Old 7th March 2019, 14:49   #141  |  Link
Gravitator
Why is the -speed-mode 3 option missing in the updated ffmpeg? > Https://forum.doom9.org/showthread.p...99#post1867899
Win10x64, Xeon E5450, GTX 750 2GB, DDR3 8GB.
Gravitator is offline   Reply With Quote
Old 8th March 2019, 12:49   #142  |  Link
jonatans
The updated ffmpeg in https://forum.doom9.org/showthread.p...99#post1867899 uses the public master branch of xvc from https://github.com/divideon/xvc while -speed-mode 3 is so far only available in our private development branch.
Jonatan Samuelsson
Co-founder and CEO at Divideon
www.divideon.com | xvc.io
jonatans is offline   Reply With Quote
Old 22nd June 2019, 07:46   #143  |  Link
augman000
Hi Jonatan,
Is it possible to build an ffmpeg (or if not, an xvcenc/xvcdec) that would run on XP 32-bit? I have an older PC that I would like to do some testing on.
In my earlier tests, xvc is very efficient for low bitrate, low resolution situations. On this older PC, xvc seems ideal.
Any assistance would be much appreciated. If this can be built, I will run some tests and share my results here. Hopefully that will assist in development.
augman000 is offline   Reply With Quote
Old 24th June 2019, 07:46   #144  |  Link
LigH
LigH's Avatar
According to one of the developers I just contacted via IRC, the support for Windows XP in ffmpeg has been dropped quite a while ago (with version 4), to improve the threading.
In addition, many linked libraries today will have their own restrictions (I remember x265 requiring special options, other codecs may not even care). So I doubt you will find any recent ffmpeg version still supporting it.
New German Gleitz board
Old 2nd July 2019, 18:27   #145  |  Link
benwaggoner
Are you looking to test encoding or playback? I don't think 32-bit XP encoding is material to anyone anymore unless the goal is to benchmark encoding on an Atom-based security camera or something.
For decoding, yeah, that can make sense as a low bar. But for a forthcoming codec, the market is already 64-bit dominant. Pretty much everything has shipped as 64-bit for a while now. Looking at the latest Steam hardware survey, 96% of gaming PCs are on a 64-bit OS. The results would be interesting, but even if xvc barely worked on 32-bit, I don't know if that would negatively impact its prospects.
Ben Waggoner
My Compression Book
Old 7th July 2019, 10:34   #146  |  Link
jonatans
Hi Jonatan,
Hi augman000, sorry for the slow response.
It is possible to build xvc for 32 bit. For Visual Studio 14 2015, you can follow the steps at https://github.com/divideon/xvc but replace
cmake -G "Visual Studio 14 2015 Win64" ..
with
cmake -G "Visual Studio 14 2015" ..
I've uploaded 32-bit binaries for Windows here if you would like to try it out: https://drive.google.com/file/d/1lcG...ew?usp=sharing
This is built from the master branch of https://github.com/divideon/xvc.
I would be happy to hear how the experiment turns out.
Jonatan Samuelsson
Old 4th September 2019, 11:24   #147  |  Link
Gravitator
Привет!
Are there any improvements in coding? Please share ffmpeg assembly (I follow the blurring of b-frames).
Old 14th May 2020, 13:28   #148  |  Link
LigH
LigH's Avatar
I believe xvc may not compile well in GCC 10.1:
In file included from ../src/xvc_common_lib/transform_data.cc:22:
../src/./xvc_common_lib/transform_data.h:32:16: error: 'int16_t' does not name a type
   32 |   static const int16_t kDct2Transform4[4][4];
../src/./xvc_common_lib/transform_data.h:33:16: error: 'int16_t' does not name a type
   33 |   static const int16_t kDct2Transform8[8][8];
Old 15th May 2020, 12:27   #149  |  Link
jonatans
Thanks LigH for reporting.
The problem was fixed in https://github.com/divideon/xvc/comm...67a85f4e858cd4
Jonatan Samuelsson
Old 17th October 2020, 13:33   #150  |  Link
Gravitator
Looks like XVC moved to x265 as --hevc-aq.
Old 19th October 2020, 18:16   #151  |  Link
benwaggoner
Huh? Where did you get that?
I thought that VVC picked up some xvc features and contributions.
Ben Waggoner
My Compression Book
Old 20th October 2020, 07:30   #152  |  Link
LigH
LigH's Avatar
Now that would be some remarkable inheritance.
Old 20th October 2020, 18:02   #153  |  Link
benwaggoner
In fact jonatans told me about how VVC got a some good xvc features at IBC last year. The specifics have faded with time, alas.
Ben Waggoner
My Compression Book
Old 20th October 2020, 21:11   #154  |  Link
jonatans
I don't know anything about this. I don't think there is any relation between xvc and --hevc-aq in x265.
Thanks Ben. Yes, in VVC there is the concept of "general constraint info" which makes it possible to indicate at the top level if some coding tools and features are disabled in the bitstream. This concept is inspired by the "restriction flags" in xvc which serves exactly the same purpose.
In EVC there are actually more features directly brought in from xvc such as a mode for determining the output order of pictures (Picture Order Count derivation) and a mode for implicit derivation of which reference picture to use for inter prediction.
/ Jonatan
Jonatan Samuelsson
codec, compression, video codec, video encoding, xvc
