14th December 2006, 19:45 | #321 | Link |
AviSynth plugger
About System Exception - Access violation.
I have no idea what is SeeSaw function (exactly), and their parameters, and what filters versions you use. But did you try this?: ... denoised_source = original_source.MVDegrain1(backward_vector_1, forward_vector_1) ...
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. |
14th December 2006, 22:32 | #322 | Link | |
Thanks. Edit: Took out SeeSaw and still there is problem - Access violation. This exception is reported at where I am calling MVDegrain1. Last edited by superuser; 15th December 2006 at 01:27. |
15th December 2006, 04:25 | #323 | Link |
Does it crash on this ?
backward_vec2 = last.MVAnalyse(isb = true, delta = 2, pel = 2, overlap=4, sharp=2, idx = 1) forward_vec2 = last.MVAnalyse(isb = false, delta = 2, pel = 2, overlap=4, sharp=2, idx = 1) last.MVDegrain1(backward_vec2,forward_vec2,thSAD=400,idx=1) Last edited by Pookie; 15th December 2006 at 04:27. |
15th December 2006, 06:05 | #324 | Link | |
I had forgot to specify MVdegrain on original_source, so may be it was trying to execute MVDegrain1 on a vectorized source. Sorry. Good thing is it is working now, can experiment continue on my experiment - compare between removegrain (mode=2, 19) , MVDegrain1 and MVDegrain2. thanks fizick and pookie for the help and resolving my silly mistake. |
24th December 2006, 03:15 | #325 | Link |
needed advice on following :
source = last #Step 1 - Compute Backward & Forward Vectors backward_vectors = source.MVAnalyse(pel=2, search=3, chroma=true, isb = true, truemotion=true, idx = 1, lambda = 1000, delta = 1) forward_vectors = source.MVAnalyse(pel=2, search=3, chroma=true, isb = false, truemotion=true, idx = 1, lambda = 1000, delta = 1) #Step 2 - Compute Compensation forward_compensation = source.MVFlow(forward_vectors, idx=1) backward_compensation = source.MVFlow(backward_vectors, idx=1) #Step 3-Create interleaved 3 frames sequences interleave(forward_compensation, source, backward_compensation) #Step 4 - Denoise the source FFT3DFilter(sigma=2, plane=4, bt=4, interlaced=true) #Step 5 - Get non compensated frame denoisedSource=selectevery(3,1) #Step 6 - If need be apply sharpner, SeeSaw or LS + Soothe sharpenedSource=denoisedSource.SomeSharpner 2 - Will using more vectors and computing more interleaved frames in step 3 help in improving results. Or that can be over kill and not really needed or can be spoiler? 3 - What is better approach - use sharpening and dehaloing capability provided by FFT3D or use some external sharpners and have Step 6 4 - Depending on input from above, should Step 6 be performed before Step 5 Thanks for your time. Merry Christmas and happy holidays. |
24th December 2006, 08:31 | #326 | Link |
interlace this!
1. yes, there can and will be artefacts, but depending on the thresholds you use and the artefact protection your denoiser uses, it shouldn't be noticable. so fft3d at low settings will be fine.
2. more frames are useful when the denoiser knows what to do with them. so for fft3d's bt=4, you could compute 1 forward and 2 backward compensations, but any more wont be used. 3. that's outside the scope of this thread. 4. results will be identical, only slower if you swap these steps. selectevery will ditch 2/3 of the frames.
sucking the life out of your videos since 2004 |
24th December 2006, 15:09 | #327 | Link |
You always need to run your own tests on your own source material, and then view the results on the monitor you use for viewing such material (i.e., the computer monitor is NOT the place to view the results). Sometimes this means burning a test DVD (on a DVD+RW or DVD-RW) and then viewing this on your TV.
