25th June 2009, 12:17 | #1342 | Link |
HDConvertToX author
you can join multiple string using dot "."
unfilter().undot().blur() EDIT: use the live update BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 Last edited by buzzqw; 25th June 2009 at 12:22. |
25th June 2009, 14:31 | #1344 | Link |
buzzqw
I finally found out why HDC was putting a green frame at the beginning of every video. The culprit was MT avisynth. If you don't use MT, there will not be a green frame added to the beginning of the video. BTW, the "use multithreaded avisynth" box doesn't work. It will always use MT if you have MT.dll in system32. Last edited by Chengbin; 25th June 2009 at 14:36. |
25th June 2009, 14:34 | #1345 | Link |
HDConvertToX author
i never got this green frame, and i use mt always
maybe related to other filters you use ? or decoder ? VGG
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
25th June 2009, 14:51 | #1346 | Link | |
I'm using eac3to, on ffdshow build 3013 (or something like that) |
25th June 2009, 14:55 | #1347 | Link |
HDConvertToX author
so.. edit your hdconverttox.ini and set "Force AviSynth MT=0"
BHH
25th June 2009, 18:42 | #1351 | Link | |
HDConvertToX author
if you want start it later.. simply launch queue.bat later for temp folder there is a option in hdconverttox.ini, but isn't recommend since it will empty all files in temp folder BHH
25th June 2009, 19:36 | #1352 | Link |
AVIMUX error
HDConvertToX v.1.9.403.3232 report Input File: c:\documents and settings\User\desktop\temp\05.mpg ( C:\Documents and Settings\User\Desktop\Temp\05.mpg ) Codec Video: mpeg Width / Heigh : 704 / 576 Framerate / Framecount: 25.000 / 60242 Duration(hh:mm:ss): 0:40:10 Aspect Ratio: 1.3334 Resized resolution: 640 / 480 Crop Values : 0:0:0:0 Start Video Configuration -> Encoding Settings: XviD in AVI SAP Compatibility: On Encoding Preset: 7 Final Size: 350 Priority: idle Denoise Level: Super Light Video Handling: Use Best Decoder -> End Video Configuration Start Audio Configuration -> Audio Codec: MP3 Audio Audio Bitrate/Quality: 160 Audio Channels: 2 MP3 Mode: abr Audio handling: Use Eac3to as demuxer Keep only core: On -> End Audio Configuration Full Audio List-> (*** mean selected) NONE *** 2: mp2, 2.0 channels, 256kbps, 48khz, 3ms -> End Full Audio List Full Subtitle List-> (*** mean selected) *** NONE -> End Full Subtitle List Mux Subtitle in MP4/MKV file: On Start Advanced AviSynth -> ColorMatrix: On -> End Advanced AviSynth Start Queue -> prompt $d $t $_$P$G "C:\Programmi\MPC-Homecinema.1018\HDConvertToX\applications\dgindex.exe" -FO=0 -OM=0 -YR=2 -AIF=[c:\documents and settings\User\desktop\temp\05.mpg] -OF=[C:\Programmi\MPC-Homecinema.1018\HDConvertToX\temp\movie] -exit -minimize "C:\Programmi\MPC-Homecinema.1018\HDConvertToX\applications\eac3to.exe" "c:\documents and settings\User\desktop\temp\05.mpg" 2: stdout.wav -down16 -down2 | "C:\Programmi\MPC-Homecinema.1018\HDConvertToX\applications\lame.exe" - -h --abr 160 "C:\Programmi\MPC-Homecinema.1018\HDConvertToX\temp\hdencodertox-pid2.mp3" "C:\Programmi\MPC-Homecinema.1018\HDConvertToX\applications\xvid_encraw.exe" -progress 50 -i "C:\Programmi\MPC-Homecinema.1018\HDConvertToX\temp\hdconverttox_05.avs" -avi "C:\Programmi\MPC-Homecinema.1018\HDConvertToX\temp\hdconverttox_05.avi" -max_bframes 