27th December 2006, 01:47 | #162 | Link |
foobaring my ass off
With Wavewizard, of course
As you already have the 6ch file mixed, you can remap straight from WW. Load the 6ch WAV, go to Edit --> Preferences. Enable Enable Channelmapping, Ignore File size in header --> Always (I donīt know how big your file is) and Output --> Wave PCM. Disable anything else. Hit OK. Go to Edit --> Channel mapping. Click on New to create a custom profile. Choose From 6 to 6, Move channels and configure the mapping. Your stream seems to be: L(ch0)-R(ch1)-C(ch2)-SR(ch3)-SL(ch4)-LFE(ch5). To remap it to proper WAV order: L-R-C-LFE-SL-SR --> ch0(0)-ch1(1)-ch2(2)-ch3(5)-ch4(4)-ch5(3) Itīs also posible that the order is: L(ch0)-R(ch1)-C(ch2)-SL(ch3)-SR(ch4)-LFE(ch5). If so remap to: ch0(0)-ch1(1)-ch2(2)-ch3(5)-ch4(3)-ch5(4) Once youīve created the mapping profile, enable it and hit OK. Now Convert. Try to find similar sounds that should come from near-to-each-other speakers. Letīs say, bullet sounds coming out from the FL speaker are more likely to come out from the SL speaker too. If you hear these sounds coming from the SR, itīs almost certain that SL and SR are mixed. Cheers.
"Damn, respect my authoritay!!" - E. Cartman |
28th December 2006, 18:34 | #163 | Link | |
Thanks. |
28th December 2006, 23:38 | #164 | Link |
If the mappings are correctly applied, that shouldnīt happen.
Maybe you missed something in the mapping. For ch0(0)-ch1(1)-ch2(2)-ch3(5)-ch4(4)-ch5(3) [L-R-C-SR-SL-LFE], remap like this: For ch0(0)-ch1(1)-ch2(2)-ch3(5)-ch4(3)-ch5(4) [L-R-C-SL-SR-LFE], like this: Donīt forget to enable the mapping Cheers
7th June 2007, 08:35 | #168 | Link | |
I'm going from DTS-HD --> Tranzcode --> Wavewizard (6 CH WAV), hopefully to AC3 using Behappy. I take the individual channel WAV's, and order them in Wavewizard: FL, FR, C, LFE, SL, SR (which I think is the proper way). I click "Merge" under Preferences, and process it. The end result is, I can't open the 6-channel wave in anything... not in Behappy, Audacity, or Nero Wave editor. It crashes each of these programs every time I load the merged WAV. The individual WAV's do play, as they are generated by Tranzcode, it seems I must be missing something somewhere, or Wavewizard is. I'm guessing from people singing the praises of Wavewizard, it's something I'm overlooking. Incidentally... I also tried to import the WAV's into audacity, and then merge into a flac... same result. Everything crashes instantly on load of the merged file. ??? Can someone tell me exactly how to properly merge the 6 WAV's into one, so I can then make a proper AC3 using BeHappy? Hopefully without the insta-crash? (Of course, I have no way of testing the mapping myself, since the resulting 6-channel wave is crashing every encoder I have.......) I'm desperately confused here... I really need to have "that one way that works"... thanks Last edited by homerpez; 7th June 2007 at 10:51. |
7th June 2007, 12:11 | #169 | Link |
@homerpez
I don't know if Tranzcode can decode DTS-HD, but if you say the mono wavs are playable, and recognized by WaveWizard, the multichannel generated can be usable for Aften (or AftenGUI) to encode to ac3. Maybe you have a multichannel wav greater than 4 GB and some soft refuse to play them, but no problem for Aften if you include the -readtoeof 1 parameter. If this not work, please specify sizes and formats of wav files. |
7th June 2007, 16:48 | #170 | Link |
I definitely think something else is amiss here... since as I posted above, it wasn't only the 6.99GB Wav that crashed all encoders/players instantly, the FLAC did it as well. The FLAC was only about 300 MB or so, so it's not a matter of size I don't think.
Each of the tracks I get from tranzcode have this attribute when I ask for 'Properties' in MPC: Audio: IEEE Float 48000Hz mono 1536Kbps [output] All of them do play correctly by themselves, but will not play of encode when merged into anything. I've tried WAV (Wavwizard) and FLAC (using Audacity). In BeHappy (which is frontending Aften I guess), the WAV simply crashes the program instantly. With the FLAC, it just sits there, the processor is doing "something" but no audio is encoded from it. Is there a program that will let me load all the mono WAV files into it directly, and encode straight to AC3? Perhaps someone who IS doing DTS-HD encoding can lead me through their process, I may be doing something wrong when I'm merging them, or my computer itself may have a demon possession - you never know. Whatever ways I'm trying (Wavwizard and Audacity) don't seem to merge properly..... |
7th June 2007, 17:46 | #171 | Link |
If your mono wav's are over 1h 48min, and over 1.16 GB each, and your 6.99 GB multichannel wav are created with WaveWizard Preferences:
- Stream manipulation: Merge - Output Format: Wave PCM or WaveFormatEx - Others options unchecked your wav 6.99GB is ready to be encoded with Aften with -readtoeof 1 Use command line or AftenGUI Last edited by tebasuna51; 7th June 2007 at 18:08. |
7th June 2007, 19:57 | #172 | Link | |||
OK... this is seriously making me want to kill myself.
