Old 6th February 2018, 22:10   #1501  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
LameXP v4.16 Beta-6
Changes between v4.15 and v4.16 [*unreleased*]:
* Upgraded build environment to Microsoft Visual Studio 2017 with Update-5
* Updated LAME encoder to v3.100 Final (2017-10-13), compiled with ICL 18.0 and MSVC 14.1
* Updated mpg123 decoder to v1.25.8 (2017-12-02), compiled with GCC 7.2.0
* Updated Opus encoder/decoder libraries to v1.3-beta-2 (2018-01-26) and Opus-Tools to v0.1.10-12 (2018-01-02)
* Updated Monkey's Audio binary to v4.33 (2017-12-01), compiled with ICL 18.0 and MSVC 15.5
* Updated FAAD decoder to v2.8.6 (2017-10-10), compiled with ICL 18.0 and MSVC 15.5
* Updated ALAC decoder to refalac v1.64 (2017-05-19), compiled with ICL 18.0 and MSVC 15.5
* Updated WavPack decoder to v5.1.0 (2017-01-20), compiled with ICL 18.0 and MSVC 15.5
* Updated MediaInfo to v17.12 (2017-12-21), compiled with ICL 18.0 and MSVC 14.1
* Updated GnuPG to v1.4.22 (2017-07-19), compiled with GCC 7.2.0
* Updated QAAC add-in (separate download) to QAAC v2.64 (2017-07-19), compiled with ICL 18.0 and MSVC 15.5
* Complete re-write of MediaInfo parsing code, now using XML-based MediaInfo output
* Improved auto-detection of max. parallel instances on computers with "fast" (i.e. SSD or similar) drive
* Some improvements to output file name generation code
* Added "Visual Elements" manifest for Windows 8+ "Start" screen tile
Old 16th March 2018, 22:14   #1502  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.16 Beta-9
* Upgraded build environment to Microsoft Visual Studio 2017.6 (MSVC 19.13)
* Updated Opus encoder/decoder libraries to v1.3-beta-15 (2018-02-22) and Opus-Tools to v0.1.10-49 (2018-02-24)
* Some more protection against "DLL pre-loading" attacks has been implemented
Old 1st April 2018, 13:10   #1503  |  Link
ggtop
Cuesheet Importer
Hi LordMulder,
I recently figured out LameXP has a cuesheet import function . That'll make my life a lot of easier in the future because I used other tools in the past to split WAV images...
One cosmetic thing though. The column index is dropping the hour from the timestamp (title 10). See attached screenshot from LameXP and the original cue file created by Exact Audio Copy.
BTW Would be better to display 63... min instead of 1:03:...
  TRACK 09 AUDIO
    TITLE "Track09"
    PERFORMER "Die drei !!!"
    REM COMPOSER ""
    INDEX 01 57:30:36
  TRACK 10 AUDIO
    TITLE "Track10"
    REM COMPOSER ""
    INDEX 01 63:51:43
Have nice Eastern,
ggtop
ggtop is offline   Reply With Quote
Old 1st April 2018, 15:04   #1504  |  Link
LoRd_MuldeR
Software Developer
Originally Posted by ggtop View Post
Hi LordMulder,
  TRACK 09 AUDIO
    TITLE "Track09"
    REM COMPOSER ""
    INDEX 01 57:30:36
  TRACK 10 AUDIO
    TITLE "Track10"
    REM COMPOSER ""
    INDEX 01 63:51:43
Have nice Eastern,
ggtop
Okay, I see why that happens. I was using the QTime class to convert the time index to a string. QTime wraps around the "minute" component to zero after 59
Now I'm doing the conversion manually, so that the "minute" component can go up to 99. Please try with the new TEST build:
https://sourceforge.net/projects/lam...6.exe/download
Regards.
Old 1st April 2018, 16:22   #1505  |  Link
ggtop
Originally Posted by LoRd_MuldeR View Post
...Please try with the new TEST build...
Many thanks for the quick fix. I can confirm it works. Also tested some other cue/wav files.
ggtop
Old 8th April 2018, 00:00   #1506  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.16 RC-1
* Updated mpg123 decoder to v1.25.10 (2018-03-05), compiled with GCC 7.3.0
* Updated Opus encoder/decoder libraries to v1.3-beta-31 (2018-03-27) and Opus-Tools to v0.1.10-51 (2018-03-04)
Old 11th April 2018, 21:44   #1507  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.16 RC-2
Old 12th April 2018, 16:12   #1508  |  Link
Kisa_AG
LameXP v4.16 RC-2
Hello!
Why don't you update QAAC to the newesr 2.66? Anything wrong with it?
Kisa_AG is offline   Reply With Quote
Old 12th April 2018, 17:27   #1509  |  Link
LoRd_MuldeR
Software Developer
Originally Posted by Kisa_AG View Post
Hello!
The changelog for v4.16 is the accumulation of everything that happened in the past ~1 year since the previous release.
