Old 16th April 2011, 13:59   #1  |  Link
Starbuck2010
DVDx 4 Author
Starbuck2010's Avatar
DVDx 4.0 first public release (FFmpeg/MEncoder)
I'm very excited at publishing the very first public release of DVDx 4!
DVDx 4.0 is free and open-source, targeting Windows, Mac OS X and Linux, today I've published a Windows release fully functionnal, for free download from SourceForge (and VideoHelp, Doom9 further, etc...):
Download DVDx 4.0 for Windows
DVDx 4.0 is fueled by MEncoder and FFmpeg.
DVDx 4.0 is an audio/video encoder as well as a powerful DVD copier. You can read DVDs and quiet any audio or video files and encode them to quiet any popular video formats: VCD/CVD/SVCD/DVD, Xvid/Divx, MPEG-4, H.264, AVC, QuickTime, Flash Video, Ogg, WebM, AC.3, WAV, MP3, MP4/AAC, Lossless Audio,
PCM, Vorbis etc.
DVDx 4.0 is very easy to use: open a DVD or file in the player, play it with audio/subtitle of your choice ; encode a short preview in a few seconds and play it to ensure it's what you expect, and then start the whole encoding job which can take about one hour but you're quiet sure to get a very good result!
DVDx 4.0 makes all good choices for you: popular video and audio codecs and appropiate settings (for fair quality, high quality or smaller size files) but you can tune the encoder with your own preferred settings.
Release 4.0.0.0 is the very first public release, don't spend too much time if you don't succeed in running it, I'll publish a new release very soon.
Nevertheless, your feedback will be appreciated on this forum.
Starbuck
DVDx 4 Author
Starbuck2010 is offline   Reply With Quote
Old 24th April 2011, 19:40   #2  |  Link
Ajax_Undone
I dont care so should you
Ajax_Undone's Avatar
Will there be support for bluray?
My Installer's ||
Ajax_Undone is offline   Reply With Quote
Old 24th April 2011, 19:50   #3  |  Link
Selur
Selur's Avatar
Will there be a portable version of this?
Old 24th April 2011, 23:11   #4  |  Link
fantasmanegro
video size
How to change video resolution ?
fantasmanegro is offline   Reply With Quote
Old 25th April 2011, 18:48   #5  |  Link
wiak
some things that are missing
Resolution
Framerate
Bitrate
Profiles
WebM
other than that it looks good and is stable
Woah! Ninja?! http://nwgat.ninja/ (AV1 Overview)
"Not available in your region" has now been redefined as "Go Pirate, you filthy scum" Nwgat
wiak is offline   Reply With Quote
Old 25th April 2011, 19:00   #6  |  Link
b66pak
b66pak's Avatar
+1 to this...
_
if you ask a question and somebody give you the correct answer don't forget to leave a "thank you" note...
Visit The Land Of Dracula (Romania - EU)!
Old 26th April 2011, 23:18   #7  |  Link
fantasmanegro
Resolution
Framerate
Bitrate
Profiles
WebM
I agree it is good... i like the interface .... please add comp test
Old 27th April 2011, 08:17   #8  |  Link
Starbuck2010
DVDx 4 Author
- I'd love, but it's tough. I've in mind to use BD-Rebuilder and integrate with DVDx 4. I'll work on it after summer and give info updates.
- what do you mean?
- changing profile level
Some things that are missing
Resolution
Framerate
Bitrate
Profiles
WebM
- noted, however these weeks we're working to release Linux and Mac OS X builds, then we'll release a Smart Edition which has resolution, audio sampling, audio and video bitrates.
- about profiles and resolution: the major issue is that encoder engines (FFmpeg, MEncoder) and formats (video codecs) don't support any values. Our policy is to provide only resolutions that are supported to avoid annoying error messages to average users. We need some time to gather feedbacks and improve engines error handling, then we may relax profiles and rezolutions.
- Framerate: changing framerate is tough because of maintaining audio synchro. I don't think it's very useful to change framerate, do you?
- WebM: we've started to compile VP8 encoder on Linux, I guess I'll start testing soon and will integrate in DVDx 4, this summer.
Starbuck
DVDx 4 Author
Old 3rd May 2011, 11:24   #9  |  Link
Starbuck2010
DVDx 4 Author
DVDx 4.0.0.1 for Windows and now for Linux!
