Old 11th December 2016, 22:01   #2681  |  Link
real.finder
Originally Posted by pinterf View Post
New week, new build, new adventures.
This time I had to remove the script array feature that has caused me and you headaches.
http://www.mediafire.com/file/gbpdu5...splus-r2343.7z
20161211 r2343dev
  • Overlay: use y offset when greymask=true (fix)
  • Fix DV chroma positioning (UV swapped), interlaced parameter check for 4:2:0
    (fix by IanB in classic Avisynth)
  • BitBlt in 32 bit Avisynth:
    for processors with AVX or better ignore tricky isse memcpy replacement, trust in memcpy (test)
    (x64 is O.K., it always used memcpy)
  • Merge: use stream_load for AVX2
  • VDubFilter.dll (now bundled):
    convert 'd' double and 'l' long typed parameters to 'f' float and 'i' int for poor AviSynth, thus allowing the usage of such virtualdub filters
  • remove script array (new AVSValue schema) feature, cannot make it compatible with Invoke from v2.5 plugins until I figure out a workaround or such plugins would slowly distinct. <sniff> <sniff>
that fix the problem of PAL DV
My Avisynth Stuff
Old 12th December 2016, 01:03   #2682  |  Link
fAy01
20161211 r2343dev
FFms2 is still not working with the new avs+ build. Avspmod still cannot display the video. Whereas, yatta throws this error when I try to open any 10bit h264 ffms2 indexed stream: http://i.imgur.com/anIgSP9.png
fAy01 is offline   Reply With Quote
Old 12th December 2016, 06:36   #2683  |  Link
pinterf
As the error says. Ffms2 opens the video in native 10 bits. Use ConvertBits(8) after ffms2 or specify a 8 bit format if your filter chain is 8 bit only. Or when using avspmod.
pinterf is offline   Reply With Quote
Old 12th December 2016, 07:54   #2684  |  Link
pinterf
Originally Posted by ajp_anton View Post
Suggestion to CombinePlanes: if source clip only has a Y plane and "source_planes" is not set, use the Y plane.
Also, if "planes" is set, why do we need "pixel_type"? Can't "pixel_type" be figured out automatically, or am I missing some case when it can't?
You don't need that.
From my earlier post:
CombinePlanes(clip1 [,clip2, clip3, clip4], string planes [, string source_planes, string pixel_type, string sample_clip])
Combines planes of source clip(s) into a target clip
If sample_clip is given, target clip properties are copied from that clip
If no sample_clip is provided, then clip1 provides the template for target clip
An optional pixel_type string (e.g."YV24", "YUV420PS", "RGBP8") can override the base video format.
Old 12th December 2016, 13:30   #2685  |  Link
mcjordan
Compilation break issue:
8> merge_avx2.cpp
8>C:\AviSynthPlus\avs_core\filters\merge_avx2.cpp(75): error C2664: '__m128i _mm_stream_load_si128(__m128i *)': cannot convert argument 1 from 'const __m128i *' to '__m128i *'
8> C:\AviSynthPlus\avs_core\filters\merge_avx2.cpp(75): note: Conversion loses qualifiers
8> C:\AviSynthPlus\avs_core\filters\merge_avx2.cpp(98): note: see reference to function template instantiation 'void average_plane_avx2<uint8_t>(BYTE *,const BYTE *,int,int,int,int)' being compiled
Help?
mcjordan is offline   Reply With Quote
Old 12th December 2016, 13:54   #2686  |  Link
pinterf
8> merge_avx2.cpp
Help?
Comment on git copied here:
Strange, here
https://msdn.microsoft.com/en-us/lib...v=vs.120).aspx
__m128i _mm_stream_load_si128(__m128i *p);
is mentioned, and you are seeing that.
However, in my smmintrin.h I can see:
__m128i _mm_stream_load_si128(const __m128i*);
Maybe the header (smmintrin.h) has been changed since vs2013?
Try removing the 'const' from cast body.
Old 12th December 2016, 13:56   #2687  |  Link
mcjordan
Thank you, pinterf. I'll try asap.
Old 12th December 2016, 18:42   #2688  |  Link
ajp_anton
ajp_anton's Avatar
But for example if I want to join three Y8 clips into RGB, I have to specify "RGB" twice: planes="RGB", pixel_type="RGB".
This is how I'd imagine it working:
version.converttoy8
combineplanes(last,last,last,planes="RGB")
"CombinePlanes: too many target planes (3)! Target video plane count is 1!"
Why would the target have 1 plane, when I obviously want to map them into RGB?
version.converttoy8
combineplanes(last,last,last,planes="RGB",pixel_type="RGB")
I know that just "RGB" is not a pixel type, but consequently there's no way to specify just "RGB". It has to be precise in both planar/packed as well as bits. If I write it wrong, the function won't convert it to what I wrote, it will just say it's wrong. Why ask me to specify it if it already knows what it's supposed to be?
version.converttoy8
combineplanes(last,last,last,planes="RGB",pixel_type="RGBP8")
"Source has no such plane "U""
Why not use the only available plane as default, if I don't purposefully try to access an unexisting plane?
version.converttoy8
combineplanes(last,last,last,planes="RGB",source_planes="YYY",pixel_type="RGBP8")
This I'm assuming is finally supposed to work, but it crashes both VirtualDub (filtermod) and x264, the two programs I have that can handle Avisynth. Anything I can do to help identify the cause? This is with r2343, both 32- and 64-bits.
