22nd January 2018, 11:33 | #26981 | Link |
Menu Colors
I'm confused by the MENU_CUSTOM_COLOR setting, as it appears to do nothing.
When I set MENU_ACTIVE_COLOR to "0xA7A7A7", in order to have a gray active text, the non-active text is not the value of MENU_CUSTOM_COLOR. It is a little (very little) darker value of MENU_ACTIVE_COLOR, resulting in one not being able to see a difference in the active/non-active colors (unless one changes the selection and then it is barely visible). I set MENU_CUSTOM_COLOR=green and that resulted in no green non-active text. How do I set the non-active text so that the difference can be seen? Maybe a MENU_NONACTIVE_COLOR setting? If set to "", then the BDRB default value is used. By having a MENU_NONACTIVE_COLOR setting, then the menu can have three colors: non-active, active and selected (default white). |
22nd January 2018, 15:01 | #26982 | Link | |
MENU_CUSTOM_COLOR=0x40FF30 MENU_ACTIVE_COLOR=CUSTOM Of course you could get the same thing by just using: MENU_ACTIVE_COLOR=0x40FF30 Note: There is a setting called MENU_INACTIVE_COLOR. Last edited by jdobbs; 22nd January 2018 at 15:15. |
22nd January 2018, 15:20 | #26983 | Link | |
Failed to Read Sectors 11471296 - 11471327 - Reason: Logical Block Address out of Range Code:
Found end of Disc! - Sector: 11471296 With that said... it has absolutely nothing to do with BD Rebuilder. It might be a good question for the IMGBURN forum Last edited by jdobbs; 22nd January 2018 at 15:26. |
22nd January 2018, 15:41 | #26984 | Link | ||
25th January 2018, 05:30 | #26985 | Link | |
26th January 2018, 01:22 | #26986 | Link | |
Since we comment on this topic UFHD and talking about this, and just out of curiosity if I download a movie in UFHD and then pass it with the next version of bd rebuilder to Full HD, there is a possibility in the final result (considering the source is an ufhd), the fhd quality result could be better than if I do the same from a bd50 fhd to BD25? I really hope you can undestand it thankyou jdobbs for do it |
27th January 2018, 13:15 | #26993 | Link |
@jdobbs
Just a friendly reminder (I know it's not on your current priority list...): Any chance that the --sar bug which I reported here will perhaps be fixed in an upcoming release? My point is that imported 720x576i 4:3 footage should be encoded with --sar 12:11 rather than 10:11. Depending on the playback scenario the wrong --sar can produce a distorted picture which is a pity because all the rest is just perfect Thank you. Last edited by Sharc; 27th January 2018 at 13:24. |
27th January 2018, 21:33 | #26994 | Link |
Funnnny! I've noticed your cunning linguistic ability, and wouldn't peg you has every other sentence F-er. My girlfriend is pretty skilled that way also, but Whhhhhew, she can produce some Fing tones if someone is really overboard to get a point across to them to stop. She usually receives some surprising looks because she's pretty creative and a looker....and does a lot with winks and slight expressions.
Orrrrr...were you meaning F from the other end, while engaged in conversations? ;-)
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! |
27th January 2018, 22:05 | #26995 | Link | |
28th January 2018, 01:51 | #26996 | Link |
Small bug in alternate output
Hi jdobbs,
I just ran into a small issue backing up Star Wars (Epidsode 5) into MP4 container. BDRB created a file with forced subs for ENG and hardcoded them. My setting is SUPTITLE=1 of course and FORCED_SUB_LANG=deu;ger; DEU and GER had no forced subs, but a ENG commentary stream had some. They were extracted to a 9999 file. Disabling SUPTITLE for that title did the trick. If you need some more info please let me know. ggtop |
28th January 2018, 03:19 | #26997 | Link | |
28th January 2018, 11:51 | #26998 | Link | ||
That brings me to a request: As the anylysis of the correct subtitle stream can be done only after extraction would it be possible to add a (hidden) option to stop BDRB from starting the first video Encoding segment? Background: As long as the first video segment hasn't been encoded successfullly I still have the chance to enable a subtitle stream and to turn it on if the subtitles aren't flagged as forced and then to continue... Right now I wait for the extraction/indexing to be completed and press "Abort" for subtitle analyzing. 50% of my discs do not have forced subtitles. They have a stream of their own without flags. EDIT: Such an option would only be useful (for me) in non batch mode. ggtop Last edited by ggtop; 28th January 2018 at 13:39. |
29th January 2018, 20:37 | #26999 | Link |
Ohh, Mr. Mascot, Mr. Guru?
Any time someone tells me I think too much (or meditate too much)...my alarms begin to chime a warning towards that person. ;-)
