Old 30th November 2007, 16:02   #281  |  Link
repdetect2
Fix?
Do you think this will be fixed in a future release?
repdetect2 is offline   Reply With Quote
Old 30th November 2007, 16:21   #282  |  Link
PSPNut
I hope so but that is really a question for the developers of mp4box and/or enc_aacplus or Atak . In any case, this is still my favourite encoding GUI.
PS: You will need the latest 1.6.9 for the mp4box to mux the .mov file correctly.
PSPNut is offline   Reply With Quote
Old 30th November 2007, 18:49   #283  |  Link
repdetect2
I sent him a PM on this issue. I hope I am following the right channels, I am new to the app feedback thing
Old 30th November 2007, 19:51   #284  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Did you try with 2.0 AAC LC 96kbps ?
Old 30th November 2007, 19:57   #285  |  Link
repdetect2
Testing
I will give that a try now sir and let you know here shortly...
Old 30th November 2007, 20:24   #286  |  Link
repdetect2
Failure
I received the same "error 2041 invalid sample description"
I have some freetime now, so I can test as much as you like
Old 30th November 2007, 20:32   #287  |  Link
Atak_Snajpera
What resolution did you use?
Old 30th November 2007, 20:50   #288  |  Link
repdetect2
Update
I used the ipod touch/iphone profile. Under advanced options for resize I have "don't resize" and then below its grayed out but it says 320x240...
Old 30th November 2007, 20:51   #289  |  Link
Atak_Snajpera
Use PSP resolution !!! and don't forget to set audio to 96kbps.
Old 30th November 2007, 21:19   #290  |  Link
repdetect2
Thanks
I shall try that, thanks sir.
Old 30th November 2007, 21:47   #291  |  Link
Alfeuss
Not sure if this info will help. I get that same error when trying to play the file in QT. I have researched it and it seems to affect QT. MPC plays the file fine.
However even though I have been encoding for the ipod g5, using floola to transfer the file. the result will not play.
I have tried a few thing to see if i can fix this. remux with NicMP4Box, and edit with AtomicParsley. xb360, and HQ profile have great results 4 what they r intended for. I will try to look further into it. thx again 4 this great looking GUI.
Alfeuss is offline   Reply With Quote
Old 30th November 2007, 22:18   #292  |  Link
Atak_Snajpera
try also with 96kbps and let me know
iPOD users please check if this file works (encoded with latest enc_aacplus.dll - winamp 5.5)
http://www.mediafire.com/?24nyymhyjtl
Old 30th November 2007, 23:11   #293  |  Link
repdetect2
I will check it shortly and report back
Old 1st December 2007, 00:18   #294  |  Link
Alfeuss
Tried the new dll from winamp. Also the sample u provided.
LOL that would help. yes error in qt, and no wouldn't play in ipod.
Old 1st December 2007, 00:27   #295  |  Link
repdetect2
Update
Did the file play in your ipod? Did you still get the error 2041?
I ended up having to go in to work, so I didn't get to test it out
Old 1st December 2007, 02:45   #296  |  Link
Alfeuss
OMG sorry guys. after doing some work and narrowing it down, i see further in the thread the prob. was already discovered. The AAC file.
I'll go back to trolling, and do some reading b4 posting.
Old 1st December 2007, 03:28   #297  |  Link
repdetect2
No Go...
I too have the same error and it won't play on the iphone...
Old 1st December 2007, 16:02   #298  |  Link
PSPNut
I have just tried it. Unfortunately, it still doesn't. But it works fine with VLC, CCC pack, etc (same as previously) . Quicktime will still give error -2041. If I strip out the audio, it works fine, as before.
Old 1st December 2007, 22:40   #299  |  Link
Atak_Snajpera
Last attempt
iPOD
f07_by_Conspiracy_720p.mp4 - muxed with -ipod switch
iPhone
realtime_demo_wannabe_by_maxon__fake_h264_1856kbps.mp4 - muxed with -ipod -brand M4VP switch
Old 1st December 2007, 23:43   #300  |  Link
repdetect2
No Go Pt. 2
Last attempt
iPOD
iPhone
I tested the iphone file and I still get the same error. I can't tell if it will even play on the phone since it isn't recognized by itunes...
Don't give up, I can test all day if I have to
