5th February 2008, 00:26 | #4541 | Link |
Is there a way to run processes at higher priority than automkv?. I am using 0.93a and my encoder (x264.exe) runs at lowest prio, just like automkv.exe and they are fighting for CPU time (both around 50% on c2d cpu). If I manually change the priority so that x264.exe is NORMAL then x264 gets most of the cpu cycles.
This is using mp4 container and x264 for video with nero (SEE3 version) for audio. edit: Also on Vista64 ultimate is there any speed to be gained from using 64bit versions of dgindex and x264 from here ? http://members.optusnet.com.au/squid_80/ Last edited by Amir; 5th February 2008 at 00:30. |
5th February 2008, 08:54 | #4542 | Link |
I dont care so should you
Kool check out my installers for this AutoMKV 0.93a and RipBot264 \/\/down\/\/ in my signature... More are coming for other OSS and Closed Source software's.
PM me if you have any comments or concerns or if you have bugs with the installers... PS the new 0.95beta21 can be accessed through the start menu if you would like to test the most recent version...
My Installer's || Last edited by Ajax_Undone; 5th February 2008 at 09:12. |
5th February 2008, 09:39 | #4543 | Link |
HDConvertToX author
@nanorch
i'll check... @Amir ... well usually users want able to do other things while encoding.. automkv priority isn't important since the work is done by encoder... @Ajax_Undone Excellent installer! i hope soon to publish the definitive 0.95, feel free to update the installer to new build, i will link your installer in first post! thanks BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
5th February 2008, 10:44 | #4544 | Link | |
Posts: n/a
5th February 2008, 12:20 | #4546 | Link |
HDConvertToX author
as i publish the new 0.95 stable , this thread will be closed.
No question will be allowed in this thread. Please use the new 0.95 thread. thanks BHH P.S. and thanks to all for all time on this application!
5th February 2008, 19:20 | #4547 | Link |
No Prob should I just PM you the links...
My Installer's || |
6th February 2008, 00:52 | #4548 | Link |
i posted with this problem a few months ago but now i have a new computer downloaded the latest mkv release but when i try to encode to any container it says no crf found please download latest build of x264 i do that but still it says the same thing
im really getting frustrated with not being able to use automkv i was using it before the latest release and it used to work fine . with the previous release help would really be appreciated |
6th February 2008, 16:52 | #4549 | Link | |
6th February 2008, 18:59 | #4550 | Link |
Hi!
First let me say, good job! Now I have a question. I'm using the 0.93a version and everything is fine but when I add subtitles (.ass) nothing happens. It just says added external subs. But then I cannot choose them from the list the only option is NONE (I still tried encoding though and as you guessed no subs ). Can this be fixed somehow? |
6th February 2008, 19:14 | #4551 | Link |
HDConvertToX author
@ALL
please use the new thread. @shorto muxing in mkv should be ok.. try from dos to lauch muxing.bat .. and look at error (if any) BHH
8th February 2008, 02:43 | #4556 | Link | |
Playing with MKV files...
Intel Core i7 920, 6 GB RAM | GeForce GTX670 | Win8.1 | LAV 0.64 / MadVR 0.87.10 | Zoom Player v10 / MPC-HC 1.7.8 |
