10th July 2009, 18:04 | #41 | Link | |
10th July 2009, 18:05 | #42 | Link | |
Hardware Aspirin
not sure what you mean. But I know that CPU encoding is where its at, and GPU encoding is still in its infancy and can't compete with x264 in its current form. When I see slides from Nvidia and ATI and review sites that GPU encoding is 5 times faster than CPU encoding and there is no mention of image quality, that makes me kinda angry.
So I'm just trying to provide proof. Quote:
That's a good idea but as in business they say, you can't make everyone happy, I fear I would get flamed for that too for trying to advertise mediacoder
Stream video on web in your quality |
10th July 2009, 18:25 | #43 | Link | |
St Devious however chose to set bframes 1 before changing anything else, eventhough with his goal of comparing quality at the same speed (i.e. maximum possible speed), he should've enabled cabac and subpixel refinements, since those would've most likely caused x264 to encode at the same speed as cuda (assuming his system behaves the same as mine does). |
10th July 2009, 18:49 | #44 | Link | |
Hardware Aspirin
10th July 2009, 18:52 | #45 | Link | |
Software Developer
In other words: Instead of starting from the defaults, we start from the selected preset. But that's all. Maybe you are thinking of the new "--profile" option (which is applied after the explicit options). That option does overwrite your settings, as it enforces a certain level!
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 10th July 2009 at 18:56. |
10th July 2009, 19:08 | #46 | Link |
Hardware Aspirin
ok then I will try to set the same option as the preset ultrafast in the MeGUI x264 settings GUI
11th July 2009, 05:00 | #47 | Link | |
MediaCoder author
I mean the people claiming that you intend to make these benchmarks to advertise something. I hope they can be a bit open-minded.
So every word should be neutral here.
When things work together, things work. MediaCoder makes audio and video things work. |
11th July 2009, 06:03 | #48 | Link |
Hardware Aspirin
I'm comparing now with best quality that each encoder can provide at a certain bitrate.
Using this video 1080p VBR Video Quality Test Streams Sony HDW-F900 footage, 1080p@25, 18 Mbps average, 30 Mbps peak in a 35 Mbps Transport Stream (259,534,064 bytes) on this page http://www.w6rz.net/ Encoding both encoders to 4Mbps and 6 Mbps. Using 2 pass unrestricted HQ profile in Megui, would extra quality provide some better quality ? And here are the settings for CUDA encoder in Mediacoder. Please let me know what to set to compare to match x264
Stream video on web in your quality Last edited by St Devious; 11th July 2009 at 06:07. |
11th July 2009, 06:12 | #49 | Link |
MediaCoder author
The CUDA H.264 encoder in current release doesn't support 2-pass mode yet.
11th July 2009, 06:29 | #50 | Link | |
Hardware Aspirin
But How can i configure the CUDA encoder to provide maximum quality ? Here is an update, click on the images to get full size 1920x1080 image x264 @ 6 Mbps CUDA @ 6 Mbps Source Mediainfo Source Code:
Video ID : 49 (0x31) Menu ID : 1 (0x1) Format : MPEG Video Format version : Version 2 Format profile : Main@High Format settings, Matrix : Default Duration : 2mn 7s Bit rate mode : Variable Bit rate : 32.5 Mbps Nominal bit rate : 30.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16/9 Frame rate : 25.000 fps Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.628 Stream size : 493 MiB (92%) x264 Code:
Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L5.1 Format settings, CABAC : Yes Format settings, ReFrames : 5 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 2mn 7s Bit rate mode : Variable Bit rate : 6 000 Kbps Maximum bit rate : 16.6 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16/9 Frame rate mode : Constant Frame rate : 25.000 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.116 Stream size : 90.9 MiB (100%) Writing library : x264 core 68 r1179M 96e2229 Encoding settings : cabac=1 / ref=5 / deblock=0:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=6000 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00 Code:
Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L5.1 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 2mn 7s Bit rate mode : Variable Bit rate : 6 035 Kbps Maximum bit rate : 42.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 4/3 Frame rate mode : Constant Frame rate : 25.000 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.116 Stream size : 91.4 MiB (100%)
Stream video on web in your quality Last edited by St Devious; 11th July 2009 at 14:03. |
11th July 2009, 07:28 | #51 | Link |
@St Devious: your x264 and your CUDA Screenshot link to the same picture,... (CUDA should be: http://www.picturepush.com/public/1958118)
11th July 2009, 14:04 | #53 | Link | |
Hardware Aspirin
thanks, corrected it now. what do you mean ?
11th July 2009, 14:20 | #54 | Link |
Software Developer
He talks about luminance levels, I think!
http://forum.doom9.org/showthread.php?t=143689 But I'm not so sure whether this is a level problem, because the "black" intensity looks identical in both screenshots. Typically you would get "black" vs. "dark gray" when comparing pictures of different luminance levels, but that's not the case here. Looks more like something is wrong with the color intensities. Look at the red shirt and the cyan bag!
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 11th July 2009 at 14:25. |
11th July 2009, 14:26 | #56 | Link |
Hardware Aspirin
MeGUI had me add ConvertToYV12() at the end of script, is that a problem ?
11th July 2009, 14:54 | #57 | Link |
Software Developer
Nope. That's because x264 doesn't accept anything but YV12() data. But you should use the very same source script for both encoders
11th July 2009, 15:12 | #58 | Link | |
Hardware Aspirin
Will encode with an avisynth script when i get home tomm. btw what about Stan's suggestion of using Mediacoder to encode with both CUDA and x264 ? that wa decoders should be the same.
Stream video on web in your quality Last edited by St Devious; 11th July 2009 at 15:17. |
11th July 2009, 15:23 | #59 | Link | |
Software Developer
I'd go with Avisynth to be 100% sure that the source data is identical for both encoders! The less steps there are between your source and the encoder, the less things can corrupt your results. Directly feeding the source into the encoder from Avisynth (using the identical script) is the most reliable method.
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 11th July 2009 at 15:29. |
11th July 2009, 15:30 | #60 | Link | |
Hardware Aspirin
How does the decoding happen ? Like what will Mediacoder and MeGUI use to decode the avisynth file ? And how does the avisynth file decode the .ts source file ?
