Old 10th November 2003, 16:32   #41  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Originally posted by Human_USB
I have the report file but what am I looking for...... all I see is stuff like this;
[list]
| + Block group
| + Block (track number 1, 1 frame(s), timecode 825.367s)
| + Frame with size 438
| + Reference block: -42.000ms
What you're looking for are lines similar to these but with "track number 3" (I'm guessing that track number 3 is the subtitle track, if not search for "track number n" where n is your subtitle track number). If there are such lines with the timecodes that match the ones on your .srt file (entries 63-67) then the subtitles are muxed correctly.
You can also compress report.txt and send the compressed file to me (moritz@bunkus.org) so that I can take a look at it.
Latest MKVToolNix is v83.0
Mosu is offline
Old 10th November 2003, 20:00   #42  |  Link
raistlin2k
Posts: n/a
IT WORKS!!
BUT, actually MPC shows only the Language name given by LCID code, not the "name"-tag containing individual data like "comment by Ridley Scott", shouldn't the (any) player show this one as well in the stream-select-dialog?? Otherwise I see only "English" 2 times, quite useless.
Raist
Old 10th November 2003, 20:06   #43  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Originally posted by raistlin2k
IT WORKS!!
Raist
Which name? Could you send me your .idx file, please? (moritz@bunkus.org)
Mosu is offline
Old 11th November 2003, 01:42   #44  |  Link
KpeX
KpeX's Avatar
Wow, MKVToolnix / Matroska continues to become more and more versatile. Kudos to Mosu, Gabest, and the rest of the team.
Is there any guideline for what kind of compression ratio can be achieved with zlib compressed vobsub's ?
KpeX
Audio FAQs: General | BeSweet | SVCD/MP2 | MP3 | Vorbis | AC3 | DTS | AAC
Linux Audio/Video FAQ
KpeX is offline
Old 11th November 2003, 04:40   #45  |  Link
Human_USB
Plug me in...
Human_USB's Avatar
E-Mail sent..... hope you get it.
Chaos in order or order in chaos..... which are you?
Human_USB is offline
Old 11th November 2003, 07:43   #46  |  Link
raistlin2k
Posts: n/a
Mosu, why the IDX file?
I'm talking about the "name"-tag of audio-streams. Sorry that I didn't write this in my last post clearly.
Your GUI for mkvmerge shos a tooltip over the name-tag that it an be used for things like "director's comment" so I did so, but no players shows this at all.
Thanks
Raist
P.S. Do you still want my IDX-file?
P.P.S. Just tried to convert several OGM + IDX into MKV, noticed that it doesn't work with one movie where there is only one sub inside the .SUB, under stream 8.
Old 11th November 2003, 09:18   #47  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
You will usually get a reduction to 40-50% of the original size:
10338304 2003-10-29 18:09 vs/ally1.sub
 6740374 2003-11-10 19:15 nocomp.mkv
 4576954 2003-11-10 19:15 zlibcomp.mkv
Explanation: VobSubs, when extracted with VSRip, still contain a complete MPEG PS (or was it TS?). Additionally this stream uses padding up to 2kb block boundaries wasting a lot of space (well on a DVD it doesn't matter, but for us it does). We only need the SPU packets so we discard the MPEG PS. The resulting SPU packets are put into a Matroska file either uncompressed (nocomp.mkv) or compressed with zlib at its best compression setting (zlibcomp.mkv).
So just by discarding the SPU packets we gain approx. 35%. The SPU packets themselves can be compressed further down to ~66% of their original size.
I haven't done extensive checking but other streams should result in similar numbers. This VobSub contains of eight streams for a 42minutes episode of Ally McBeal.
Mosu is offline
Old 11th November 2003, 09:20   #48  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Uuups. I though there was some obscure "name" tag in the .idx for the VobSub file which mkvmerge did not convert to a Matroska track name.
No, I don't need the .idx then
Sorry, I don't know enough about Windows, DirectShow etc. in order to place blame. It's either the splitter's or the player's fault, obviously.
Is this .idx+.sub small? If so, can you send it to me please? moritz@bunkus.org
Mosu is offline
Old 11th November 2003, 13:39   #49  |  Link
Pasqui
Error while muxing
Hi Mosu,
using mkvtoolnix 0.7.5, I got the following error while muxing a XviD video, a vorbis audio and a VobSub file:
Using AVI demultiplexer for D:\XMEN2_DISC1\VIDEO_TS\X-Men 2.avi. Opening file. This may take some time depending on the file's size.
+-> Using video output module for video track ID 0.
Using OGG/OGM demultiplexer for D:\XMEN2_DISC1\VIDEO_TS\XMen2 AC3 T01 3_2ch 448Kbps DELAY -24ms - New - [10.11.2003] - [12.46.09].ogg.
OGG/OGM demultiplexer (D:\XMEN2_DISC1\VIDEO_TS\XMen2 AC3 T01 3_2ch 448Kbps DELAY -24ms - New - [10.11.2003] - [12.46.09].ogg): using Vorbis output module for stream 19749.
Using VobSub subtitle reader for 'D:\XMEN2_DISC1\VIDEO_TS\X-Men 2.idx' & 'D:\XMEN2_DISC1\VIDEO_TS\X-Men 2.sub'.