FWIW, I have seldom found huge improvements in using the motion compensation (there is some) compared to the improvements that can be had by spending time tweaking the settings in step #4. The settings of the FFT denoiser are where all the action is. I would recommend temporarily eliminating all the motion compensation, and then taking 10-20 seconds of representative footage (or longer, if you have the time), and doing test runs with various settings. People have posted various settings here, and I have used some of those as starting point (although some of the settings posted are a little odd). Here are a few that I've collected and modified: Code:
fft3dfilter(x, sigma=3, plane=0, sharpen=1, bt=3, interlaced=false) YToUV(fft3dfilter(x, sigma=2, plane=1, sharpen=.25,interlaced=false).UToY,\ fft3dfilter(x, sigma=2, plane=2, sharpen=.25,interlaced=false).VToY,\ fft3dfilter(x, sigma=7, plane=0, sharpen=1, bt=3, interlaced=false)) fft3dfilter(x, sigma=5, sigma2=10, sigma3=12, sigma4=20, plane=0, bt=3, bw=16,\ bh=16, ow=8, oh=8, sharpen=0.3, smin=20, smax=1000, wintype=2, kratio=1.0,\ measure=true, interlaced=true, degrid=1) fft3dfilter(x, sigma=8, sigma2=18, sigma3=12, sigma4=8, plane=0, sharpen=1,\ measure=true, interlaced=true, degrid=1,wintype=2) Code:
chroma=source.Cnr2("oxx",8,16,191,100,255,32,255,false) final=chroma.fft3dfilter(sigma=6, plane=0, sharpen=1, interlaced=true) Hope this helps. Last edited by johnmeyer; 24th December 2006 at 15:11. |
25th December 2006, 00:09 | #328 | Link |
ангел смерти
This one doesn't make much sense:
YToUV(fft3dfilter(x, sigma=2, plane=1, sharpen=.25,interlaced=false).UToY,\ fft3dfilter(x, sigma=2, plane=2, sharpen=.25,interlaced=false).VToY,\ fft3dfilter(x, sigma=7, plane=0, sharpen=1, bt=3, interlaced=false)) Code:
fft3dfilter(x, sigma=2, plane=3, sharpen=.25,interlaced=false) fft3dfilter(x, sigma=7, plane=0, sharpen=1, bt=3, interlaced=false) |
25th December 2006, 07:54 | #329 | Link | ||||
Thnxs Mug Funky, johnmeyer, Didee (though i do not know where your post went away), and foxyshadis for your input and time. This is one of the reasons I love doom9.
Info on my part for what I am trying this for: I am trying the suggested options (tweaking settings a little bit) on a newer source which needs more than grain remover (with and without motion compensation). Once I find the appropriate method for the source will apply those settings for encoding DVD 9 -> DVD 5 using CCE. Quote:
2 - Another point clicked to me, will interleaving say using with 2 compensated vectors and source, the the previous, current and next frame would be the same. Will this make block temporal size "bt" inefficient for bt parameters 3 and 4, as it will have three frames from same frame to work on, not sure. What do you guys think about it? If I am going offtopic to this thread, mods please my post to fft3d post. Edit: though i observe the color and sharpness difference with same settings one used with motion compensation and another one without. Motion compensation one seems to be better whereas one without appears slightly dull. 3 - I will take this one to fft3d thread. Though do not know where the didees comment on this disappeared. Though at the point Didee made, currently I am trying LSF + Soothe (soothe with newer masktool version from soothe thread). 4 - Yes sir, that was dumb on my part. did not gave it a thought. Quote:
- To process all planes, I generally use plane=4. Is processing one plane at a time better, though time wise I understand, processing one plan at a time, may be higher. - wondering about why you are using high values for sigma 2, 3, & 4 and is there any correlation for values of sigma 2 ,3 & 4? Quote:
Regards and happy holidays to all !!! Last edited by superuser; 25th December 2006 at 23:43. |
4th January 2007, 15:53 | #330 | Link |
Just some questions about strenght of filtering in MVtools
What is the most higher parameter for filtering for MVdegrain 2 or MVDenoise: I am using this scripts(for interlaced material, Pal, DV avi 720x576,BFF). Source is yuy2 Code:
