Old 31st August 2009, 03:06   #41  |  Link
Zachs
Suptitle, MediaPlayer.NET
What's the frame rate of your source?
Edit: I think I know what's going on.
It's a rounding error that's resulting 1000.999999 being treated as 1000.
I'll change it such that it rounds up / down more accurately.
I've found the problem with the subtitle not showing with v1.0.6.
It's another 10L caused by code refactoring.
Zachs is offline   Reply With Quote
Old 31st August 2009, 03:25   #42  |  Link
sneaker_ger
24000/1001
Old 31st August 2009, 05:50   #43  |  Link
Zachs
v1.0.7 now available.
Fixes both problems.
http://www.zachsaw.co.cc/?pg=suptitl...visynth_plugin
Old 31st August 2009, 14:01   #44  |  Link
sneaker_ger
That was fast, Thanks! Working fine.
Old 11th September 2009, 18:58   #45  |  Link
Red Leader
Suptitle is great and I was wanted this for a long time.
To make installation easier, maybe you should insist that .NET 2005 is required, and that .NET 2008 does not includes 2005 functions
I had the "can't load plugin" before realizing that.
Also, it that's not too complex, could Suptitle display PGS that are not text? I tried to display a non-text .SUP file (graphic comments with trivia about the movie), and SupTitle could not display it, while regular subtitles from the same movie worked perfectly.
Red Leader is offline   Reply With Quote
Old 13th September 2009, 16:42   #46  |  Link
Zachs
Thanks for the suggestions.
PGS is all bitmap - it doesn't differentiate between a text and non-text sub. Could you post your file somewhere and let me know what and where to look at?
Old 14th September 2009, 04:29   #47  |  Link
Red Leader
Here is the file ready for download.
http://dl.free.fr/rug5GtpiA
There must be some data that makes SupTitle stall. The graphics are comments in one color, appearing regularly at the bottom of the movie, on the sides or in the center.
Old 14th September 2009, 13:49   #48  |  Link
Zachs
I'll take a look at it - what's the time code I should be looking at?
And what did you use to create the sup file?
Old 15th September 2009, 01:52   #49  |  Link
Red Leader
eac3to was used to demux the movie (m2ts file from bluray) each subtitle tracks is demuxed to a .sup file, including regular subtitles and graphics
suptitle stalls as soon as the avs script is opened
here is the error message
Old 15th September 2009, 15:29   #50  |  Link
Zachs
Yup definitely something I haven't come across before.
Will have a look and see if I could figure out the format...
Old 16th September 2009, 05:48   #51  |  Link
Zachs
I've changed the code so it would read the SUP format you posted.
It'll be available soon.
With regards to the framework dependency issue though, there's really not much I could do besides incorporating the dotnet bootstrap into a proper installer. I'm not keen on doing that as it would increase the download size to a few MBs from ~40KB. I'd rather have the framework as a separate download so users only need to download it once.
Old 16th September 2009, 08:34   #52  |  Link
Zachs
v1.0.8 is now available.
Adds support for the SUP file format found here.
Head over to http://www.zachsaw.co.cc/?pg=suptitl...visynth_plugin to download.
Old 17th September 2009, 18:57   #53  |  Link
Red Leader
Great! It works perfectly now, you have redefined the word responsive! Many many thanks. Now we can read the graphics commentaries demuxed from blurays. You just added a major feature that was lacking since the introduction of hidef media. Maybe you could talk to the media player classic developers, it would be fantastic to include SUP reading directly from MPC, what do you think?
Old 19th September 2009, 12:14   #54  |  Link
vwpassion
Thank you for this filter! Great work.
vwpassion is offline   Reply With Quote
Old 19th September 2009, 22:25   #55  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
This plugin is a lifesaver!
Thanks so much!
Old 21st September 2009, 03:04   #56  |  Link
Zachs
It'll be a lot easier if MPC-HC has some sort of plug-in support which would allow developers to build upon the subtitles rendering part of the software. For now though, you can use AviSynth to do the same and use MPC-HC to play the script.
Old 2nd February 2010, 01:45   #57  |  Link
Zachs
Just wanted to drop a line to inform all Suptitle users that an updated version (v1.0.9) is now available.
It fixes a problem with some SUP files not loading properly.
Old 12th May 2010, 02:18   #58  |  Link
ChldsPlay
I'm getting a syntax error. It says: "Script error: syntax error" Then below that is the location of the script followed by line 3, column 0.
I'm not really sure I know what I'm doing, but I think I don't see what I'm doing wrong. I installed everything mentioned.
ChldsPlay is offline   Reply With Quote
Old 12th May 2010, 04:17   #59  |  Link
Zachs
What's your script?
Old 13th May 2010, 04:28   #60  |  Link
ChldsPlay
LoadPlugin("SupTitle.dll")
clip = MPEG2Source("C:\Users\Kevin\Documents\NeroVision\ExportedVideo\avatar.mpg")
return clip.SupTitle("D:\Avatar\00002.track_4608.sup", forcedOnly=false,
swapCbCr=false, relocate=false, relocOffset="")
For all I know, everything about it is wrong. This is my first time working with AviSynth and scripts.
avisynth, hard sub, plugin, subtitle, suptitle