+-> Using VobSub subtitle output module for subtitle track 1 (language: en).
+-> Using VobSub subtitle output module for subtitle track 2 (language: fr).
Opened 'D:\XMEN2_DISC1\VIDEO_TS\X-Men 2.mkv' for writing.
progress: 176/192449 frames (0%)
progress: 350/192449 frames (0%)
progress: 523/192449 frames (0%)
progress: 109774/192449 frames (57%)
progress: 109943/192449 frames (57%)
progress: 110100/192449 frames (57%)
mkvmerge FAILED with a return code of -2147483641.
Any idea of what's going on ?
BTW, thanks for your great tools !
Pasqui.
EDIT: the failure seems related to the zlib compression because the multiplexing was successful without compression.
EDIT2: the error appears randomly: after several tries and failures at different percentage done, I successfully muxed the file with subtitles compressed.
Pasqui is offline
Old 11th November 2003, 14:58   #50  |  Link
Human_USB
Plug me in...
Human_USB's Avatar
@Mosu
Did you get the file?
Old 11th November 2003, 17:17   #51  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Re: Error while muxing
Originally posted by Pasqui
...progress: 110100/192449 frames (57%)
Unfortunately mkvmerge does not print any error at all, it just exits with a strange exit code. The last line is from mmg which just tells you that mkvmerge died. So I have no idea what's going wrong.
Ah, that's interesting. Could you please send me those vobsubs so that I can try to recreate this problem? moritz@bunkus.org
Mosu is offline
Old 11th November 2003, 17:19   #52  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Yes. Your Matroska file contains a VobSub subtitle track, but the stuff you posted above is from a .srt file. I assume that the .srt was made from the same VobSubs so that the timecodes match.
Anyway, the report.txt you sent me DOES contain the entries for the timecodes you haven't seen, so I'd say that mkvmerge has done its job correctly and that it's a playback problem.
Mosu is offline
Old 11th November 2003, 17:25   #53  |  Link
DamnedSoul
why Virtual Dub Mod don't open mkv file created with mkvmerge of mkvtoolnix 0.7.5?
(i haven't tried with previous version)
... only love can bring us forward ... [Ark - Just a little]
DamnedSoul is offline
Old 11th November 2003, 17:28   #54  |  Link
tiki4
tiki4's Avatar
I think this was posted in the beginning of this thread:
VirtualDubMod was compiled against a version of libmatroska that doesn't yet support the new lacing scheme mkvmerge 0.75 uses. VirtualDubMod has to be updated.
tiki4
tiki4 is offline
Old 11th November 2003, 17:37   #55  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Exactly, but I think Cyrius did release a new version yesterday. Anyway, VDubMod will probably never handle VobSubs.
Mosu is offline
Old 11th November 2003, 17:48   #56  |  Link
Suiryc
Exactly.
I also said that it won't be able to edit matroska files using encryption/compression.
And I think it won't edit files with vobsub tracks either.
Really ? Where ?
There is no released version IIRC. Changes up to VirtualDub(-MPEG2) 1.5.9 are in the CVS, but we still need to update a few VirtualDubMod specific things.
Concerning the Vobsub tracks I don't know if it will ever be supported.
Suiryc is offline
Old 12th November 2003, 20:55   #57  |  Link
lighty
@Mosu
Could you please look at those threads http://forum.doom9.org/showthread.php?s=&threadid=64649 and to http://neuron2.net/ipw-web/bulletin/...hp?p=2510#2510
and decide if you're willing to add timecodes import option in mmg GUI since it is real pain to experiment with VFR and having to type everything so many times?
After parsing Telecide decision log on the basis of some parameters vfrparser produces timecodes as per your specs.
First example of TNG clip
# timecode format v1
assume 29.97
#Consecutive frames threshold 2
0,293,29.97
294,296,29.97
297,1138,23.976
second example of TNG clip
assume 29.97
#Consecutive frames threshold 1
0,0,23.976
1,293,29.97
294,294,23.976
295,296,29.97
297,1138,23.976
I also do hope that syntax 294,294,23.976 is correct. If not I will limit simillar-type consecutilve threshold to minimum of 2 (like it is in first example).
lighty is offline
Old 12th November 2003, 21:06   #58  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
You mean a simple file selection entry for the --timecodes command line switch? Sure, no problem.
This is correct - this would mean that there's exactly one frame with a duration of 1/23.976 seconds.
Mosu is offline
Old 12th November 2003, 21:24   #59  |  Link
Palikrovol
Palikrovol's Avatar
where can i read about "variable frame rate" and for what can be use it?
It has something to do with changing the frame rate of the movie when changing the audio stream (from 23.976 fps audio stream to 25 fps audio stream)? (is this possible?)
Thanks
Palikrovol is offline
Old 12th November 2003, 22:53   #60  |  Link
ssjkakaroto
ssjkakaroto's Avatar
Thanks
i couldnt find the first thread where 120fps videos were discussed but here are some threads:
http://forum.doom9.org/showthread.ph...variable+frame
http://forum.doom9.org/showthread.php?s=&threadid=64314
http://forum.doom9.org/showthread.php?s=&threadid=63290
ssjkakaroto is offline
