19th April 2014, 22:15 | #20043 | Link |
Hmm, I don't find Information if my Intel Processor supports quicksync?
http://ark.intel.com/de/products/657...Cache-3_30-GHz Here is a log from Bold 3D, i cancelt after 6 hours when it startrt encoding the next file... Code:
[04.19.14] BD Rebuilder v0.47.04 (beta) [17:15:15] Source: BOLT_00001 - Input BD size: 32,03 GB - Approximate total content: [01:36:21.775] - Target BD size: 22,95 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Quality: Highest (Very Slow), ABR - MVC 3D Output Mode enabled - Decoding/Frame serving: FRIMDecode - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 - Audio [2] set to default. - Resuming from previously started job. [17:15:19] PHASE ONE, Encoding - [17:15:19] Processing: VID_00002 (1 of 2) - [17:15:20] Reencoding video [VID_00002] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 71.283 frames - Bitrate: 29.994 Kbs - Using FRIMEncoder for MVC encoding - [17:15:20] Reencoding: VID_00002, Pass 1 of 1 - [22:47:27] Video Encode complete - [22:47:27] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - Track 4353 (deu): Reencoding audio to AC3... - [22:52:02] Processing: VID_00003 (2 of 2) - [22:52:02] Extracting A/V streams [VID_00003] - [22:57:44] Reencoding video [VID_00003] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 67.341 frames - Bitrate: 29.866 Kbs - Using FRIMEncoder for MVC encoding - [22:57:44] Reencoding: VID_00003, Pass 1 of 1 |
19th April 2014, 22:47 | #20044 | Link | |
20th April 2014, 05:04 | #20045 | Link | |
If you fail to plan; you plan to fail, would you not agree? Think about it. |
20th April 2014, 09:53 | #20046 | Link |
Damn That's sound not good.... but there are so many possible speedups like CUDA or Hyper-Threading??
I actually tried a new recode with the two FRIM-Parameters but with no effect: Speed: 0,19x ETA: 04:08:15 FPS: 4,53 |
21st April 2014, 11:33 | #20052 | Link |
(2D) - Decoding/Frame serving: X264/LAVF - Quality: Ultra High Quality (Extremely Slow) 4-6fps (2D) - Decoding/Frame serving: FRIMSource - X264/LAVF Quality: Ultra High Quality (Extremely Slow) ~3fps (3D) - Decoding/Frame serving: FRIMSource - 70-80fps (u=2; u= 1:quality - 7:speed) |
21st April 2014, 13:57 | #20053 | Link | |
Are those speeds using ABR with X264 (like FRIM), or are they pass-2 speeds from a 2 pass encode? JMHO, but ultrahigh quality is almost always overkill. That's why it is "hidden" from the menu. It might be more closely related to u=1 in FRIM. But since I couldn't see a difference between 2 and 1 for the increased time, I didn't enable u=1 in BD-RB. [Edit] I just tested X264/LAVF with "Ultra High Quality" in one pass ABR mode on a 1920x1080 source, and I'm getting about ~11-14fps. I get slightly higher with DGDecNV. I'm not sure if 2x speed increase would qualify as "a lot". With "High Quality" mode, which is as high as I ever use, I get 28fps on the same source (using LAVF). Based on your results, I may want to consider adding an option to allow FRIM to be used as the encoder on 2D sources (for use by those with Quick-Sync capabilities). Last edited by jdobbs; 21st April 2014 at 15:04. |
21st April 2014, 19:11 | #20057 | Link | |