1 -nopacked -vhqmode 1 -quality 6 -max_key_interval 125 -lumimasking -bquant_ratio 150 -framerate 25.000 -threads 3 -bitrate 1055 -pass1 -turbo "C:\Programmi\MPC-Homecinema.1018\HDConvertToX\applications\xvid_encraw.exe" -progress 50 -i "C:\Programmi\MPC-Homecinema.1018\HDConvertToX\temp\hdconverttox_05.avs" -avi "C:\Programmi\MPC-Homecinema.1018\HDConvertToX\temp\hdconverttox_05.avi" -max_bframes 1 -nopacked -vhqmode 1 -quality 6 -max_key_interval 125 -lumimasking -bquant_ratio 150 -framerate 25.000 -threads 3 -bitrate 1055 -pass2 "C:\Programmi\MPC-Homecinema.1018\HDConvertToX\applications\AVIMux_GUI.exe" -stdin mux0.amg -> End Queue AviSynth Script -> Working with files: C:\Programmi\MPC-Homecinema.1018\HDConvertToX\temp\hdconverttox_05.avs Setmemorymax(512) SetMTMode(2,0) mpeg2source("C:\Programmi\MPC-Homecinema.1018\HDConvertToX\temp\movie.d2v") LanczosResize(640,480,0,0,-0,-0) ColorMatrix(d2v="C:\Programmi\MPC-Homecinema.1018\HDConvertToX\temp\movie.d2v") hqdn3d(1) -> End AviSynth Script AVIMux-Gui Script > CLEAR LOAD C:\Programmi\MPC-Homecinema.1018\HDConvertToX\temp\hdconverttox_05.avi LOAD C:\Programmi\MPC-Homecinema.1018\HDConvertToX\temp\hdencodertox-pid2.mp3 SELECT FILE 1 ADD VIDEOSOURCE SET OPTION CLOSEAPP 1 SET OPTION OVERWRITEDLG 0 SET OPTION DONEDLG 0 SET OPTION ALL AUDIO 1 SET OPTION ALL SUBTITLES 1 SET INPUT OPTIONS SET OUTPUT OPTIONS WITH SET OPTION OPENDML 0 RECLISTS 0 AUDIO INTERLEAVE 1 FR AVI ADDJUNKBEFOREHEADERS 0 PRELOAD 512 END WITH START C:\Programmi\MPC-Homecinema.1018\HDConvertToX\hdconverttox_full_05.avi -> End AVIMux-Gui Script
sorry for my bad english |
26th June 2009, 02:30 | #1354 | Link |
I think i've found the problem.
I do not know why, but KasperskyInternetSecurity2010, make skip the encode video. After dgindex, passes directly to the avimuxgui, freezing it. Now I must find the solution to this problem. K.I.S.2010 don't alert me of nothing.....strange. I'm sorry for "false positive".
26th June 2009, 09:49 | #1355 | Link | |
Why is it not recommended? |
26th June 2009, 10:17 | #1356 | Link |
HDConvertToX author
before launching queue.bat make sure that temp folder cointains all avs script.
BHH
26th June 2009, 18:00 | #1357 | Link |
Fighting spam with a fish
Small Bug Report. Using the latest 1.9.403.3232.
It appears that HDConvertToX still thinks that there is an error when loading a file after that error has been corrected and the "problem" file loads fine in MPC. To replicate: 1) Take a .vob file. 2) Turn OFF ffdshow mpeg2 codec. Or any other directshow mpeg2 filter you have. Make sure that there is no way the file can be played through directshow. 3) Load .vob file into HDC. 4) Analyze. A problem will occur. MPC will display an error saying that "DirectShowSource: RenderFile, the filter graph won't talk to me." 5) Don't close HDC! 6) Renable Mpeg2 decoding (in ffdshow or otherwise). 7) Re-analyse your file. It will say that there is a problem, but when MPC loads to display the problem, it loads the .vob file correctly and plays just fine. Let me know if I need to be more precise. |
26th June 2009, 21:11 | #1358 | Link |
HDConvertToX author
Hi All!
it's a busy today! my second son, my first daughter Isotta is born! BHH
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui |
