Old 18th February 2016, 18:39   #14201  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
You must use x86 version of KLNMeansCL due to installed AviSynth x86.
Run http://developer.download.nvidia.com...eviceQuery.zip to see if hd5500 has proper support for OpenCL
Old 18th February 2016, 19:37   #14202  |  Link
kensiko35
bandwidth
Hey Atak, I was shown your application from another forum guy. This is pretty amazing. I used HandBrake for a while now simply because it is much faster than many others, this is what really matters to me, speed !
I didn't try your application yet, I don't have a second powerful computer at home. But I was wandering if I should buy a Intel 8 cores CPU or get another Intel quad core. My concern is about bandwidth, I'm on powerline Ethernet here all over my house. It would be great if I could put the other computer in the garage, but I will not get more than 2 MB per second (bytes, not bites). It is pretty reliable though, unlike wifi.
kensiko35 is offline   Reply With Quote
Old 18th February 2016, 20:46   #14203  |  Link
Atak_Snajpera
DE mode works fine even via Wi-Fi . If you can stream (watch) video file without any fps drops via your network then it should be all ok.
Encoding preset determines speed.
Old 19th February 2016, 01:19   #14204  |  Link
kensiko35
So now as I see your app can use the gpu to encode ? I have a hd7800, would it be much faster than my 2500k @ 4.5 ghz ?
Old 19th February 2016, 04:34   #14205  |  Link
dv8r
cdial
I have 4 nodes on ethernet and I will put my laptop online via wifi at times. The wifi usually takes about 5-10 seconds longer to load the file. Not too shabby at all. Not when you consider the amount of time you're saving having multiple machines working on a file. It's a great program. I'm doing a x265 encode now at 45 fps with 1 ancient and 3 older machines. Can't beat that.
dv8r is offline   Reply With Quote
Old 19th February 2016, 07:18   #14206  |  Link
omegaeel
Source file could not be indexed !
I love this program, been using it for over a year. But lately I've been having an issue with the error text "Source file could not be indexed". It only comes up with DE enabled.
I've had this happen with v1.19.3, with mp4s and mkvs, Windows 10 and Windows 7. I've tried switching to a different Temp folder through Ripbot264.ini, but this seems to be ignored. I'm running it as Administrator, I can access the shared Temp from other PCs on the LAN.
What am I missing?
omegaeel is offline   Reply With Quote
Old 19th February 2016, 14:45   #14207  |  Link
Atak_Snajpera
What am I missing?
When you get that message run this in command console and see what happens. (post screenshot)
Change X to correct drive letter
"\\[YOUR-PC-NAME]\Ripbot264temp\Tools\AviSynth plugins\ffms\ffmsindex.exe" -f -k "X:\temp\Ripbot264temp\Job1\video.mkv"'
GPU is only used for denoising. Encoder runs purely on CPU.
Old 19th February 2016, 22:35   #14208  |  Link
omegaeel
Screen cap: https://www.dropbox.com/s/g5obpoqsyj...encap.png?dl=0
The command did create "video.mkv.ffindex", I attempted to rerun the encode and this time a window popped up saying it could not open "info.txt", even though I saw it was there when I ran ffmsindex. In the directory "info.txt" was now gone.
Old 20th February 2016, 02:27   #14209  |  Link
burt123
burt123's Avatar
I see that Khanattila has posted an updated version.
burt123 is offline   Reply With Quote
Old 20th February 2016, 14:43   #14210  |  Link
Atak_Snajpera
I asked you to use specific NETWORK path ("\\[YOUR-PC-NAME]\...). You used local path.
Old 20th February 2016, 15:57   #14211  |  Link
bcn_246
bcn_246's Avatar
Just wondered, when using networked encoding is the resulting quality any lower than single machine? How exactly is the encode spread (I assume it is by segmenting the video).
bcn_246 is offline   Reply With Quote
Old 20th February 2016, 16:39   #14212  |  Link
Atak_Snajpera
In CQ mode quality is the same. In 2-pass mode should be also almost the same due to added Bitrate Distribution Optimization
https://www.doom9.org/showthread.php...04#post1729404
Old 20th February 2016, 17:20   #14213  |  Link
billqs
Can someone tell me where the logs are kept. I'm having trouble backing up one of my discs. Previously, I've just had to adjust something in the .ini program and it would work, but I've had no success with it. I keep getting a Demux error.
billqs is offline   Reply With Quote
Old 20th February 2016, 18:49   #14214  |  Link
Atak_Snajpera
go to job folder and locate demuxlog.txt
Old 20th February 2016, 20:49   #14215  |  Link
billqs
I've attached the demuxlog.txt. Looks like there may be trouble reading the source, unless that points to something else.
