31st March 2008, 17:22 | #1781 | Link |
@wunschkind
Had this happen too, thought it was related to closing the dgindex stats window, you can try dgindex 1.4.9 or projectx. 1.4.9 was replaced because somebody had problems with a certain source.
31st March 2008, 18:20 | #1782 | Link |
hi stax,
after copying the files from the network machine to my local machine i can use staxrip and dgindex ... i´m getting some strange popups after the installation of the new beta: staxrip says that the avisynth plugin directory is in a unfortunate location (but it´s under programs\staxrip\) then staxrip tries to copy the directory ...staxrip\settings\applications\avisynth plugins to staxrip\settings\applications\avisynth plugins (the same ...) and fails clicking on OK staxrip says that it changed the avisynth directory. "while running with admin rights, the location can be changed in the setting" (i´m admin) what do you think? wunschkind |
31st March 2008, 18:31 | #1783 | Link |
@wunschkind
The settings dir is within the programs dir, I'll have to make changes to make this impossible to happen. To workaround meanwhile, please close StaxRip, move the settings dir somewhere else, run StaxRip, it'll ask now for the location of the settings, point it to the new location.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 31st March 2008 at 18:34. |
1st April 2008, 16:21 | #1785 | Link | |
1st April 2008, 18:24 | #1786 | Link |
resolution vs bitrate
Hi, I am ripping DVDs to 2 cds using xvid codec.
Since my size is fixed after the initial analysis I am trying lower the resolution to imrprove the bitrate. But bitrate won't change. I never run compression check. Is bitrate is locked irrespective of changes in resolution. Btw I am using latest staxrip build. Thanks for any info. |
3rd April 2008, 06:13 | #1792 | Link | ||||
The url for unofficial builds is always the same. Sometimes these builds are more stable than official builds, sometimes less. The current unofficial build is fairly stable, the next one will have a couple of new features which always come with a lot refactoring so it'll be less stable. I have a script to post images to forums, I just make a screenshot with greenshot pressing Alt+Print, it saves a image on the desktop, I right-click the image and select upload, it uploads the image and copies the url including forum markup to the clipboard. Code:
Public Class MainClass <STAThread()> _ Public Shared Sub Main() Application.EnableVisualStyles() Try Using wc As New Net.WebClient Dim target = "://planetdvb.net/non_drupal/forum_images/" wc.Credentials = New Net.NetworkCredential("********", "********") Dim s = "" For Each i In EnvironmentHelp.GetArgs s += "[IMG]" + "http" + target + i.Path.Name + "[/IMG]" + CrLf wc.UploadFile(New Uri("ftp" + target + i.Path.Name), i) Next Clipboard.SetText(s) End Using Catch ex As Exception Msg.Show(ex.ToString) End Try End Sub End Class Quote:
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 3rd April 2008 at 06:25. |
3rd April 2008, 08:46 | #1793 | Link | |
3rd April 2008, 09:27 | #1794 | Link | |
The build has a lot code changed but not thoroughly tested so please take care, especially the 2 latest entries (at the top) in the changelog.
3rd April 2008, 09:42 | #1795 | Link | |
is there a way to stop this from popping up? |
3rd April 2008, 11:05 | #1796 | Link | |
3rd April 2008, 13:00 | #1797 | Link | |
vote for stax |
3rd April 2008, 13:28 | #1799 | Link |
lastest x264 build on x264.nl has info for AQ parameters in --help
maybe you could add them to the command line presets or in the gui? Code:
--aq-mode <integer> How AQ distributes bits [2] - 0: Disabled - 1: Avoid moving bits between frames - 2: Move bits between frames --aq-strength <float> Reduces blocking and blurring in flat and textured areas. [1.0] - 0.5: weak AQ - 1.5: strong AQ |
3rd April 2008, 13:49 | #1800 | Link |
>> "staxrip doesnt support reading files from DVD" <--- doesnt make any sense." >> from the support page: describe a scenario to emphasize the usefulness of the feature and if possible provide help, information and resources that might be useful to implement the feature. The better the support I get the more features I can add. This applies not only to StaxRip but to any software, not every request makes sense so I have to understand first what exactly you are trying to achieve. >>> stax, from the videohelp software description: "With StaxRip you can easily convert your DVD's ..." As well as emphasis on the word "RIP" [I am talking not about ripping tho, but just reading normal VOBs off a non-encrypted DVD.] How can you state "With StaxRip you can easily convert your DVDs.." if i am not even able to read/access a simple VOB off a DVD? If staxrip now (for some bizarre reason) requires me to first copy all the VOBs to HD and only is able to read them from HD...this totally eludes me and i dont understand the sense of this at all! Add: For clarification: I tried to read-in some VOBs and convert a DVD to Xvid/H264, some really, really basic task. But i got this error message that staxrip cannot read right off DVD <---?!?!!? Last edited by Flexy; 3rd April 2008 at 13:51. |
gui, h.264, h.265, hevc, mkv, x264, x265 |
