15th October 2013, 18:46 | #20401 | Link | ||
Just think about it yourself: If you have a large image area which after YCbCr -> RGB conversion has an 8bit brightness of e.g. 80.4, then without dithering every pixel in that image area will be rounded down to 80.0. So the average brightness of the whole image area will be 80.0. If you enable dithering (as you should!) some pixels will be drawn as 80.0 and some with 81.0, resulting in an average brightness of 80.4. So only by using dithering you'll get the correct image brightness. Dithering does not deband anything, it just avoids quantization errors. And quantization errors can *cause* banding artifacts. So enabling dithering doesn't repair/improve anything. It's the other way round: Disabling dithering can introduce severe image artifacts. It doesn't matter whether you enable debanding or not, you should never disable dithering. |
16th October 2013, 05:09 | #20402 | Link |
madshi, quick question since you are on the subject of dithering. I use ffdshow raw video processor as a post processor only with avisynth script "LimitedSharpenfaster" after decoding with LAV before using mVR as the renderer. In the ffdshow raw settings under the RGB Conversion tab there are two options; one for "High Quality YV12 to RGB Conversion" and the other for "Dithering". Should these be checked or unchecked? I am unsure as I thought that mVR does its own conversion and dithering (?) I am only using the avisynth script with the raw ffdshow, nothing else. Thanks much
16th October 2013, 06:02 | #20403 | Link | |
If you ever needed to output RGB then most certainly you'd want these ticked, without them enabled the image quality is quite bad. Check with madVR (Ctrl-J fourth line) it should show YV12 or NV12, personally I stick with YV12. I don't believe MadVR benefits any from working with NV12, so it's a waste of resources converting to it. Last edited by ryrynz; 16th October 2013 at 06:34. |
16th October 2013, 06:48 | #20404 | Link | |
16th October 2013, 10:34 | #20405 | Link |
Smooth motion
Hello Madshi!
First, thanks for your amazing work along the years! I've one question concerning the smooth motion option under madVr v0.86.11. On my computer (i7 3770k @4.6Ghz + 660GTX Ti + 8Go ram) The picture quality is bad with this option (@60Hz). There is no difference in the picture fluidity and sometimes I can see some frame doubling. It's really strange. I'm using Windows 7 Pro N (special version without Windows Media Player and Media Center) Do you think my problem can be link? Thanks again for your help ++ |
16th October 2013, 17:59 | #20406 | Link |
ok i try it.
i said output YCbCr is not the ideal way because you asked about a way to output this because you heard you ~beamer?~ got problems with rgb right? so i talked about about a way to output YCbCr with madvr because i heard it's possible (i still don't know it's true). so madvr outputs 8 bit 0-255 rgb at default settings. if your gpu outputs rgb unlimited noting should happen. so i don't know what your plan is right now. are you going with your new amd card or not. than there was something about rgb YCbCr output in intel. you can just switch to both in the driver (never heard that this is not working) but outputing rgb 0-255 was a or is a problem with intel there is no option for this (something about "it"or normal content but this does nothing...) and it's a well known problem. don't mix that up with video output 16-235 or 0-255. even if you are going to use limited rgb you still have to use a 16-235 to 0-255 (madvr does this y default) because the desktop is 0-255 and both together needs to be limited again. not the best way to do this but yeah there are plenty of people in this forum with much better english and much better knowledge of this topic then me. so what's your problem in the detail? |
16th October 2013, 23:52 | #20407 | Link |
Hi, nice to see the development is going on! Nice things are coming all the time!
I need your help selecting a good yet not expensive videocard for use with madvr. I need cuda so I am looking for an nvidia. Is a gtx 650 Ti Boost a good one for madvr? Do you recomend another one at this range of money? |
17th October 2013, 00:31 | #20408 | Link |
why cuda dxva is much faster and near if not everything what works with cuda works with dxva too and this leaves more breathing room for madvr.
660 ti 1344 cuda cores 185 € 650 ti 768 cuda cores 140 € i think the 650 ti is very bad for it's money. you may look at the new amd gpu edit: or have a look at an richland apu Last edited by huhn; 17th October 2013 at 00:34. |
17th October 2013, 16:46 | #20409 | Link |
What do you mean, dxva is much faster? DXVA and CUVID use the same ASIC. There may be some differences but "much faster" is simply not true. Also, madVR does not use ASIC but shaders (main GPU) so there is no competition for same resources between madVR and decoding.
17th October 2013, 17:18 | #20412 | Link | |
CUVID forces the gpu in max power state and is more like dxva copy back.
17th October 2013, 21:31 | #20413 | Link |
When using CUVID and DXVA copy-back the decoded video passes back and forth between the GPU and the CPU (well, between video memory and main memory, to be precise). With DXVA native the video stays on the GPU from decoding to rendering, which makes it somewhat faster.
17th October 2013, 22:25 | #20414 | Link |
I've a problem, hope you can help me. Ever since I've updated to Windows 8.1, when I go to exclusive mode with MPC-HC (using LAV filters), I get a red message saying "out of memory" in a red font in a black frame, but the video runs fine. Here's a sample screenshot (sorry, the frame is not shown in screenshot, I don't know why). http://imgur.com/YHlXJ4X What could be the issue? And how do I fix this? I've already re-installed LAV filters, it's still same. Edit: Weirdly, after re-installing (clean) the NVidia driver (although it was showing official driver is already installed at GeForce Experience panel), it's fixed. Thanks again for the awesome renderer!
Spirit... It's the hero's strength, the mother's restlince and the poor man's armor. It cannot be broken and it cannot be taken away. This I must believe Drizzt Last edited by SoulSmasher; 17th October 2013 at 22:32. |
17th October 2013, 23:29 | #20415 | Link | |
On the other hand, I was talking about decoding speed on ASIC which is basically the same for any method. So, it is not "much faster", that is all I wanted to comment. Also, sometimes it is better to put GPU in max power mode because some users reported frame drops because GPU goes to lower power mod and does not have power for madVR rendering job. |
17th October 2013, 23:48 | #20416 | Link | ||
------------------------- I've found a quite promising new tweak for the debanding algorithm. So all ya debanding geeks out there, here's a new test build: http://madshi.net/madVRdeband6.rar The new feature is called "angleBoost" and you can control it via Ctrl+Alt+F9/F10 (decrease/increase) and Ctrl+Alt+Shift+F9/F10 (off/on). This feature checks whether the surrounding pixels all have the same gradient angle. If they do, the other parameters (avgDif, maxDif etc) are all multiplied with the "angleBoost" factor. So a factor of 1.0 means no change. A factor of 2.0 means double parameters. It seems that this new feature might be able to separate details from gradients, so I hope we'll get a nice debanding improvement without losing any image detail. On the content I've tried so far an angleBoost of 2.0 seems to work quite nicely, although that might be a tad too high. Let me know what you think... P.S: The angleBoost feature does consume a bit of additional rendering power. But from my first tests it seems to be more than worth it. |
18th October 2013, 00:12 | #20417 | Link | ||
660 Ti 1344 cores ~235€ 660 960 cores ~175€ 650 Ti Boost 768 cores ~160€ 650 Ti 768 cores ~125€ Quote:
Any recomendation? Last edited by nautilus7; 18th October 2013 at 00:19. |
18th October 2013, 05:12 | #20419 | Link | |
Can we get a build which lets us customize the keyboard shortcuts though? I find them increasingly difficult to use. I'd much rather be using QA, WS, ED, RF etc. |
18th October 2013, 07:20 | #20420 | Link | |
