Old 23rd December 2010, 18:23   #341  |  Link
SilaSurfer
SilaSurfer's Avatar
Hey Sharktooth very nice collection with EQM series. My favorite is Eqm V3HR modded for standalone support. I was just wondering is Trellis bug fixed or do I have to use these two workarounds?
1. Disable Trellis
or
2. Restrict quantizers to 2-31
I'm using latest Jawors Xvid 1.22 VAQ version.
SilaSurfer is offline   Reply With Quote
Old 24th December 2010, 02:22   #342  |  Link
Tuik
Hey,
Right now i'm using xvid-encraw from megui development server.
The aim is to backup bluray content to view in players which not support it.
So i'm encoding bluray to xvid HD 720p and bluray to xvid SD 480p.
I load to xvid a small avisynth script with DSS2, spline16 resize and a little bit of sharpen.
I've been in research for the best xvid options to retain the most detail without blocking and without loosing standalone player compatibility. The above taking in consideration that 480p is to be encoding at a max of 2000 avg bitrate and 720p at a max of 3000 avg bitrate.
The settings i'm using now are:
2 pass, 2 max b frames, bframe ratio 162, bframe offset 0, VHQ for bframes and mode 4, MSP 6, no QPEL, no GMC, Chroma Motion, Closed GOP, Trellis Quant, Adapt. Quantization, Packed Bitstream, No Turbo, max kframe in 240, min qt 2 max qt 31
So now what is missing is the custom matrix...
What CQM would you advise with all the above set?
(also if you suggestions on other used settings please don't abstain )
Thanks for your help!
Tuik is offline   Reply With Quote
Old 24th December 2010, 02:52   #343  |  Link
henryho_hk
Originally Posted by SilaSurfer View Post
1. Disable Trellis
Isn't the Trellis bug fixed years ago? And the min. Q should always be set 2 or higher.
henryho_hk is offline   Reply With Quote
Old 26th December 2010, 18:02   #344  |  Link
SilaSurfer
SilaSurfer's Avatar
I know that. I misunderstood what Sharktooth meant by his workarounds on the first page of this thread. The bug came when you would use Trellis + EqmV3HR matrix with quantizer ranges Min 1-31 Max but I never use that so. I thought that restricting max quantizers would show those issues. Thanks and I apologize for taking your time.
Old 27th December 2010, 17:08   #345  |  Link
Tuik
Originally Posted by Tuik View Post
Hey,
Any help?
Old 28th December 2010, 04:15   #346  |  Link
henryho_hk
Is it 720p or 480p @60fps or 30fps?
If you use a good denoiser, QPel can help 480p encodes. Avoid the old AQ.... grab a new xvidcore.dll and use the new VAQ if u need to.
I seem to have read somewhere for best standalone player compatibility, we should use max one consecutive B-frame with "Packed Bitstream" on. If it is a newer player supporting 2 max cons. B-frame, turn off "Packed Bitstream". QPel + 2-max-cons-B saves over 10% bitrate (for more movie details).
max key-frame interval is still 10*fps. But for 60fps encodes I think we may reduce it to 5~7*fps.
H263 with new VAQ offers the best standalone player compatibility and it encodes fastest too. If u want more details, u can use EQM-v2 or EQM-HR-v3-SAP-mod. Make sure that u do have sufficient bitrate because VAQ makes them more prone to blocks and rings for frame peepers. (Actually, H263+VAQ tends to give running textures @ insufficient bitrates too.)
Old 1st January 2011, 21:47   #347  |  Link
Tuik
Encodes are @24fps
Well, my standalone player don't support QPEL so i cannot use it.
Hum.. could you explain me what really packed bitstream does? Because, until now, i've always used it because virtualdubmod doesn't show image if i turn packed bitstream off.
Well, for now, i've been using sixofnine HVS with VAQ and it seems to have good results, however, i can't find those matrices you said. Would you help me? Thanks a lot
Old 2nd January 2011, 11:09   #348  |  Link
henryho_hk
EQM matrices? Take a look at Sharktooth's signature.