I'm very happy to announce the very first release of DVDx for Linux platforms!
Linux users were expecting DVDx for a long time and they had to wait the completely re-written DVDx 4 versions. DVDx 4 Linux editions offers same GUI with same features as the Windows versions. There's a limitation, due to FFmpeg/MEncoder, the Linux edition supports less output formats, we've to disable 3GP/3G2, iPod, PSP, MP4 audio files and MP4/AAC audio codec. Nevertheless Linux users are able to encode in a bunch of video formats;
  • AVI (DivX/Xvid)
  • Flash Video
  • Matroska
  • Apple QuickTime
  • MP4
  • MPEG-1/MPEG-2 (VCD, xVCD, SVCD, CVD, DVD)
  • Ogg Vorbis
and audio formats: AC-3, AU, MP3 and WAV.
We aren't use to package Linux applications for Debian or Ubuntu distros, so we've release DVDx 4.0 in a Linux i386 self-installer.
We encourage Windows users to upgrade to 4.0.0.1 for the improvements and the new MPlayer engine which displays subtitles correctly.
Version 4.0.0.1: bug fixes & display improvement
Features:
- reduced AAC bitrate (better quality alignment with MP3 half bitrate)
- added AAC HQ profiles with high bitrates to HD movies
- added MP3 Low Rates to replace AAC Low Rates on Linux
- change preferred audio codecs for 3GP/3G2 formats
- add mp3_flv virtual codec for 44.1khz high profile in FLV format
- disable AAC audio and 3G2/3GP, iPOD (M4A/M4V) formats on Linux
- add source name display in encoding progress widget
- apply QProcess::close() method to all Qprocess on stack (avoid segment fault in linux/macx)
- use -vframes and -aframes FFmpeg options for encoding preview
Build:
- main.pro fixed to compile on Linux
Engines
- fix (Windows) mixing subtitle display in player (change MPlayer to Sherpya-SVN-r30369-4.2.5)
Downloads:
- Windows: https://sourceforge.net/projects/dvd...2.zip/download
- Linux i386: https://sourceforge.net/projects/dvd...6.run/download
- Source code: https://sourceforge.net/projects/dvd...rc.7z/download
Starbuck
DVDx 4 Author
Old 3rd May 2011, 22:09   #10  |  Link
Selur
Selur's Avatar
- what do you mean?
A zip/rar/..-package version or similar that doesn't need to be installed.
Also wondering: "Why do you include the VC++ 10 .pdb files with the source code,.. " (I mean they are relatively large and one has to rebuild them anyway,..)
Old 4th May 2011, 06:42   #11  |  Link
Starbuck2010
DVDx 4 Author
Portable version: I've added to the wish list, but I've to think before deciding because I'll have to maintain 4 distribution files (win32+macx+linux+src) which will be 7 if I do "portables"... And when we'll release the Smart Edition, will be 8 or 14...
PDB files: oops! shouldn't be in there, I'll correct.
Starbuck
DVDx 4 Author
Old 25th May 2011, 13:58   #12  |  Link
Starbuck2010
DVDx 4 Author
DVDx 4.0.0.2 for Windows, Linux and Mac OS X!
DVDx 4.0 is now available for Mac OS X users!
New in 4.0.0.2 release: first Mac OS X release and first Debian package for Linux
Features:
- added Google/On2's VP8 video codec and WebM (HTML5 video) format for file input
- set Linux paths to use ffmpeg-dvdx4 build and MPlayer/Mencoder installed pakages
- set Mac OS X engine paths to MacPorts (/opt/local/bin)
- cosmetics (reduce size of encoding progess windows)
Build:
- set Debian package to install MPlayer/MEncoder distro packages if not installed
- install libdvdcss2 package to rip encrypted DVD (libdvdcss2_1.2.10-0.4_i386.deb )
- Qt framework libraries updated to 4.7.3
- all platforms buildable: Windows, Linux and Mac OS X
- released binaries for Windows (x86), Linux (i386), Mac OS X (x86_64)
Engines:
- use MEncoder/MPlayer distro (upgrade to Ubuntu 11.04 recommended)
- new FFmpeg build on Windows and Linux (r30023)
- update FFmpeg on Mac OS X (0.6.2 MacPorts)
- update MEncoder/MPlayer on Mac OS X (1.0rc4-4.2.1 MacPorts)
- update MediaInfo to 0.7.44 (all platforms)
Go to trhe download page...
