Go Back   Doom9's Forum > General > Linux, Mac OS X, & Co
Old 27th July 2010, 22:26   #1  |  Link
peeco
Linux Command joining UNC QT
Is is possible to command line join 2 UNC QT containers together without transcoding them to other formats?
I have done some searching but everything is a transcode (usually demuxing) of the files and I just need to join 2 UNC QT's to one new UNC QT?
peeco is offline   Reply With Quote
Old 27th July 2010, 23:59   #2  |  Link
nm
By "UNC QT" I guess you mean MOV containing uncompressed video?
Demuxing is not transcoding. Since MOV files can't be directly concatenated, they need to be remuxed anyway. I'd try something like this:
ffmpeg -i input1.mov -vcodec copy -f rawvideo -an input1.yuv
ffmpeg -i input2.mov -vcodec copy -f rawvideo -an input2.yuv
cat input1.yuv input2.yuv | ffmpeg -pix_fmt yuv420p -s 720×576 -r 25 -i - -vcodec copy output.mov
Named pipes can be used to avoid writing the raw intermediate files on disk. See "How can I join video files?" in FFmpeg FAQ.
Audio can be handled in a similar way and muxed in the output MOV at the same time as the final video.
Old 28th July 2010, 23:07   #3  |  Link
peeco
Thanks for the quick response nm.
Yes I did mean uncompressed quicktime mov, was hoping it was possible to join the together without demuxing but glad too have an answer to this question.
Old 11th August 2010, 17:22   #4  |  Link
peeco
I tried the cat command suggested using the same naming convention.
The original files are: libquicktime-1.0.2, 720 x 486, Millions, 16-bit Integer (Big Endian), Stereo, 48.000 kHz and the frame rate is 23.98fps.
I can make the yuv files but when I run the cat I get an "Invalid data found when processing input". I have tried different frame rates / frame sizes but have been unsuccessful.
Any thoughts as to where I might be going wrong? Ideally I need to get them back as the original file type, size and frame-rate.
Error below:
[root@toxik1 test_1]# cat input1.yuv input2.yuv input3.yuv | ffmpeg -pix_fmt yuv420p -s 720x486 -r 23.98 -i - -vcodec copy output.mov
FFmpeg version 0.6, Copyright (c) 2000-2010 the FFmpeg developers
built on Jun 28 2010 15:00:32 with gcc 4.4.4 20100503 (Red Hat 4.4.4-2)
configuration:
libavutil 50.15. 1 / 50.15. 1
libavcodec 52.72. 2 / 52.72. 2
libavformat 52.64. 2 / 52.64. 2
libavdevice 52. 2. 0 / 52. 2. 0
libswscale 0.11. 0 / 0.11. 0
pipe:: Invalid data found when processing input
Old 7th May 2011, 02:30   #5  |  Link
danny0085
linux commands
Here you can check out the most used linux commands .
danny0085 is offline   Reply With Quote
command, join, linux, mov
