8th June 2011, 02:05 | #242 | Link |
hey kostik, I like your code but I think that is not going to work.
download dither and write the next code: Code:
Dither_convert_8_to_16() SmoothCurve16("0-0;32768-36768;65535-65535") ditherpost()
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread |
11th June 2011, 22:47 | #244 | Link |
I want to try processing in 16bit. I assume the filter doesn't support working from 8bit input to 16bit output, right?
Would this be correct to get the MSB/LSB stacked clip, or do I need to use ditherXpre (even though I don't need any actual dithering at that point)? Code:
video = last stackvertical(video,blankclip(video,color_yuv=$000000)) # and smoothtweak... smoothtweak16(contrast=0.84) |
11th June 2011, 23:08 | #245 | Link |
Yes, Dither_convert_8_to_16() does exactly that.
Anyway DitherXPre doesn't do any dithering. Dithering is the inverse operation (from 16 back to 8 bits).
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding |
17th June 2011, 01:10 | #247 | Link |
Interesting, I'll have to add support for your stacked kludge into my HDR tools. I use separate clips for msb/lsb because to me it didn't make sense to stack them; most filters wouldn't produce valid results if applied the same way to both bytes.
If you need to pass a highbit video in one clip, that's the only way of course. |
29th June 2011, 21:38 | #248 | Link |
Ok I have a bit of a problem getting SmoothAdjust to co operate with writing out 16bit image sequences via avs2yuv and imagemagik.
Basically to get SmoothAdjust 16bit functions to work it appears I need to add 'Dither_convert_8_to_16()' otherwise I get the same split frame as Kostick as posted above. BUT adding 'Dither_convert_8_to_16()' works so far until I try to use: Dither_convert_yuv_to_rgb(matrix="601", tv_range=false, cplace="MPEG2", chromak="bicubic", output="rgb48yv12") And then pipe out via avs2yuv to Imagemagick I get this error: Dither_resize16: Cannot allocate buffer memory. And no images get written. But if I remove the: 'Dither_convert_8_to_16()' and hash out the SmoothAdjust stuff I can write 16bit image sequences. Is SmoothAdjust msb/lsb stack not be implemented the same as Dither 1.9? |
29th June 2011, 22:20 | #249 | Link |
Your problem comes from Dither_convert_yuv_to_rgb() running very quickly out of memory (it uses Dither_resize16() internally). I'm currently working on this issue, to make Dither_resize16 less memory hungry.
30th June 2011, 08:52 | #251 | Link |
It would be cool if you added lsb_in feature for inputting 16bits stacked clips. Besides correcting chroma in debug, in case it is a bug.
edit: Also there seems to be a bug in UV planes with smoothcurve16. It is less red than default smoothcurve. Maybe it is related to dither, who knows...
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 3rd July 2011 at 10:19. |
3rd July 2011, 15:18 | #252 | Link | |
LaTo INV.
3rd July 2011, 16:57 | #253 | Link |
#~ SmoothCurve(\ #~ ycurve="0-9;16-30;128-128;233-220;255-255",\ #~ ucurve="0-16;255-240",\ #~ vcurve="0-16;255-240",\ #~ interp=50,smooth=10,show=false,limiter=false) SmoothCurve16(\ ycurve="0-2304;4096-7680;32768-32768;59648-56320;65535-65535",\ ucurve="0-4096;65535-61440",\ vcurve="0-4096;65535-61440",\ interp=50,smooth=10,show=false,limiter=false)
3rd July 2011, 17:10 | #254 | Link | |
LaTo INV.
If you want exactly the same, add 65280-65280 before 65535-65535. It works? PS: Why "Besides correcting chroma in debug, in case it is a bug."? What is the problem? Last edited by LaTo; 3rd July 2011 at 18:28. |
3rd July 2011, 17:24 | #255 | Link |
Im just doing what the readme suggests:
For example: SmoothCurve("0-255;128-128;255-0") --> SmoothCurve16("0-65535;32768-32768;65535-0") If I change it to 65280 I get an error: *curve have not a correct synthax! The debug graph for UV planes is different from yours. yours
3rd July 2011, 18:29 | #256 | Link | ||
LaTo INV.
SmoothCurve16(\ ycurve="0-2304;4096-7680;32768-32768;59648-56320;65280-65280;65535-65535",\ ucurve="0-4096;65535-61440",\ vcurve="0-4096;65535-61440",\ interp=50,smooth=10,show=false,limiter=false) Quote:
4th July 2011, 02:02 | #257 | Link |
Thank you, but result is the same (in other sources too). Does it work with you?
edit: smoothcurve16 doesn't have any benefit over default smoothcurve, right (quality wise)? I realised I dont need it since after that Im processing in 8b. In any case it's still worth a look on why that happens.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 4th July 2011 at 07:10. |
4th July 2011, 12:20 | #258 | Link | |
LaTo INV.
SmoothCurve16(\ ycurve="0-2304;4096-7680;32768-32768;59648-56320;65280-65280;65535-65280",\ ucurve="0-4096;65280-61440;65535-61440",\ vcurve="0-4096;65280-61440;65535-61440",\ interp=50,smooth=10,show=false,limiter=false) Last edited by LaTo; 4th July 2011 at 17:42. |
4th July 2011, 15:06 | #259 | Link |
Are you theorizing, or are you getting instead right results? It doesn't work for me either.
You know the insights of SmoothAdjust so you'll probably want to start matching smoothcurve internal dither algorithm with Dither's one, and start from there for testing, and discard either SmoothAdjust or Dither. Although I have just tested a simple resize with Dither vs Spline36 and chroma is alright, so it doesn't look like its fault. (It could be the way it "records"/deals chroma to LSB, cretindesalpes should have more to say on this...) By the way, overriden parameter in smoothcurve16 are.... "dither" only? Maybe it would be a good idea to delete that option.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 4th July 2011 at 15:11. |
4th July 2011, 17:53 | #260 | Link | |||
LaTo INV.
Seriously, I don't think that the problem is the dithering. (Have you tried with "dither=-1"?) Quote:
msb[x] = (BYTE)( smooth[x]>>8 ); lsb[x] = (BYTE)( smooth[x] ); Last edited by LaTo; 10th July 2011 at 09:49. |
