17th December 2012, 23:58 | #842 | Link |
Software Developer
After all it turned out he has a "true" 5.1 DTS stream - only camouflaged as fake PCM 2.0 to hack around the Audio CD specifications.
18th December 2012, 01:06 | #843 | Link | |
Software Developer
LameXP v4.07 Alpha-7
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 17th January 2013 at 21:33. |
20th December 2012, 16:24 | #844 | Link |
Converting mono tracks
I have taken audios with my audio recorder, and wanted them to be converted from wav to flac format by LameXP. Since the recorder has taken mono audio tracks I expected the flac files to have a mono track, too. But LameXP, at least with its default settings, gave me stereo tracks. Of course, left and right channel are identical. So the rendered flac file is even bigger than the original wav file. With Audacity (a freeware audio editor), which is using the LAME codecs, too, conversion is done from mono to mono. That's why I hope, LameXP can do it as well and I only didn't press the right button.
My question ist: How can I have LameXP to render flac mono tracks? Greetings Heinrich |
20th December 2012, 16:31 | #845 | Link |
Software Developer
Hello, Heinrich.
First of all, Wave (PCM) to FLAC conversion has nothing to with LAME at all Secondly, if a FLAC file with two identical Mono channels comes out twice as big as uncompressed PCM, then that's a good example of how bad (or non-existing) the inter-channel compression of FLAC is Finally, I am not quite sure how your Mono Wave file can end up as Stereo FLAC file. Can you post your log?
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 20th December 2012 at 16:37. |
20th December 2012, 18:19 | #846 | Link |
Certainly, if I only knew where to find it. Searching in LameXP's F.A.Q.s I found a slice of text saying "In that case you can double-click on the failed item in order to view the log." But in my case nothing really failed. And if I double-click on the titel just been converted, I get the "meta information", which I don't think will tell you much.
20th December 2012, 22:03 | #847 | Link |
Software Developer
You can click on "succeeded" items just as well to show the log
(And here I'm talking about the "Processing" window, not about the main window)
20th December 2012, 23:26 | #848 | Link |
This is the log. Input file: channels=1 (line 8); output file: channels=2 (line 39). Hope you see the reason why a second channel has been created.
Heinrich Code:
LameXP v4.06 (Build #1170), compiled on 2012-11-04 at 13:56:05 ------------------------------- C:/DOKUME~1/Heinrich/LOKALE~1/Temp/d039e52d80114476ab85d728a3a4a0a0/lxp_sox.exe --i "D:/Heinrich/Eigene Musik/MesseRohrdorfProbe.wav" Input File : 'D:/Heinrich/Eigene Musik/MesseRohrdorfProbe.wav' Channels : 1 Sample Rate : 44100 Precision : 24-bit Duration : 01:34:29.92 = 250043400 samples = 425244 CDDA sectors File Size : 750M Bit Rate : 1.06M Sample Encoding: 24-bit Signed Integer PCM Exited with code: 0x0000 ------------------------------- --> Number of channels is: 1 C:/DOKUME~1/Heinrich/LOKALE~1/Temp/d039e52d80114476ab85d728a3a4a0a0/lxp_sox.exe -V3 -S --guard --temp . "D:\Heinrich\Eigene Musik\MesseRohrdorfProbe.wav" C:\DOKUME~1\Heinrich\LOKALE~1\Temp\d039e52d80114476ab85d728a3a4a0a0\7548e458743848c29fbdc9cc9c8e4121.wav channels 2 C:\DOKUME~1\Heinrich\LOKALE~1\Temp\d039e52d80114476ab85d728a3a4a0a0\lxp_sox.exe: SoX v14.4.0 C:\DOKUME~1\Heinrich\LOKALE~1\Temp\d039e52d80114476ab85d728a3a4a0a0\lxp_sox.exe INFO formats: detected file format type `wav' Input File : 'D:\Heinrich\Eigene Musik\MesseRohrdorfProbe.wav' Channels : 1 Sample Rate : 44100 Precision : 24-bit Duration : 01:34:29.92 = 250043400 samples = 425244 CDDA sectors File Size : 750M Bit Rate : 1.06M Sample Encoding: 24-bit Signed Integer PCM Endian Type : little Reverse Nibbles: no Reverse Bits : no