9th March 2013, 08:27 | #1401 | Link | |
"PSNRHVSM-based rdo"
Should be Quantization->Motion Estimation->VHQ Quote:
9th March 2013, 17:30 | #1402 | Link |
I tried my first encoding in x264 with Hybrid and it stops at 98 % and no file is created.
I use rev 2013.02.16.1 on XP 32 bit. It's an avisynth script. I guess you need a debug output file, how to create it ? |
10th March 2013, 11:34 | #1404 | Link |
Thanks. I wait for your response to my pm and I will give you a debug file if you need it.
By the way, when I open Hybrid, I get an Info message : Code:
objName: timeCodePage I believe I didn't have this before today or yesterday. Something else : how to change the DAR of MKV ? I'd like to encode anamorphic 16/9 in 720.576 (and thus display it in 1024.576). |
10th March 2013, 11:40 | #1405 | Link | ||
and b. the name of a sub-page of x264->Misc Quote:
If you use video passthrough, you can change the PAR throug Muxing->Overwrite->Pixel aspect ratio. Cu Selur |
10th March 2013, 14:29 | #1409 | Link |
Astonishing as 16/11 = 1,4545, and 720 * 1,4545 = 1047,24, not 1024.
I found a very little bug in Crop/Resize->Main->Pixel Aspect Ratio (PAR) ; if we tick Convert output to PAR and choose Custom, the digits stay grayed and can't be changed, unless to choose anything else than custom and then choose custom again. |
23rd March 2013, 09:28 | #1411 | Link |
I'm getting an error at mux time.
Nothing related to Hybrid, sorry me for posting this here. It's related to MP4Box: Code:
*** glibc detected *** MP4Box: free(): invalid next size (fast): 0x00000000024dcdd0 *** ======= Backtrace: ========= /lib/x86_64-linux-gnu/libc.so.6(+0x7eb96)[0x7fd043e35b96] /usr/lib/nvidia-current/tls/libnvidia-tls.so.295.40(+0x1c01)[0x7fd042883c01] ======= Memory map: ======== ... ... ... I post here in case you know about other mp4 muxer I can use in this case. My OS is Linux Mint KDE. I could also mux in an mkv container, but I never tried it, and I may lose chapters. |
23rd March 2013, 13:25 | #1412 | Link |
You could try:
a. ffmpeg or b. http://mp4creator.sourceforge.net/ as alternative mp4 multiplexers. But before that I would try a newer version of mp4box from: http://gpac.wp.mines-telecom.fr/downloads/gpac-nightly-builds/ |
23rd March 2013, 15:18 | #1413 | Link | |
If nightly build doesn't help, I'll try ffmpeg that I have installed. I'll come back and report results. I'm back I tried with latest nightly build 0.5.1-DEV-rev4388 in Windows. It also gave me an error on muxing, but it managed to multiplex video and 2 audio streams and chapters. Even with this error, the resulting mp4 seems OK when analysed with MediaInfo, and plays well in VLC. When I tried to add subtitle or tags, it crashed and I just had temporal files and no encoded mp4. I'll try and see if I manage to add tags and subs to the encoded mp4 now... Last edited by digitall.h; 23rd March 2013 at 20:53. |
30th March 2013, 14:45 | #1414 | Link |
Hybrid rev 2013.03.29:
*fixed*
-> downloads: http://www.selur.de/downloads Cu Selur |
30th March 2013, 17:01 | #1415 | Link |
Thanks for these corrections but I have a problem : Hybrid's GUI crashes on my new pc (XP 32 bit SP2) when I open it (Hybrid, not Windows).
I first installed rev 2013.03.09.1 (that you gave me in PM) then 2013.03.29, both crash. I still use rev 2013.03.09.1 on my other pc without problem while it's also with XP 32 bit SP2. |
30th March 2013, 17:06 | #1416 | Link |
Try the win2k version, might be something is missing if only sp2 and not sp3 is installed,... i.e. missing c++ runtime,..
Just tried the newer version on Win2k and they two crash because of MediaInfo. ;/ -> investigating Last edited by Selur; 30th March 2013 at 17:30. |
30th March 2013, 17:41 | #1417 | Link | |
Ok, but I prefer to wait the result of your investigation before to install the win2k version.
I see 2 things installed on the pc on which rev 2013.03.09.1 works and not installed on the pc on which it crashes ; Framework.net and Windows installer. |
30th March 2013, 17:45 | #1418 | Link |
please call mediainfo in a command line and see if that also throws an error for you
it would also help a lot if you could copy the Hybrid.exe (and only the .exe) to another folder an see if it starts up also does the 2013.02.16 version start up fine? Last edited by Selur; 30th March 2013 at 18:14. |
30th March 2013, 18:54 | #1419 | Link | ||
Yes, also with these dll's. Quote:
"C:\Program Files\Hybrid\MediaInfo.exe" I click on enter and I get this message ; Usage : "MediaInfo .... |