Starbuck
DVDx 4 Author
Old 27th May 2011, 17:46   #13  |  Link
setarip_old
setarip_old's Avatar
@Starbuck2010
Hi!
...a powerful DVD copier. You can read DVDs...open a DVD...
These statements suggest that your program is a RIPPER (eliminates copy protection) as well as a converter. Is this so?
setarip_old is offline   Reply With Quote
Old 28th May 2011, 01:23   #14  |  Link
avih
Capture, Deinterlace
avih's Avatar
Originally Posted by setarip_old View Post
@Starbuck2010
Hi! These statements suggest that your program is a RIPPER (eliminates copy protection) as well as a converter. Is this so?
You can read about it at DVDx 4 homepage.
avih is offline   Reply With Quote
Old 28th May 2011, 17:24   #15  |  Link
Starbuck2010
DVDx 4 Author
Yes DVDx 4 can remove copy protection, however for some licensing reason, the Linux package doesn't contain the libdvdcss2 but one can downbload and install it further.
The Windows installer contains libdvdcss.dll, but could be removed easily.
And yes, a reading at DVDx homepage does the trick
Starbuck
DVDx 4 Author
Old 30th May 2011, 06:42   #16  |  Link
ziemlichdunkel
Originally Posted by Starbuck2010 View Post
DVDx 4
Looks nice, wanted to try, but only one audio stream selectable? (At least two streams should be selectable, making this program much more useful for nowadays encoding tasks...)
ziemlichdunkel is offline   Reply With Quote
Old 30th May 2011, 08:39   #17  |  Link
Starbuck2010
DVDx 4 Author
Agreed multi-audio and multi-subtitle is required nowadays and is planned for DVDx 4, I guess in the next couple of months because I've to improve movie access before (4.0.0.2 too often fails at loading DVD or large files, so I'm working on it and few other issues).
Starbuck
DVDx 4 Author
Old 7th June 2011, 16:17   #18  |  Link
Starbuck2010
DVDx 4 Author
DVDx 4.0.0.3 is out!
DVDx 4.0.0.3 release is out there:
new 4.0.0.3 release provides complete error-free installers for every platform and corrected QuickTime profiles to ensure current AppleŽ QuickTime 7 player compliance ; it improves DVD loading, VP8/WebM playing/encoding, H.264/MKV playback and comes with updated FFMpeg/MEncoder engines.
Download DVDx 4.0: http://www.labdv.com/dvdx/download.php
I hope you enjoy it and expect your feedback, I'll be happy to help new users!
Changelog:
version 4.0.0.3: improve DVD loading and VP8 support
All:
- add progress-bar while loading file
- set large time-out (10s) for MediaInfo and FFprobe
(required for large files and when loading DVD)
- fix H.264 playback issue with MKV files
- fix resampling multi-channel audio with FFmpeg (file input)
- correct QuickTime profiles (H.264 and MPEG-4) for file input
- remove QuickTime (MOV) and iPOD format for DVD input (do MKV first)
Windows:
- add player-dvd.exe (Sherpya-SVN-r30369-4.2.5) for subtitle preview
- new MPlayer/MEncoder builds (r33488, better VP8 playback support)
- new FFMpeg build (git-N-30344)
- uninstall silently previous version
Linux:
- added libdvdcss2_1.2.10-0.4_i386.deb available as extra download,
libdvdcss2 is required to read encrypted DVD movies
- added DVD authentication (may not be needed but not sure)
Mac OS X:
- fix uncomplete installation bundle
- add DVD authentication (no more needed to play DVD before opening in DVDx 4)
- new MEncoder build to fix DVD encoding issues (AAC audio, Xvid/DivX and H.264/AVC)
- new FFmpeg-dvdx4 build to support AMR-NB audio encoding (3G2/3GP/MOV)
- set default player latency started/finished to 5000ms instead of 3000ms
- restart after installation to display icon in /Applications
Starbuck
DVDx 4 Author
Old 10th June 2011, 16:30   #19  |  Link
Starbuck2010
DVDx 4 Author
Just to mention I've published a help-me-to-rip-dvd-and-bluray guide and updated the FAQ for DVDx 4 users who're facing troubles ripping DVD with new protection schemes.
And yes, it will be bluray support.
Starbuck
DVDx 4 Author
ffmpeg, gui, mencoder, x264