QAAC v2.64 simply was the latest version of QAAC at the time when I last updated QAAC.
I usually try to keep all tools up-to-date, but I also have a real-life job, so I can't update everything all the time
(Also, don't expect any "spectacular" improvements in the new QAAC version. After all, it is "only" front-end to Apple's AAC encoder)
Old 15th April 2018, 15:10   #1510  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.16 RC-3
* Updated MediaInfo to v18.03.1 (2018-03-26), compiled with ICL 18.2 and MSVC 15.6
Old 16th April 2018, 02:48   #1511  |  Link
johnsonlam
johnsonlam's Avatar
Thanks for your work, I've enjoy LameXP and other utilities for almost a decade, some people did have most of their real-life besides the monitor, never mind.
I've noticed both the Doom9 and HydrogenAudio was not as crowd as before.
Hong Kong - International Joke Center (after 1997-6-30)
johnsonlam is offline   Reply With Quote
Old 17th April 2018, 20:08   #1512  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.16 RC-4
Old 19th April 2018, 06:34   #1513  |  Link
boyumeow
boyumeow's Avatar
Sorry to bother U again, but I just encounter the not able to encode Chinese character named song again, just wonder was this fixed before cause I somehow remember U did it?
LameXP v4.16 (Build #2124), compiled on 2018-04-17 at 20:19:48
C:/Users/AhBoy/AppData/Local/Temp/e507d1c81c1faf6c/lxp_oggdec.exe -w C:\Users\AhBoy\AppData\Local\Temp\e507d1c81c1faf6c\07d05cd64630cc93.wav "E:\Animovies\And to be remux\天下有情人.ogg"
OggDec v1.10.1 (libVorbis 1.3.5) Compiled on: Mar 19 2015
ERROR: cannot open E:\Animovies\And to be remux\?????.ogg
********** Done decoding all input files. **********
Exited with code: 0x0000
C:/Users/AhBoy/AppData/Local/Temp/e507d1c81c1faf6c/lxp_sox.exe --i C:\Users\AhBoy\AppData\Local\Temp\e507d1c81c1faf6c\07d05cd64630cc93.wav
C:\Users\AhBoy\AppData\Local\Temp\e507d1c81c1faf6c\lxp_sox.exe FAIL formats: can't open input file `C:\Users\AhBoy\AppData\Local\Temp\e507d1c81c1faf6c\07d05cd64630cc93.wav': WAVE: RIFF header not found
Exited with code: 0x0001
It encode successfully if I rename it to English character. I'm using Win10x64 for your info.
Thanks and have a nice everyday.
boyumeow is offline   Reply With Quote
Old 19th April 2018, 22:11   #1514  |  Link
LoRd_MuldeR
Software Developer
According to your log, the file name was passed correctly to OggDec by LameXP, however OggDec failed to open the file.
It appears that OggDec does not support Unicode file names
Maybe I will try to build OggDec from the sources myself and patch in Unicode support...
Old 20th April 2018, 23:23   #1515  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.16 RC-6
* Updated Vorbis decoder to OggDec v1.10.1+ (2015-03-19), using libVorbis v1.3.6 (2018-03-16)
* Updated MediaInfo to v18.03.1+ (2018-04-19), compiled with ICL 18.2 and MSVC 15.6
Old 21st April 2018, 03:52   #1516  |  Link
boyumeow
boyumeow's Avatar
Hi LM, thanks for your kind attention and quick fix, this static build 2130 works for the Unicode support, hope I didn't create new bugs to LameXP.
Didn't realize OggDec does not support Unicode file names, I only just found it a few days ago when I want to share the happiness with a friend, not sure her phone support playing ogg files, so thinking encode into mp3.
Anyway, thanks and have a nice everyday .
Old 21st April 2018, 04:46   #1517  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Do you have the Oggdec patch? Sounds like it'd be useful to polish up and submit to xiph. Fortunately Opus doesn't seem to have that problem.
Old 21st April 2018, 09:19   #1518  |  Link
LoRd_MuldeR
Software Developer
Opus-Tools doesn't have the problem (anymore), as my Unicode patch was already adopted. The patch for OggDec (John Edwards' version) is provided here. Also submitted to the author.
Old 28th April 2018, 06:59   #1519  |  Link
Gravitator
Привет.
The program instead of the directory "Z:" selects the directory in which the LameXP program is installed "Z:\LameXP".
> DEMO
Gravitator is offline   Reply With Quote
Old 28th April 2018, 10:38   #1520  |  Link
LoRd_MuldeR
Software Developer
Originally Posted by Gravitator View Post
Привет.
> DEMO
Seems strange
Would you kindly try with this version and watch out for the additional debug output?
https://sourceforge.net/projects/mul...8.zip/download
aac, aotuv, flac, lame, lamexp, mp3, mp4, ogg, oggenc, opus, vorbis