Old 12th December 2016, 19:11   #2689  |  Link
pinterf
version.converttoy8
version.converttoy8
version.converttoy8
Don't forget that RGBP8 is unknown for these softwares.
In order to make it work or get it shown in VirtualDub, you have to do a ConvertToRGB32().
As the special case when inputs are greyscale, it is indeed a good idea not defaulting source planes to YUV, your proposal is logical.
edit:
version.converttoy8
I know that just "RGB" is not a pixel type, but consequently there's no way to specify just "RGB". It has to be precise in both planar/packed as well as bits. If I write it wrong, the function won't convert it to what I wrote, it will just say it's wrong. Why ask me to specify it if it already knows what it's supposed to be?.
This is a very special rule: Wwen inputs are greyscale _and_ planes="RGB" (or RGBA) then the output could be planar RGB or RGBA, keeping the bit-depth of the input clips.
Old 12th December 2016, 20:31   #2690  |  Link
ajp_anton
ajp_anton's Avatar
Oh. And I could've sworn it crashed also with a ConvertToYV12, but now it doesn't. Nevermind then =).
Do we need a special rule here? If planes has any permutation of RGB or RGBA, there's only one thing to do: combine the inputs. Throw an error if bitdepths or resolutions don't match.
If it has any permutation of YUV or YUVA, same thing, except also check if the U/V resolutions match 4:2:2 or 4:2:0 before throwing an error.
Also, I would go even further by making source_planes always default to Y if the source clip is YUV(A), because that's what you're usually processing before combining them, and that's what you're actually seeing when previewing anything. If there's at least one RGB source, then require the source_planes string.
Old 12th December 2016, 20:49   #2691  |  Link
pinterf
RGBA and YUVA permutations are working already.
But this latter idea can be confusing, e.g. you can specify only one YUV clip, and the default source plane order is YUV, which is good enough I think.
There is a rule that you can specify less input clips, and if no more clips found in the list, but there are still planes to process, the last one will be automatically used further on.
Old 13th December 2016, 03:26   #2692  |  Link
ajp_anton
ajp_anton's Avatar
How so? Or did you misunderstand?
If planes="RGB" or "BARG" or "AVYU" (weird examples), why does it need pixel_type? There's only one string that's ever going to be accepted by the filter anyway, why not use that? Does there exist a scenario where the user can actually choose between two different pixel_type strings?
Old 13th December 2016, 06:51   #2693  |  Link
pinterf
Sorry, I mean they are working because meanwhile I have done it. Specify planes=RRG or GBRA, it will map to planar rgb. pixel_type is good only when single Y or A target is specified or want a target with alpha plane but not filling all 4 planes.
Old 14th December 2016, 03:16   #2694  |  Link
fAy01
Why do I have to convert my encode from 10bit to 8bit? It worked fine before. Please help
Old 14th December 2016, 04:34   #2695  |  Link
real.finder
re did same test here http://forum.doom9.org/showthread.ph...mc#post1745799 but with MP_Pipeline and after edit this http://publishwith.me/ep/pad/view/ro.rDkwcdWn4k9/latest
MP_Pipeline("""
### platform: win64
ColorBars(width=720, height=480, pixel_type="RGB32")
ConvertToYV12()
QTGMC(InputType=1, Ezdenoise=2)
LSFMod(strength=66)
gradfun3()
Prefetch(12)
and get ~38 fps
My Avisynth Stuff
Old 14th December 2016, 07:52   #2696  |  Link
real.finder
I note that GScriptClip is incompatible with avs+ mt, with mode 2 not work at all and with mode 3 gave random scriptcilp errors
My Avisynth Stuff
Old 14th December 2016, 09:07   #2697  |  Link
jpsdr
If Prefetch is used in a script, is it possible in a plugin to retrieve the value used?
If yes:
- how?
- Is this value allready avaible when AvisynthPluginInit3 is called, or should i have to wait to be within the Create_xxxx to have the value?
Old 14th December 2016, 09:28   #2698  |  Link
Groucho2004
Groucho2004's Avatar
If yes:
- how?
See here and here.
Groucho's Avisynth Stuff
Old 14th December 2016, 11:02   #2699  |  Link
jpsdr
This answer half... But i still can make tests, to chek if using GetProperty(AEP_FILTERCHAIN_THREADS) inside AvisynthPluginInit3 will allready give me the correct value.
Old 14th December 2016, 11:14   #2700  |  Link
Groucho2004
GetProperty() is part of IScriptEnvironment2 and not supported by IScriptEnvironment as far as I know. That should answer your second question.