C:\DOKUME~1\Heinrich\LOKALE~1\Temp\d039e52d80114476ab85d728a3a4a0a0\lxp_sox.exe INFO sox: Overwriting `C:\DOKUME~1\Heinrich\LOKALE~1\Temp\d039e52d80114476ab85d728a3a4a0a0\7548e458743848c29fbdc9cc9c8e4121.wav' Output File : 'C:\DOKUME~1\Heinrich\LOKALE~1\Temp\d039e52d80114476ab85d728a3a4a0a0\7548e458743848c29fbdc9cc9c8e4121.wav' Channels : 2 Sample Rate : 44100 Precision : 24-bit Duration : 01:34:29.92 = 250043400 samples = 425244 CDDA sectors Sample Encoding: 24-bit Signed Integer PCM Endian Type : little Reverse Nibbles: no Reverse Bits : no Comment : 'Processed by SoX' C:\DOKUME~1\Heinrich\LOKALE~1\Temp\d039e52d80114476ab85d728a3a4a0a0\lxp_sox.exe INFO sox: effects chain: input 44100Hz 1 channels C:\DOKUME~1\Heinrich\LOKALE~1\Temp\d039e52d80114476ab85d728a3a4a0a0\lxp_sox.exe INFO sox: effects chain: gain 44100Hz 1 channels C:\DOKUME~1\Heinrich\LOKALE~1\Temp\d039e52d80114476ab85d728a3a4a0a0\lxp_sox.exe INFO sox: effects chain: channels 44100Hz 2 channels C:\DOKUME~1\Heinrich\LOKALE~1\Temp\d039e52d80114476ab85d728a3a4a0a0\lxp_sox.exe INFO sox: effects chain: output 44100Hz 2 channels Done. Exited with code: 0x0000 ------------------------------- C:/DOKUME~1/Heinrich/LOKALE~1/Temp/d039e52d80114476ab85d728a3a4a0a0/lxp_flac.exe -7 --channel-map=none -T title=MesseRohrdorfProbe -T "comment=Encoded with LameXP" -T track=1 -f -o "D:\Heinrich\Eigene Musik\MesseRohrdorfProbe (3).flac" C:\DOKUME~1\Heinrich\LOKALE~1\Temp\d039e52d80114476ab85d728a3a4a0a0\7548e458743848c29fbdc9cc9c8e4121.wav flac 1.2.1, Copyright (C) 2000,2001,2002,2003,2004,2005,2006,2007 Josh Coalson flac comes with ABSOLUTELY NO WARRANTY. This is free software, and you are welcome to redistribute it under certain conditions. Type `flac' for details. 7548e458743848c29fbdc9cc9c8e4121.wav: WARNING: skipping unknown sub-chunk 'fact' (use --keep-foreign-metadata to keep) 7548e458743848c29fbdc9cc9c8e4121.wav: wrote 425447346 bytes, ratio=0,284 Exited with code: 0x0000 |
21st December 2012, 01:20 | #849 | Link |
Software Developer
Okay, I had a quick look and it turns out that the FLAC encoder class does not have 1 channel (mono) in the list of supported channel counts.
Consequently the input will be up-converted to 2 channels (stereo), before it is sent to the FLAC encoder. Unfortunately I'm not quite sure whether I omitted 1 channel (mono) intentionally in the list of supported channel counts for FLAC or just forgot it Anyway, I will do some more testing when I have more time...
24th December 2012, 22:02 | #851 | Link | |
Software Developer
I just gave it a try and indeed FLAC will fail to encode from a Mono (1ch) Wave file, so I had disabled "1ch" input for a reason No idea why FLAC doesn't work with Mono input though...
2nd January 2013, 14:03 | #852 | Link |
4 GB limited problem
LameXP v4.05 (Build #1100), compiled on 2012-09-03 at 22:48:43
------------------------------- C:/Users/SHEKO6~1/AppData/Local/Temp/e85c168fcc05486f9728f8b3be211cdc/lxp_avs2wav.exe D:\sheko6000.2\lossless.avs C:\Users\SHEKO6~1\AppData\Loca\Temp\9\e85c168fcc05486f9728f8b3be211cdc\c45608c1de5845c7b8f83f9a597e4938.wav avs2wav v1.3 [Aug 16 2011] by Jory Stone <jcsston@toughguy.net>, updates byLoRd_MuldeR <mulder2@gmx.de> Input: D:\sheko6000.2\lossless.avs Output: C:\Users\SHEKO6~1\AppData\Local\Temp\9\e85c168fcc05486f9728f8b3be211cdc\c45608c1de5845c7b8f83f9a597e4938.wav Checking Avisynth... Done Analyzing input file... Done Opening output file... Done [Audio Info] TotalSamples: 364299776 TotalSeconds: 7590 SamplesPerSec: 48000 BitsPerSample: 16 Channels: 6 AvgBytesPerSec: 576000 Dumping audio data, please wait: All samples have been dumped. Exiting. Dump size exceeds 4 GB, cannot save as RIFF/Wave file! Error while closing output wave file! Exited with code: 0xFFFFFFFA |
2nd January 2013, 16:05 | #853 | Link |
Software Developer
Hi, real.finder.
