16th October 2006, 20:06 | #321 | Link |
This tool is amazing! I've just been learning/using Avisynth for a month now and I don't know how I missed AvsP until now.
For the first time, this weekend, I was able to actually see instant differences between plugins that I couldn't decide on before. Now I feel like I am really using the best items and settings for my material in my script. I really love this program. THANKS! |
17th October 2006, 00:18 | #323 | Link | ||
17th October 2006, 03:23 | #324 | Link |
@Alain2
I tried reproducing the bug (it seemed like a unicode filename issue), but didn't succeed. Could you tell me exactly how it occurs, and could you also upload your options.dat file? Hopefully that will give me a better idea of what's going on, thanks. |
19th October 2006, 06:23 | #325 | Link |
Small suggestion: Could you add a "Copy Script" to the Edit or context menu that would copy the currently selected script / lines in their final form - without the slider definition but with their current defined values. That way you can post the script on the net without having to remove the slider definition or save it explicitly to a file
19th October 2006, 06:33 | #326 | Link |
A couple of Problems
I wanted to report a couple of problems using this fantastic program.
When using a script for HDRagc where multible lines for varables are used, on a bright scene, you can see a brigther border or a darker square covering about 80% of the screen. It varies on different workstations. The solution was to have all the varibles for a plugin on just one line. The second problem pops up after a session has been operating for a long time. The preview screen in the "AVSp's" window appears correct but when that script is saved or called by F6, the image in VD-dub is dark and distored. The solution is to quit AVSp and load the session again. Richard |
19th October 2006, 08:15 | #327 | Link | ||
In case anyone was wondering, I'm working hard on the upcoming release, I'm about 90% done with rewriting all the layout code (which will hopefully solve problems some people are having with large resolution videos). I'd estimate the new release to be out sometime during the weekend.
19th October 2006, 18:48 | #328 | Link |
ангел смерти
Have you considered having an .avsp extension for files with all the markup? And saving .avs without (or with the markup commented out)? As it currently stands it's kind of annoying to lose all the markup everytime I close it, especially since I often use old scripts as starting points for new ones. ^^; Sorry, I know that's just one more thing to worry about.
If the new layout has the capability to show the video on a second monitor (as a window that gets dragged around or whatever), that would be awesome. |
19th October 2006, 19:14 | #329 | Link | |
.............................................................................................................................. Good AVSp Session http://www.uploading.com/files/N0RG6...aster.ses.html ............................................................................................................................... ............................................................................................................................... http://www.uploading.com/files/K9KCY...AVSp.jpeg.html All Sliders work OK, Export "Script" picture quality fails after hours of using same session. Problem Preview http://www.uploading.com/files/PNOR2...AVSp.jpeg.html Reloading session solves the problem ................................................................................................................................ ................................................................................................................................ Good AVSp Window http://www.uploading.com/files/K9KCY...AVSp.jpeg.html 80% Square in background http://www.uploading.com/files/3KD0JVBR/Bad.jpeg.html Problem seen when more than one line is used to call varibles See below AVISource("C:\hdragc.avi") LoadPlugin("E:\AVS\Plugins\AGC.dll") HDRAGC(coef_gain=2.0,reducer=0.3) HDRAGC(coef_sat=0.8,min_gain=1.5,avg_window=1,corrector=.7) HDRAGC(max_gain = 4.0 black_clip = 0.1, shift_u = -10 ............................................................................................................................................................... Richard Last edited by rfmmars; 19th October 2006 at 19:39. |
19th October 2006, 22:06 | #330 | Link |
Hey, just started using this today. Looks like a pretty awesome program. I've come across what looks like a small bug, I hope this hasn't been mentioned already as I haven't read through the huge thread. If you have the preview hidden, maximize the window, and toggle the preview on, the maximized window jumps down and to the right slightly. Minimizing and then bringing it back up returns it to its proper place, oddly enough.
By the way, would an option to scale all text down or up by a percentage or something be possible? Like CTRL & + and CTRL & - in SciTE if you've ever used that. It looks like I'd have to set up the size for 13 font options whenever I wanted to change it otherwise. |
19th October 2006, 22:31 | #331 | Link | ||||
@rfmmars Thanks for the files and info, I'll try and figure out what's going on pronto. Quote:
19th October 2006, 23:03 | #332 | Link | |
ангел смерти
The session option looks good, I'll give it a couple days and see if it works well (it should, that's basically how I use editplus anyway). |
19th October 2006, 23:25 | #333 | Link | |
And by the way, I believe the Ctrl+mouse scrolling shortcut works in most web browsers, try increasing the font size to gigantic proportions on a friend or co-worker's pc for good clean fun . |
21st October 2006, 03:00 | #335 | Link | |
Btw I begin to get used to the video being in the same window than the editor ; only thing required really for me now is the "on the fly" resize of the video in this preview, if possible not affecting the sliders. The resize within the script trick is good but everytime I want to change the clip it means to reload the script.. an independant bicubicresize-like would be better One more thing for your already huge todolist ^^ Can you add a factor to be used in the preview window for the seek bar ? Like default=1 -> as is at the moment; changing it to 3 for instance would make the seek slider go to mod(3) positions only when manually moved (but still move frame by frame when using the arrows shortcuts). This would help me when I use the interleave function to compare clips, to always start from the same clip.. Can't wait to see this new layout now ++ |
21st October 2006, 13:33 | #336 | Link | ||||
Neither can I . The layout code is pretty much done, still has some weird behavior I'm trying to iron out, so hopefully the new release will be out in a day or two, we'll see. Last edited by qwerpoi; 21st October 2006 at 13:37. |
23rd October 2006, 21:07 | #338 | Link | |
New version 1.3.0, download from the AvsP download page, you can use this mirror if there are any problems. Here's the changelog:
I'm still working on the details of the new layout, as it still exhibits some strange behavior occasionally, sometimes the divider may be set to an unexpected position, etc. If you have any serious problems (hopefully unlikely), I left the download link for v1.2.1 available on the first post. As always, report back with any bugs or suggestions. Last edited by qwerpoi; 23rd October 2006 at 21:17. |
23rd October 2006, 22:37 | #339 | Link |
This is great . One thing though, when I load 720p file, the script window is getting covered by video window and slider window. Here is an example. Is this an expected behavior?
p.s. I'm dreaming about undockable preview window
(!sig) Last edited by krisq; 23rd October 2006 at 22:40. |
23rd October 2006, 23:10 | #340 | Link | |
