Old 14th May 2011, 06:00   #1  |  Link
scifiguy
Fast transcoder to convert to iPhone format?
Anybody have suggestions on a utility that can take a number of different formatted videos and quickly convert them to be usable on an iPhone? Ideally, something i can just point to a directory of files and have it convert them all..
Any ideas?
scifiguy is offline   Reply With Quote
Old 14th May 2011, 10:36   #2  |  Link
7ekno
XviD4PSP v6, setup the format to convert to, drag and drop files and away you go ... it should also have an iPhone profile ...
As for fast (irrespective of quality) check out Badaboom (but not sure it does batches) ...
7ek
7ekno is offline   Reply With Quote
Old 22nd August 2011, 00:37   #3  |  Link
isapc
Badaboom 2 does batch encoding.
http://badaboomit.com/node/537
isapc is offline   Reply With Quote
Old 25th August 2011, 14:41   #4  |  Link
vineet89
Isnt decoding support better
Badaboom utilizes GPU number crunching for fast transcoding. But with increasing capability of processors, wont you want to build something which can play a wider variety of formats rather than pushing everything to H.264??
vineet89 is offline   Reply With Quote
converter, ipad, iphone, transcode
