4th June 2005, 06:21 | #1 | Link |
Elecard XMuxer Pro
Elecard is happy to announce the availability of Elecard XMuxer Pro version 1.0. for online purchase.
Elecard XMuxer Pro is a great choice for those who want to exploit the cutting-edge technology implemented in easy to use products. You can discuss this product on http://www.elecard.ru/forum/ and download it on http://www.elecard.com/products/xmux_pro.shtml |
23rd September 2005, 09:02 | #3 | Link |
Life's clearer in 4K UHD
Thanks very for the updated information....
We need more tools with MP4 support
2nd December 2005, 14:00 | #5 | Link | |
any link to a new standalone mp4 muxer filter? last version i had was 0.2.9.50929
4th May 2006, 07:12 | #7 | Link |
Elecard is happy to announce the availability of Elecard XMuxer Pro version 2.0. for online purchase.
http://www.elecard.com/products/prod...156/xmuxer-pro |
4th May 2006, 13:22 | #8 | Link |
Kostantin isn't it Mainconcept MP4 Multiplexer now ?
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 |
26th May 2006, 07:15 | #10 | Link |
Hi k-c-ksum,
Whether you could send me a small piece of stream that conatains AC3 track and has problem it the XMuxer Pro. Please send me no more than 3 Mbytes file.(Kohanenko@mainconcept.ru). Best Regards Konstantin. |
26th May 2006, 13:39 | #11 | Link |
I have similar problems. In one stream, version 2 detects the AC3 in transport and it plays OK in preview. But when I want to save the demuxed stream the GUI only allows me to specify MPA audio on output. I do that and then if I rename the saved stream to AC3 it plays.
With another transport stream, the video is not detected! This is pretty bad for a tool that bills itself as a professional muxer/demuxer. Settings are not saved across invocations and I can't make DEC/HEX work at all. All that I found in 10 minutes. I also don't like this: PID 189 ID 20 It should be: Stream 189 PID 20 I'm very unhappy with this new version. 3MBytes is very small for a transport stream. Can I give you bigger ones via my FTP server? Last edited by Guest; 26th May 2006 at 13:48. |
28th May 2006, 03:31 | #12 | Link |
Hi, neuron2,
If you wish to save the demuxed audio stream with .ac3 extension, you must to choose All files (*. *) in Save As dialog and to enter file name with extension necessary for you (for example audio.ac3). It would be very good, if have laid out on FTP a file with which at you there were problems in our XMuxer Pro. For this purpose, please, contact the Elecard Technical Support Team: tsup@mainconcept.ru. Best Regards Konstantin. |
28th May 2006, 05:00 | #13 | Link | |
I will contact your support. Last edited by Guest; 28th May 2006 at 15:30. |
28th May 2006, 05:17 | #14 | Link |
I do not think, that extension of a file is of great importance. In the following version we shall make exhibiting necessary extension according to type of an input stream. Thanks that help to improve our software product.
Best Regards Konstantin. Last edited by Konstantin; 28th May 2006 at 07:42. |
28th May 2006, 07:42 | #17 | Link |
Hi ed
"I can make a shorter sample if needed" Make it please (I think will be enough 5 – 10 Mb) then we can understand what a problem and to solve it as soon as possible. Additional details also will be very useful to us. Best Regards Konstantin. |
28th May 2006, 08:04 | #18 | Link |
Below is shorter 7MB sample.
sample Use VLC player to playback, there are two audio tracks + video. To play ac3 track / 2 audio track with 2-channels audio system set also AUDIO DEVICE to 5.1 to hear full volume of the sound. Regards eb Last edited by eb; 28th May 2006 at 08:06. |
28th May 2006, 14:08 | #20 | Link | |
0x5d3 Video 0x5d4 MPA Audio 0x5d5 DTS Audio XMuxer Pro does NOT detect the MPA stream! I was able to demux and play the DTS track, however. For your longer stream, XMuxer Pro detects the MPA track but not the DTS track! Last edited by Guest; 28th May 2006 at 14:21. |
