Old 16th December 2013, 04:11   #1  |  Link
Nozdrum
Can x264 keep the attachments from the input file?
Is it possible to force x264 to keep the attachments from the source files? like the subtitles, so that remuxing the output file is not needed anymore. Any idea?
Nozdrum is offline   Reply With Quote
Old 16th December 2013, 12:20   #2  |  Link
kypec
User of free A/V tools
kypec's Avatar
x264 is pure video encoder, it doesn't care about any audio, subtitle or another data tracks but video. You should use MKVToolnix to remux your x264 output to include attachments, audio, subtitles or any other metadata you need.
kypec is offline   Reply With Quote
Old 16th December 2013, 16:54   #3  |  Link
Selur
Selur's Avatar
@Nozdrum: You could use ffmpeg with libx264 instead of the x264 binary. ffmpeg support passing through audio and subtitles while only encoding the video.
Old 17th December 2013, 01:17   #4  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
It's always better to remux to optimize the indexing (and therefore seeking). If using mkv, mkvtoolnix is also gives slightly smaller files than ffmpeg's muxer, but it's usually a trivial difference.
If you aren't concerned about seeking performance, the ffmpeg route is reasonable.
Old 23rd December 2013, 06:45   #5  |  Link
Nozdrum
I think mkv merge is still the best, probably I'll stick with it.
attachments, mux, output file, subtitles, x264
