Old 6th June 2019, 18:10   #16961  |  Link
brumsky
That works!
brumsky is offline   Reply With Quote
Old 6th June 2019, 19:18   #16962  |  Link
stryker412
Originally Posted by stryker412 View Post
Does Ripbot support UHD rips? I am getting an audio error when trying to load up the source file.
Any thoughts on this Atak? This is my first UHD movie.
stryker412 is offline   Reply With Quote
Old 6th June 2019, 19:22   #16963  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Dolby Atmos?
Old 6th June 2019, 19:24   #16964  |  Link
stryker412
Format : TrueHD
Format profile : TrueHD+Atmos / TrueHD
Old 6th June 2019, 19:27   #16965  |  Link
Atak_Snajpera
Try with option "Skip demuxing process". You would have to manually extract audio on your own though.
Old 6th June 2019, 19:29   #16966  |  Link
brumsky
I've been using ripbot to do UHD encodes for at least a year. I haven't had any issues with it until a couple of days ago. I reinstalled Avisynth+ and it was resolved.
I was getting the same error you were.
Old 6th June 2019, 19:30   #16967  |  Link
brumsky
Try this
EncodingServer.exe /priority low
Any thoughts on why this is happening?
Old 6th June 2019, 19:34   #16968  |  Link
Atak_Snajpera
normal is default
Old 7th June 2019, 11:29   #16969  |  Link
stryker412
Hmm, I updated to the latest AviSynth+ and still getting the same error.
Old 7th June 2019, 17:18   #16970  |  Link
brumsky
Well I found one that is still giving me a problem. I'm not sure what it is about this one file. I even remuxed it to a new MKV which didn't fix it...
It's weird because I've done more than 100 but this one is failing still. Oh well, just say no audio and remux later like Atak suggested.
@Atak_Snajpera
Is it possible to give us an option for the encoding priority? I let it run on my PC while I'm working since I don't need the extra CPU cycles.
Old 7th June 2019, 19:18   #16971  |  Link
stryker412
I'll try another movie, this one was Coco.
Old 9th June 2019, 11:55   #16972  |  Link
stryker412
Tried another kids movie (Trolls) and I was able to get it down to a 9GB file! Seems to work now. Took almost 14hrs though. Is there something special you have to do to keep HDR? The resulting file was only SDR.
Old 10th June 2019, 00:14   #16973  |  Link
byteshare
ByteShare
byteshare's Avatar
If you put it in DE (Distributed Encoding) mode you can.
Settings > Distributed Encoding > "Wrench" next to the Active Servers count takes you to:
Encoding Server Command-Line Switches, such as:
``/port 1000 /minimize /priority low``
Old 13th June 2019, 19:07   #16974  |  Link
SKPN
Is there any way to trim audio while doing a direct copy? I'm trying to remove the opening/ending credits from a TV show, but the Trim command only seems to work on audio if it's being encoded, which I don't want to do. I was able to do this previously with Staxrip, but I haven't found any way to do it with Ripbot.
SKPN is offline   Reply With Quote
Old 14th June 2019, 16:19   #16975  |  Link
byteshare
ByteShare
byteshare's Avatar
Might be easier to do it with MKVToolNix IMO...only works with Keyframes though, so might be better to do with source or your encode depending where the keyframes are.
I use MKVToolNix a lot with stuff that has intro trailers and outro trailers after I encode.
Otherwise you can define the frames to use with AVISynth.
Old 17th June 2019, 01:52   #16976  |  Link
Axelstrife
Hope someone could help me, I can get it to encode using the second server which is a laptop but not the computer it's running from (my desktop) i think the encodeing server application is supposed to open but it doesn't like how it does on my laptop, it's open as a process but not in my system tray.
Hope someone can help.
Edit: downloaded an old version and it's working fine with encodeingserver application opening and it's encodeing fine, so it was something wrong with the latest ripbot version.
Axelstrife is offline   Reply With Quote
Old 17th June 2019, 12:23   #16977  |  Link
Atak_Snajpera
https://forum.doom9.org/showthread.p...84#post1872384
Old 18th June 2019, 20:28   #16978  |  Link
byteshare
ByteShare
byteshare's Avatar
Not sure about licensing and all that but any chance of updating to FDKv2?
https://github.com/mstorsjo/fdk-aac/releases/tag/v2.0.0
Not sure there have been the same updates to their FHG encoder
I know Stax has QAAC https://sites.google.com/site/qaacpage/
But not sure how they get around the iTunes being needed.
Old 19th June 2019, 20:28   #16979  |  Link
en3rmax
Hi there,
I been encoding some episode blu-rays in batch mode normally in 1080p without cropping but I would like to crop to - 1440x1080 what is the best way to do this in ripbot batch mode? thanks for the help
en3rmax is offline   Reply With Quote
Old 20th June 2019, 16:37   #16980  |  Link
byteshare
ByteShare
byteshare's Avatar
Originally Posted by en3rmax View Post
Hi there,
Use the auto crop (check box) or manually do it via the GUI or by editing the job files, which can be done in batch with something like NotePad++.
