXTRW + PINSRW r32" latency 1, movd throughput 0.4, pinsrw throughput 0.66.
For speed of this part it's actually the other way around - at the beginning i thought it to be painfully slow too, but profiler says it's quite fast. Changing even movd/psrldq into movdqa/mov [+0/4/8/12] gives me 10% speed drop for the whole function. Changing pinsrw would likely cost even more. Of course it's measured on Nehalem and not on Core2 that everyone seems to love for reason that's beyond me. Modern CPUs taught me to believe only profiler when optimizing and not what you think is faster, so i'm not going to write something that "maybe better for Core2" when i have no means of confirming it by testing there.
palignr is definitely great for some cases, but guess how much difference i measure between old unaligned hell of
movdqu	xmm6, [esi-6]
movdqu	xmm0, [esi+6]
pavgb	xmm6, xmm0
movdqu	xmm5, [esi-5]
movdqu	xmm7, [esi+5]
pavgb	xmm5, xmm7
movdqu	xmm4, [esi-4]
movdqu	xmm0, [esi+4]
pavgb	xmm4, xmm0
movdqu	xmm3, [esi-3]
movdqu	xmm7, [esi+3]
pavgb	xmm3, xmm7
movdqu	xmm2, [esi-2]
movdqu	xmm0, [esi+2]
pavgb	xmm2, xmm0
movdqu	xmm1, [esi-1]
movdqu	xmm7, [esi+1]
pavgb	xmm1, xmm7
movdqa	xmm0, [esi]
pavgb	xmm6, xmm5
pavgb	xmm4, xmm3
pavgb	xmm2, xmm1
pavgb	xmm6, xmm4
pavgb	xmm2, xmm0
pavgb	xmm6, xmm2
pavgb	xmm6, xmm2
movntdq	[esi+edi], xmm6
and new (to be released)
movdqa	xmm7, [esi+10h]
movdqa	xmm0, xmm6
movdqa	xmm2, xmm7
palignr	xmm0, xmm5, 10
palignr	xmm2, xmm6, 6
pavgb	xmm0, xmm2
movdqa	xmm3, xmm6
movdqa	xmm4, xmm7
palignr	xmm3, xmm5, 11
palignr	xmm4, xmm6, 5
pavgb	xmm3, xmm4
pavgb	xmm0, xmm3
movdqa	xmm1, xmm6
movdqa	xmm2, xmm7
palignr	xmm1, xmm5, 12
palignr	xmm2, xmm6, 4
pavgb	xmm1, xmm2
movdqa	xmm3, xmm6
movdqa	xmm4, xmm7
palignr	xmm3, xmm5, 13
palignr	xmm4, xmm6, 3
pavgb	xmm3, xmm4
pavgb	xmm1, xmm3
pavgb	xmm0, xmm1
movdqa	xmm1, xmm6
movdqa	xmm2, xmm7
palignr	xmm1, xmm5, 14
palignr	xmm2, xmm6, 2
pavgb	xmm1, xmm2
movdqa	xmm3, xmm6
movdqa	xmm4, xmm7
palignr	xmm3, xmm5, 15
palignr	xmm4, xmm6, 1
pavgb	xmm3, xmm4
pavgb	xmm1, xmm3
pavgb	xmm1, xmm6
movdqa	xmm5, xmm6
movdqa	xmm6, xmm7
pavgb	xmm0, xmm1
pavgb	xmm0, xmm1
movntdq	[esi+edi], xmm0
? The second version is only 10% faster (of course, on Nehalem again).
Old 17th June 2009, 23:50   #26  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Maybe because that's what they own? It will be years before the Nehalem has a higher install base than the Core 2.
Then ask someone for SSH access, there are billions of Core 2s.
Try running the first set of code when you're not on a cacheline, and the second set when you are, perhaps?
Old 18th June 2009, 00:23   #27  |  Link
SEt
I suspect there is higher install base for P4/D than Core2 now, but does it mean we should optimize primary for P4? If care for something else it would be Phenoms and i suspect them to behave similar to Nehalem, not Core2.
Good idea, but i'd rather spend my time now for more important stuff, like actually releasing something.
I'm not quite get your point here. I bench the code on real video processing. Also notice the 'movdqa' in the only memory load of second variant.
Old 18th June 2009, 00:37   #28  |  Link
Dark Shikari
x264 developer
People who care about video processing speed are not using Pentium 4s.
Why is it that I can release code optimized for multiple modern CPUs while you can't?
And? x264 performs "real video processing" and has separate code paths for when the loads fall across a cacheline.
Old 18th June 2009, 00:52   #29  |  Link
SEt
People who really care about video processing speed would use Nehalem.
It's a matter of preference. I think optimization is important, but comes behind the features. I'd love to see in next x264 option to be 2x slower but produce 5% better quality/smaller file size instead of even 10% overal speed up.
How can dq loads aligned on 16 bytes be across a cacheline?
Old 18th June 2009, 01:20   #30  |  Link
Dark Shikari
x264 developer
You said that your palignr-based code is only 10% faster.
What if it was 70% faster when on a cacheline, and 10% slower otherwise? This would average out to 10% faster overall.
In that case, you'd want to use the unaligned code when not on a cacheline, and the palignr code when on a cacheline.
Old 18th June 2009, 02:01   #31  |  Link
SEt
Ok, now i understand you. Profiled such case and it turned out that old and new code have exactly the same speed when not on a cacheline. So, those 10% are what palignr wins on cacheline split.
Old 18th June 2009, 02:11   #32  |  Link
Dark Shikari
x264 developer
By the way, the reason it's only 10% faster on Nehalem is because the Nehalem has only a 2-cycle penalty for cacheline splits.
The Core 2 Penryn has a ~12-14-cycle penalty, which will probably mean that SSSE3 code will go massively faster on Penryn; I'd guess at least 50% benefit.
Old 18th June 2009, 02:36   #33  |  Link
SEt
I know that much about my Nehalem. But would love to read something like http://www.agner.org/optimize/ about its microarchitecture and instruction timings (regrettably, information there is only up to Core2 now).
Old 18th June 2009, 02:47   #34  |  Link
Dark Shikari
x264 developer
Intel's latest optimization guide has Nehalem documentation, but not timings.
Mubench has mostly-accurate Nehalem timings.
Old 18th June 2009, 14:56   #35  |  Link
Gokumon
Posts: n/a
Because you get paid to work on x264 while SEt doesn't get paid to work on his aWarpSharp rewrite?
Old 19th June 2009, 21:15   #36  |  Link
SEt
Finally an update:
  • renamed main filter from aWarpSharp to aWarpSharp2 for less confusion with original aWarpSharp
  • fixed wrong offsets in Warp
  • added new blur type - produce better quality, but around 2.5x slower
  • blur will be more precise around frame borders if SSSE3 is available
  • some optimizations, mostly noticeable on Core2
  • removed support for undocumented parameters of original aWarpSharp
Old 19th June 2009, 21:18   #37  |  Link
Dark Shikari
x264 developer
I do? That's news to me, because I haven't gotten a check.
Old 19th June 2009, 23:41   #38  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
What about your (previous) engagement at Avail Media?
Old 19th June 2009, 23:43   #39  |  Link
Dark Shikari
x264 developer
As it happens, summer internships end at the end of the summer
Old 22nd June 2009, 20:17   #40  |  Link
Gokumon
Posts: n/a
Okay, from what I read from your posts it seemed to be an actual full-time position not an internship. Let's put it this way instead then, some people don't necessarily have as much time and effort to spend to write assembly for many multiple CPUs as other people may be able to.