Thanks for all your help! I used your program for several years and it's been a lifesaver!
EDIT: I tried cleaning the media even though it appears clean. I also tried another blu-ray drive in my PC, still getting same results.
EDIT: For some reason it didn't show the log I had uploaded so here it is:
eac3to v3.31
command line: "C:\Program Files (x86)\Ripbot 264\Tools\eac3to\eac3to.exe" "D:\" 1) 2: "E:\Temp\RipBot264temp\job1\video.mkv" -seekToIFrames 3: "E:\Temp\RipBot264temp\job1\audio_1_English.core.dts" -core 5: "E:\Temp\RipBot264temp\job1\5_subtitles_English_1080.sup" 6: "E:\Temp\RipBot264temp\job1\6_subtitles_Spanish_1080.sup" 1: "E:\Temp\RipBot264temp\job1\chapters.txt" -progressnumbers -log="E:\Temp\RipBot264temp\job1\demuxlog.txt"
M2TS, 1 video track, 2 audio tracks, 2 subtitle tracks, 1:36:53, 24p /1.001
1: Chapters, 24 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: DTS Master Audio, English, 5.1 channels, 24 bits, 48kHz
(core: DTS, 5.1 channels, 1509kbps, 48kHz)
4: AC3, English, 2.0 channels, 224kbps, 48kHz
5: Subtitle (PGS), English
6: Subtitle (PGS), Spanish
Creating file "E:\Temp\RipBot264temp\job1\chapters.txt"...
[s05] Extracting subtitle track number 5...
[s06] Extracting subtitle track number 6...
[v02] Extracting video track number 2...
[a03] Extracting audio track number 3...
[a03] Extracting DTS core...
[v02] Muxing video to Matroska...
[a03] Creating file "E:\Temp\RipBot264temp\job1\audio_1_English.core.dts"...
[s05] Creating file "E:\Temp\RipBot264temp\job1\5_subtitles_English_1080.sup"...
[s06] Creating file "E:\Temp\RipBot264temp\job1\6_subtitles_Spanish_1080.sup"...
Reading the source file failed. <ERROR>
Aborted at file position 4269801472. <ERROR>
Last edited by billqs; 21st February 2016 at 06:13. Reason: To include demuxlog.txt
Old 21st February 2016, 00:03   #14216  |  Link
omegaeel
It doesn't work. The Ripbot264temp network share points to the directory with the job1 files, not the shared tools. Ripbot264.ini still lists StoreTempFilesin=TEMP
Old 21st February 2016, 00:58   #14217  |  Link
kwangkwang
Hi
I am using 20 cores 40 threads (2 x E5-2660v2) to perform x265 10bit.
Unlike x264 where all cores are fully utilised, the maximum number of cores use for x265 are 16 cores. Increasing number of encoding servers has no effect to use the remaining idle 4 cores.
Is there something that I need to tweak for x265 to use all cores or is it a limit that x265 use max 16 cores?
kwangkwang is offline   Reply With Quote
Old 21st February 2016, 03:32   #14218  |  Link
mdchaser
Originally Posted by kwangkwang View Post
Hi
I may be reading this wrong but it sounds like you are trying to use two NUMA nodes on the same machine to encode? If that is the case I would recommend loading two VMs, giving them each 10 or 20 cores and set them to not cross NUMA boundaries. You will get noticeably better performance and should be able to more fully utilize your hardware. Good luck! And might I ask which settings you are using for x265? I'm using CRF 18 with the goal of getting near perfect encodes but I think the scale is different than it was with x264.
mdchaser is offline   Reply With Quote
Old 21st February 2016, 19:31   #14219  |  Link
Atak_Snajpera
Fixed: EncodingClient couldn't copy tools to temp folder if user chose "StoreTempFilesIn=TEMP"
Old 21st February 2016, 20:31   #14220  |  Link
Ma
It could be related to commit 10983 https://bitbucket.org/multicoreware/...50a72261c308d9
x265 team tested this patch only on Linux systems. On Windows it is big slow-down change -- on 2 NUMA system with 48 logical cores up to 50% maximum speed.
There are 2 simple solutions:
1) please add '--pools 20,20' option to x265 command line,
2) you can test x265 builds from page www.msystem.waw.pl/x265 (not clean builds which are without changes) -- if you take x265 binaries from yellow background (VS 2015, version >= 1.9+15) you can run it without any changes in options.
This problem is under investigation by x265 team, so please report back what you observe.
Ma is offline   Reply With Quote
