2nd July 2011, 20:02 | #9801 | Link |
I see no error message in your log.
2nd July 2011, 20:27 | #9802 | Link |
Its not causing errors, but its making my BDMV moves hiccup throughout the movie. When you wave your mouse over the other copies they just go away like when something just crashed and it was a copy in the task bar you waive mouse over it and disappears off your screen. Is the 2nd pass trying to open a copy and overwrites itself and crashes
3rd July 2011, 01:43 | #9805 | Link | |
would it be possible to add this option and correct frame rate (like when 30fps sometimes gets detected as 24fps, and video ends up longer then video) right into future version in the GUI? |
3rd July 2011, 07:21 | #9806 | Link | |
3rd July 2011, 11:15 | #9807 | Link |
Hi there, I've installed [AviSynth v.2.5.8 MT, 64-bit] , [ffdshow_rev3914_20110629_clsid_x64.exe] , and [Haali Media Splitter 32-bit]. I actually wanted to get the full potential by installing the 64-bits, however when I try to open RipBot264, I get "Not Installed" for FFDshow is it because it must be 32 bit? Because if FFDshow has to be 32-bit then i have to make AviSynth 32-bit also, because AviSynth requires and reccomends FFDshow x64.
Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away. Last edited by AiDz0r; 3rd July 2011 at 11:21. Reason: wth? |
3rd July 2011, 12:52 | #9808 | Link |
Everything MUST be 32 bit!!!
3rd July 2011, 15:25 | #9809 | Link |
oh nooo! Should i just uninstall everything then reinstall in 32 bit?
Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away. |
3rd July 2011, 15:26 | #9810 | Link | |
...something like that is what I'd do. I'm not really sure how the disc is setup make sure after ripbot scans the disc that you are choosing the right playlist(s) (scan with bdinfo) there might be a playlist to play ALL of the episodes. if so...and if you're choosing that playlist, that'd account for why you end up with one big file contain all the episodes =) |
3rd July 2011, 22:33 | #9811 | Link | |
I figured this out with "Lost". |
4th July 2011, 12:29 | #9813 | Link | |
4th July 2011, 19:40 | #9815 | Link | |
4th July 2011, 19:41 | #9816 | Link | |
It seems Warner does it like that as this is the same with Chuck, Fringe, etc... |
5th July 2011, 06:24 | #9817 | Link |
@Atak_Snajpera:
I finally got it working. It was all my fault. It didn't really occur to me that I should double check my profile settings until the exact same problem started happening with a another rip. The thing that bugged me the most was how cryptic x264's error messages seem. Like Code:
x264 [error]: could not open input file `1' |
7th July 2011, 05:22 | #9818 | Link |
Hi all
I have just started with BR so I may have missed something simple here very easily. I apologise if this has been asked, but this thread is 100+ pages long and is too long to read through on a 64K connection. I am trying to use ripbot on an XP SP3 machine. I had to install Java, FFDshow etc, to get it to load up. WHen I start a job, it runs for a couple of seconds and finishes. Know I know its not a super computer so I went looking into the logs and found this Error: The source file 'D:\Temp\RipBot264temp\video.264' could not be opened successfully, or retrieving its size by seeking to the end did not work. Checking the directory, there is indeed no video.264 file there. How do I fix this problem, what have I done wrong. Thanks Mick Last edited by znelbok; 7th July 2011 at 05:25. |
7th July 2011, 13:46 | #9819 | Link | |
Cheers, Damian Blog - http://www.adigitalhomeblog.com MSS.net blog (contributing editor) - http://www.mediasmartserver.net |