1. I demux the DTS-HD track from the m2ts stream. 2. I used Tranzcode 0.40 (TransGUI) to generate 6 mono WAV files. These mono WAV's all play correctly in MPC, WMP, etc. 3. I load the 6 WAV files into Wavwizard. I order them, top to bottom: FL FR C LFE SL SR 4. I applied the checkboxes as indicated. Stream manipulation, Merge, PCM WAV out, no other options. I Click 'Convert', and at the end they all say 'Sucessful'. It makes the 6.99GB wav. 5. I then try to use the 6.99GB "audio-FL_Merge.wav" file to make the AC3. Here's what happens: BeHappy wavsource -> Aften AC3 = Program instantly crashed, with this error: Quote:
("Read to end" flag was checked on both GUI's, and is by default.) Trying to play audio-FL_Merge.wav in WMP crashes. Winamp crashes. Audacity crashes. Media Player Classic crashes. This is the error raised by MPC, maybe it can explain why this is going on??? Quote:
7th June 2007, 20:40 | #173 | Link |
- Maybe you use a old Aften version without support for -readtoeof?
Last rev521 must work. - Or send me the wav headers (mono and 6chan). Extract the first bytes with a Hex editor or VirtualDub/Mod: VirtualDub -> Tools -> Hex Editor -> File -> Open... your wav file, Edit -> Extract Segment... -> (Address: 0, Length: 1000) Ok and save like segment.wav. Use http://www.mytempdir.com/ to host this file. |
7th June 2007, 21:11 | #174 | Link | |
Just wanted to clarify again... it's not just Aften crashing, it's every program I use, system-wide. Any time my system goes to play or encode from this multichannel wav, whatever program I'm in crashes. So it's having trouble even before Aften even has a chance to work with it. EDIT: oops... I messed up the first time, this is the first I ever used Mytempdir.com.. This should be the segment file : http://www.mytempdir.com/1349567 The segment also crashes everything I try to load it in.... Last edited by homerpez; 7th June 2007 at 22:09. |
8th June 2007, 00:46 | #175 | Link |
1) I can't reproduce this, using -readtoeof 1 I can encode the segment to a 32 ms (1 frame) ac3.
2) The header is correct (32 bit float, 48 KHz, 6 channel) only the DataLength and RiffLength are set to 0 (the correct value can't fit in the 4 bytes reserved for these fields). Maybe some soft don't crash, only open/play a wav with 0 sec. If you want try this: - Extract the files in WavHead.zip at same folder than your audio-FL_Merge.wav and double-click in runme.bat - Now the wav file can be open like 20.8 sec with some soft and we avoid the problem with value 0. 3) To open this wav (32 float) with WavSource (AviSynth-BeHappy) you need AviSynth 2.5.7 You can open the six monowavs with BeHappy using this merge.avs file: Code:
fl = WavSource("g:\yourpath\audio-FL") fr = WavSource("g:\yourpath\audio-FR") fc = WavSource("g:\yourpath\audio-FC") lf = WavSource("g:\yourpath\audio-LF") sl = WavSource("g:\yourpath\audio-SL") sr = WavSource("g:\yourpath\audio-SR") mergechannels(fl,fr,fc,lf,sl,sr) |
8th June 2007, 01:46 | #176 | Link |
Thanks for the reply... unfortunately I think there's something seriously wrong with my machine, or the codecs on it. I hope this is a common problem so someone can tell me what to do..
First of all, I really appreciate your efforts to help me, tebasuna51... it's above and beyond. However, I tried the .avs script on my 6 WAV files... instant crash. I opened up the example WAV you sent me... instant crash. I tried to load it into BeHappy using Wavsource... instant crash. Apparently, at the system/driver/codec level, my machine seems to want to refuse to load multichannel WAV files at all. Where do I even begin to try and fix this kind of problem? I always assumed that multichannel WAV was a standard for eons...??? I've never heard of such a thing happening, and it's something that's worked for me in the past. I'm going to play around a bit with ffdshow, see if maybe I have something checked off somewhere I shouldn't (I don't think I have anything special going on that would cause this)... all I know at this point is, my machine won't decode multichannel WAV, or FLAC formats, out of the blue, at all. |
8th June 2007, 05:44 | #177 | Link |
I FIGURED IT OUT.
It turns out, there WAS a checkbox I should have used in Wavewizard after all: Conversion from 32-bit (float) to 16 bit. On much closer inspection, I discovered that the mono WAV's were all 32-bit (float) format. When I played back a couple AC3 files I had around, I noticed they were all 16-bit. Hmm. Sure enough, I downsample the 6 wav files to 16-bit, and the multichannel WAV opens and plays! I'm encoding to AC3 with BeHappy as I type. Hopefully BeHappy knows what to do with the channels mapped that way... if not, I'll be back to ask for help again probably. Thanks very much for the help thus far Last edited by homerpez; 8th June 2007 at 05:47. |
8th June 2007, 10:56 | #178 | Link | |||
15th June 2007, 13:54 | #179 | Link |
@homerpez
Why dont you use a prof Dolby encoder like Sony/Steinberg/Sonic or Softencode So you can encode the 6 mono waves to AC3 1. Demux DTS HD 2. Tranzcode DTS HD (core) to 6 mono waves 3. Softencode wave to ac3 (i use Steinberg Nuendo) Or you can decode the DTS HD core with Tranzcode to a 6.1 wave with /mch switch and feed aften So you need no wavewizard in this cases greets |
28th July 2007, 16:18 | #180 | Link |
@johnman,
Could you fix the problem in this post: http://forum.doom9.org/showthread.ph...314#post942314? "Wavewizard don't put a valid channel mask, then with WinHex at Offset 0x28 put 0x3F (ChannelMask= FL,FR,C,LFE,SL,SR) and now work OK" Looking at the readme, i think this is open source. Can i get the source somewhere? |