Old 3rd January 2011, 02:00   #349  |  Link
crasus
I think he meant the EQM-HR-v3-SAP-mod (which doesn't seem to in Sharktooth's signature) ?
crasus is offline   Reply With Quote
Old 3rd January 2011, 09:15   #350  |  Link
henryho_hk
I see. EQM-HR-v3-SAP-mod is to use CQE to modify inter-frame matrix of EQM-HR-v3 setting all <16 coefficients to 16.
Old 29th October 2011, 23:14   #351  |  Link
$in0bi
I've got an artifact by using eqm v3hr matrix. You can see it in the right top corner.
http://i29.fastpic.ru/big/2011/1030/...66f7374699.png
$in0bi is offline   Reply With Quote
Old 30th October 2011, 05:09   #352  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
It's highly improbable a quantization matrix can result in such an artifact unless the encoder and/or the decoder used is buggy.
Old 30th October 2011, 08:09   #353  |  Link
$in0bi
But this artifact disappears only when I change the matrix or change bitrate. But with this bitrate and output size byte to byte the only decision is to change matrix, but if you think that your matrix is perfect that's nothing to discuss. Besides I've already reinstalled every codec and the result is the same. My friends told me that they saw such artifact when they had compared the matrices (eqmv3hr with others).
The answer from xvid.org:
From your pictures, I can just see that the problem _might_ indeed be related to custom quantization.
Old 2nd May 2012, 14:06   #354  |  Link
neveja
Sharktooth
What do you recommend for ripping on the matrix of 1CD (low bitrate 600-700kbps) - 'v3ulr', 'v3ulr_rev2' or 'v3ulr_rev3'?
Thanks in advance.
neveja is offline   Reply With Quote
Old 9th May 2012, 07:21   #355  |  Link
henryho_hk
http://forum.doom9.org/showthread.ph...70#post1250770
".... on a sidenote eqm v3 ULR is obsolete since LCD displays. ...."
(You can still compare it with Jawor's 1CD matrix and see which one looks better for you.)
Old 17th May 2012, 16:21   #356  |  Link
SilaSurfer
SilaSurfer's Avatar
@ henryho_hk
At what compressibility level did you notice EQM-v3HR + VAQ to show blocks and ringing? I still use Xvid when it comes to SD material and this is my favorite CQM. I was thinking of using VAQ instead of my general setup where I restrict quantizers. I think VAQ should provide more fine quantizer distribution. My compressibility is very low. With compcheck <90%, bitrate range 1800 to 2400.
Old 18th May 2012, 00:21   #357  |  Link
henryho_hk
@ henryho_hk
About 45.
Old 26th November 2021, 17:30   #358  |  Link
orion44
None
orion44's Avatar
Description:
This is a HIGH BITRATE matrix designed to work at full anamorphic DVD res (720x432) with bitrates over 1600kbits (for an average motion movie) and works pretty well even with Q2 encodings or extremely High bitrates. But for that target there will be an Ultra-high bitrate matrix (EMQ V3UHR).
EQM V3HR:
 8 10 10 10 11 11 13 15
10 10 10 10 11 12 14 16
10 10 11 11 13 14 16 18
10 10 11 13 15 17 19 23
11 11 13 15 19 22 26 29
11 12 14 17 22 28 34 41
13 14 16 19 26 34 44 55
15 16 18 23 29 41 55 72
15 15 15 15 16 17 19 22
15 15 15 15 16 18 20 23
15 15 16 17 19 20 23 27
15 15 17 19 22 25 29 33
16 16 19 22 28 32 38 43
17 18 20 25 32 41 50 60
19 20 23 29 38 50 66 81
22 23 27 33 43 60 81 106
Can I use this matrix on a downsized video (576x432) that still requires high bitrates (I will set it to 1900 kbps)?
orion44 is offline   Reply With Quote
