Old 16th November 2019, 20:01   #1  |  Link
Katie Boundary
Katie Boundary's Avatar
Maximum i-frame interval does nothing in second pass
When doing a two-pass XviD encode, if you change the maximum i-frame interval between the two passes, the second pass will ignore the new setting and use the same i-frame interval that was used during the first pass.
Is this intended behavior or a bug?
I ask unusual questions but always give proper thanks to those who give correct and useful answers.
Katie Boundary is offline   Reply With Quote
Old 16th November 2019, 20:19   #2  |  Link
Cary Knoop
Cary Knoop
Cary Knoop's Avatar
First of all, why use XviD, it's an old and inefficient CODEC.
Second, why change essential parameter values? Two-pass is only useful to optimize the encoding for a given fixed size.
Cary Knoop is offline   Reply With Quote
Old 16th November 2019, 23:20   #3  |  Link
Sharc
As far as I know it is by design. The position of I, P and B frames are determined in the first pass of a 2-pass encode. The second pass does not (must not) change it. Changing it would undermine the purpose of a 2-pass encode.
Old 17th November 2019, 21:58   #4  |  Link
Katie Boundary
Because everything that's "better" is too much of a pain in the ass to install and/or use. Or just poorly documented.
Old 17th November 2019, 22:23   #5  |  Link
Cary Knoop
Cary Knoop
Cary Knoop's Avatar
Using H.264 or H.265 is not any harder than using XviD.
What it takes is the willpower to adapt to newer technology instead of maintaining 'rusty' views thereof!
Old 18th November 2019, 18:18   #6  |  Link
Yip, x264 is way way better than XVID, however, I aint too keen on adopting x265 as yet.
[probably because my go-to player in android (MX Player) cant seem to seek in x265 stream, back to beginning or keep going only, was also maybe 10 bit where problem, not sure].
