Old 18th January 2021, 03:45   #1  |  Link
Albert6677
What are the disadvantages of intra_refresh?
I am new in the RTC field.
Could you please tell me what are the disadvantages of intra_refresh?
After reading Salsify and WebRTC's source code, I found that they do not use this mechanism.
In my opinion, intra_refresh can benefit us a lot. It could not overshoot the bandwidth in most of the time, because of no IDR frame.
So could you please tell me why they do not use intra_refresh?
Albert6677 is offline   Reply With Quote
Old 19th January 2021, 07:02   #2  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Good question! It's unfathomable to me to use single frame VBV (when targeting low latency) without intra refresh! That keyframe pumping is ruinous.
Old 20th January 2021, 18:03   #3  |  Link
benwaggoner
Intra refresh also can really improve quality when there is packet loss, which is pretty inevitable when using low-latency UDP in RTC. If an IDR is corrupted, the rest of the GOP is likely unwatchable. But with intra refresh, you get periodic refreshes for macroblocks which future frames can then reference, so over time quality is restored without a full IDR.
One can think of it is having IDRs for macroblocks instead of frames.
They're not great for random access, but that's not a key RTC scenario.
Encoding and playback are really different above and below 1 sec of latency!
Ben Waggoner
My Compression Book
intra_refresh, webrtc, x264
