Old 14th September 2007, 00:11   #101  |  Link
The Scientist
The Scientist's Avatar
This error appears only if you use limited account
Incorrect. I only use admin accounts. Also tried using XP SP2 compatibility and right-click run as admin.
The Scientist is offline   Reply With Quote
Old 14th September 2007, 00:31   #102  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
If I created Guest or Standard User account I indeed got the same error. But If I switched to admin or set XP SP2 compatibility error did not show. Run as admin does not work in my case either. BTW Do you use UAC?
deets
when you get that error try to open info.txt from:
C:\Users\<your user name>\AppData\Local\Temp\RipBot264temp\job1\info.txt
I need to know exactly what values are inside that file. (first is framecount ,below should be framerate...)
Atak_Snajpera is online now   Reply With Quote
Old 14th September 2007, 00:33   #103  |  Link
The Scientist
Are you accessing the registry during the form load?
Old 14th September 2007, 00:40   #104  |  Link
deets
i have 189789;23.976044
deets is offline   Reply With Quote
Old 14th September 2007, 00:46   #105  |  Link
Atak_Snajpera
deets
It should be
189789
23.976044
not 189789;23.976044 in single line ?!?!?!?!
What do you see in getinfo.avs?
Yes. I check if AviSynth,FFDshow,Haali are installed by finding keys.
Old 14th September 2007, 00:55   #106  |  Link
The Scientist
Blank out all the registry stuff in the form load as a test, I'll try it, at least it will narrow the problem down.
Old 14th September 2007, 00:58   #107  |  Link
deets
ok. well i have 2 machines, one with vista 64 and that works fine with 1.5.0
this laptop, which is XP, is the one that gives the floating point error though... using the same file to test, so its something about XP?
how can i get you that info from XP?
edit, nice clean post
ok i found the file on XP and its only MKV that give me the floating point error, the info.txt has this:
64699
23.976044
0
0
0
from 2 mkv files
avi and mpg work fine on xp, all work fine on vista
Old 14th September 2007, 01:11   #108  |  Link
Atak_Snajpera
The Scientist
I think I found solution
I had function CheckRequiredSoftware() in OnCreate event. If function is moved to OnShow event error does not show
deets
The easiest way is to search for info.txt
Old 14th September 2007, 01:20   #109  |  Link
deets
64699
23.976044
0
0
0
from 2 mkv files
Old 14th September 2007, 01:22   #110  |  Link
Atak_Snajpera
There is something wrong. Those zeros mean that audio wasn't detected by avisynth/decoder. (third row shows frequency, fourth is audio channels and the last one is length) Show me your getinfo.avs file.
see you tommorow....time to bed...ZzZZzzZzZzzzzz....
Old 14th September 2007, 02:19   #111  |  Link
deets
DirectShowSource("C:\downloads\sample.mkv")
WriteFile("C:\DOCUME~1\OWNER~1.YOU\LOCALS~1\Temp\RipBot264temp\job1\info.txt","Framecount")
WriteFile("C:\DOCUME~1\OWNER~1.YOU\LOCALS~1\Temp\RipBot264temp\job1\info.txt","Framerate")
WriteFile("C:\DOCUME~1\OWNER~1.YOU\LOCALS~1\Temp\RipBot264temp\job1\info.txt","AudioRate")
WriteFile("C:\DOCUME~1\OWNER~1.YOU\LOCALS~1\Temp\RipBot264temp\job1\info.txt","AudioChannels")
WriteFile("C:\DOCUME~1\OWNER~1.YOU\LOCALS~1\Temp\RipBot264temp\job1\info.txt","AudioLength")
Trim(0,-1)
ok its sorted, if i stop ffdshow handling AC3 using liba52 then all works as it should and i get this in my info.txt
1472
23.976044
48000
2
2946946
I have no clue if this was causing the other issues for people with the same problem...
thanks, would have not worked it out had it not been you pointing out the three zeros were the sound
Old 15th September 2007, 17:58   #112  |  Link
weaver4
Love your tool.
Could you make a Apple TV profile?
Thanks,
weaver4 is offline   Reply With Quote
Old 17th September 2007, 01:16   #113  |  Link
Atak_Snajpera
AppleTV profile (Right click and select Save link as)
http://yamf.republika.pl/RipBot264/[... ] AppleTV.ini
Let me know if It's working or not.
Old 17th September 2007, 07:36   #114  |  Link
mrpijey
Has anyone any idea how to make any of the resulting files to play in Quicktime? I even used the iPod profile, but no matter what profile I use i get an error in Quicktime when trying to playback the file:
"Error -2041: an invalid sample description was found in the movie"
mrpijey is offline   Reply With Quote
Old 17th September 2007, 20:46   #115  |  Link
weaver4
One other small suggestion.
After I set a profile, I set autocrop, then I want to set the width. I either want 320 for an ipod or 640 for my computer; but I never know the height.
On avi.net you just set the width and the height is calculated for you automatically. Can you do the same thing? The author of avi.net (the Scientist) is on this thread, maybe he can tell you how he did it.
Old 17th September 2007, 21:02   #116  |  Link
Atak_Snajpera
Peace of cake The main problem is that I don't have enough spare time in this week. I barely have one day off on thursday .
BTW You didn't answer my question about AppleTV profile.
mrpijey
I think it's time to start use real software. Quicktime is a peace of ...
Old 18th September 2007, 00:10   #117  |  Link
mrpijey
Of course, I rather use MPC or VLC But I wanted something that would work with iTunes on my PC and on my Mac =) All tests I have done with megui, ripbot264 and other apps has been crappy at best. It's been either messed up brightness, too low quality or a file format that can't be played on anything except Windows... And from what I have seen, a Quicktime compliant file seems to be the only common denominator on PC, Mac and iPhone/iPod Touch. Since I want to be able to use all these devices to playback the movie with GOOD quality, without getting too large files (1.5GB for a regular movie).
But if you guys got any good recommendations for me then please teach me What I want to be able to do with the movie is preferrably:
- Playback on Mac (using iTunes and Frontrow)
- Playback on PC (using Media Center and/or iTunes)
- Playback on iPod Touch
Getting stuff to work on Media Center is the easiest part, since Windows is so forgiving with it's options to accept codecs. Quicktime won't even do divx/xvid, and that's the only option for a decent media center front end on the Mac (Frontrow, which uses iTunes, which uses Quicktime).
The alternative is to keep all DVD:s in their original format (4,7-9.4GB MPEG2), and that's a whole waste of space when there are much better codecs out there... and this still would make the Mac a very useless moviebox
So if you got any ideas...
Old 18th September 2007, 02:39   #118  |  Link
weaver4
mrpijey
Thanks, I will try the AppleTV profile tomorrow (moving my computer today). Won't have my Apple TV till this weekend though.
Old 20th September 2007, 01:56   #119  |  Link
weaver4
I went to get this link tonight and it was not there. Did it get moved?
Old 20th September 2007, 11:26   #120  |  Link
Atak_Snajpera
My account has been locked
http://www.mediafire.com/?bfbb4zz0ynm