Indeed, as a matter of fact, the maximum size of a RIFF/WAVE file is 4 GB. Do you have any specific question/suggestion? BTW: Please use [CODE]...[/CODE] tags for pasting logs and other lengthy stuff...
2nd January 2013, 16:57 | #854 | Link | |
thank you for fast reply
any way, I think it's avs2wav, avs2wav has a lot of Issues, like it not work if there is no video in avs script any way I use a big pcm wav file size 4.7 gb directly without an avs script and lamexp work normally for suggestion, you can use avs2pipemod instead of avs2wav, because it work even if there is no video in avs script and more things for file 4gb and over, it show warning but it work for me Code:
avs2pipemod.exe -wav "x.avs" > "x.wav" pause Code:
D:\x>avs2pipemod.exe -wav "x.avs" 1>"x.wav" avs2pipemod[info]: writing 11776.767 seconds of 48000 Hz, 6 channel audio. avs2pipemod[warning]: audio size over 32bit limit (4GB), clients may truncate audio. avs2pipemod[info]: finished, wrote 11776.767 seconds [100%]. avs2pipemod[info]: total elapsed time is 60.708 sec. Code:
General Complete name : D:\x\x.wav Format : Wave File size : 6.32 GiB Duration : 3h 16mn Overall bit rate mode : Constant Overall bit rate : 4 608 Kbps Audio ID : 0 Format : PCM Format settings, Endianness : Little Codec ID : 1 Duration : 3h 16mn Bit rate mode : Constant Bit rate : 4 608 Kbps Channel(s) : 6 channels Sampling rate : 48.0 KHz Bit depth : 16 bits Stream size : 6.32 GiB (100%) thank you again Last edited by real.finder; 2nd January 2013 at 17:33. |
2nd January 2013, 17:34 | #855 | Link |
Software Developer
The WAVE/RIFF file format has a size limit of 4 GB. That's a direct consequence of the fact that chunk sizes are defined as 32-Bit integers (unsigned). There is no way around that, except for changing the specifications. That of course wouldn't be WAVE anymore and all programs would have to be updated to support the new format! And indeed, there is the RF64 format that resolves the issue. Only problem: Support for RF64 is pretty much non-existing in audio tools of today! At the same time, some tools use an "ugly" hack to write "normal" WAVE files larger than 4 GB, by simply setting the "size" value to the maximum possible value (~4 GB) and then writing as much data as they have. In other words: They write past the end of the file! Such file obviously is non-standard and broken! Whether any subsequent tool will be able to process the "broken" file is sheer luck.
About avs2wav issues: There may be some other problems in that tool, which I'd have to investigate. But the 4 GB limit is not a bug or limitation of avs2wav. It simply is not possible to write a (correct) WAVE file larger than 4 GB. Unless you have a time machine to go back to the early 90's and convince Microsoft to define the WAVE format with 64-Bit size fields (rather than 32-Bit), nothing can change that...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 2nd January 2013 at 17:38. |
2nd January 2013, 21:02 | #857 | Link | |
Software Developer
I'd prefer to fix my avs2wav tool.
Also, what if the user selects Wave/PCM output ???
2nd January 2013, 22:18 | #858 | Link |
so, what about wave 64 in temporary file within lamexp operations?
and you can make the output in 4gb limit as usual by make the temporary file within lamexp operations only use the fixed avs2wav or avs2pipemod The choice is yours thank you again Last edited by real.finder; 2nd January 2013 at 22:21. |
2nd January 2013, 22:29 | #859 | Link |
Software Developer
As said before, support for RF64 Wave files is pretty much non-existing in the relevant audio tools. None of the encoders used by LameXP can read this.
17th January 2013, 21:33 | #860 | Link | |
Software Developer
LameXP v4.07 Beta-1
http://sourceforge.net/projects/lame...29/2013-01-17/ Quote:
aac, aotuv, flac, lame, lamexp, mp3, mp4, ogg, oggenc, opus, vorbis |