#SetMTMode(2) //To speed up source=AVISource("C:\Documents and Settings\Nenad\Desktop\vulkani.avi") fields=source.AssumeBFF().SeparateFields() backward_vec2 = fields.MVAnalyse(isb = true, delta = 2, pel = 2, overlap=4, sharp=1, idx = 1) backward_vec1 = fields.MVAnalyse(isb = true, delta = 1, pel = 2, overlap=4, sharp=1, idx = 1) forward_vec1 = fields.MVAnalyse(isb = false, delta = 1, pel = 2, overlap=4, sharp=1, idx = 1) forward_vec2 = fields.MVAnalyse(isb = false, delta = 2, pel = 2, overlap=4, sharp=1, idx = 1) fields.MVDegrain2(backward_vec1,forward_vec1,backward_vec2,forward_vec2,thSAD=800,idx=1) Weave() Only when set to 200 i see that is low quality. The same thing is with these script: Code:
LoadPlugin("mvtools.dll") LoadPlugin("MaskTools.dll") import("C:\Program Files\AviSynth 2.5\plugins\SeeSaw.avs") #setmtmode(2) source = AVISource("C:\Documents and Settings\Nenad\Desktop\vulkani.avi") fields=source.AssumeBFF().SeparateFields() backward_vec2 = fields.MVAnalyse(isb = true, lambda = 1000, delta = 2, idx = 1) backward_vec1 = fields.MVAnalyse(isb = true, lambda = 1000, delta = 1, idx = 1) forward_vec1 = fields.MVAnalyse(isb = false, lambda = 1000, delta = 1, idx = 1) forward_vec2 = fields.MVAnalyse(isb = false, lambda = 1000, delta = 2, idx = 1) fields.MVDegrain2(backward_vec1,forward_vec1,backward_vec2,forward_vec2,thSAD=800,idx = 1) Weave() So, my question is, how to get stronger filtering with MVtools. And one more, where in this script i can put FFT3d filter. Because with that i can get better filtering. thanks |
4th January 2007, 17:38 | #331 | Link |
AviSynth plugger
There is no "filtering strength" parameter in MVDegrain.
It uses "simple" (i.e. very complex) temporal averaging. The more frames, the more averaging. But you can get more strong filtering with "overlap" option (up to half of block size).
4th January 2007, 17:49 | #332 | Link |
I read your manual,
Overlap-Must be even and less than block size Can in script just have overlap and not pel that script is runing little faster? |
4th January 2007, 18:02 | #333 | Link |
AviSynth plugger
for other functions, overlap may be simply lesser block size.
For mvdegrain: ... like FFT3DFilter, overlap value up to blksize/2 Any overlap is summation. Any summation is averaging. i.e. parial denoising. I can not give specific advice. try yourself for your clip. Time-quality is compromiss.
4th January 2007, 18:08 | #334 | Link |
Not clear but i will try to higher overlap parameter
One more, where is proper way to put fft3dfilter in this MVtools interlaced scipts(3 post above). Because with this scripts i remove noise but not all, and with fft3d i can remove little more noise. |
4th January 2007, 22:46 | #336 | Link |
Did you mean to put fft3d filter after weave() and does need to specific interlaced=true or not.
SetMTMode(2) source=AVISource("C:\Documents and Settings\Nenad\Desktop\vulkani.avi") fields=source.AssumebFF().SeparateFields() backward_vec2 = fields.MVAnalyse(isb = true, delta = 2, pel = 2, overlap=4, sharp=1, idx = 1) backward_vec1 = fields.MVAnalyse(isb = true, delta = 1, pel = 2, overlap=4, sharp=1, idx = 1) forward_vec1 = fields.MVAnalyse(isb = false, delta = 1, pel = 2, overlap=4, sharp=1, idx = 1) forward_vec2 = fields.MVAnalyse(isb = false, delta = 2, pel = 2, overlap=4, sharp=1, idx = 1) fields.MVDegrain2(backward_vec1,forward_vec1,backward_vec2,forward_vec2,thSAD=800,idx=1) Weave() fft3dfilter(sigma=1.2,interlaced=true) |
5th January 2007, 01:49 | #338 | Link | |
I try before and after weave and result are similar. Also tried with MT and 2 way is better because use both core.
I mean, how do i know when to set overlap=1 or 2 or 3 or 4 ? Any example would be helpful. |
5th January 2007, 02:07 | #339 | Link |
ангел смерти
Block size is bw and bh. Check the docs for what it defaults to. Overlap is in # of pixels, for instance if you have a 32x32 block size, overlap could be 24 (but slooooooooow). 2 is a very limited overlap, though even that's better than 0, which is rather blocky.
5th January 2007, 11:53 | #340 | Link |
So in MVtools block is blksize, and we have overlap.
Overlap value is blksize/2 or blksize/4 And blksize can be 4,8,16. Default is 8 So if we want blksize=4 overlap must be 2 or blksize=8 then overlap must be 4 Just one note: Can we in script write overlap=4 and not to write blksize=8 ? Does we for thSad parameter we must to define with value of overlap or no? |
