29th February 2012, 19:31 | #12402 | Link |
Dithering in LAV is only applied if its necessary, and if you use madVR, it should never be necessary.
29th February 2012, 19:56 | #12403 | Link |
The main issue that seems to be the problem for the MAJORITY of 0.8.1 users now is that the display changer doesn't "change" the display refresh rate in the OSD consequently not changing the V-sync which basically nulls the whole function of display changer. The only way around this that seems to work for me is that if you have set display changer to restore the refresh rate AFTER the media player has closed and if you have a dual monitor setup then you can drag the video to the other monitor and back to update the display refresh rate in the OSD which resets the V-sync to the proper rate.
29th February 2012, 20:37 | #12404 | Link | |
*EDIT* I've just had it freeze with copy to backbuffer set to flush, I have yet to have it freeze however with 'after last render step' set to flush as well. Freeze report below. http://www.mediafire.com/?yor8i34dirdisu4 Last edited by ryrynz; 1st March 2012 at 07:28. |
29th February 2012, 21:10 | #12405 | Link |
madshi, given most of the media are 16-235, wouldnt it be more accurate to the source for displaying, to setup tv to limited RGB (16-235) and madvr to TV levels?
If so, how would you configure coreAVC as for Output and Input levels? (0-255), (16-235) or Auto detect. I think you said you use coreavc for h264 decoding so just curious how you have set it up. Im going crasy to be sure to have all the luminance configuration filters correctly set up |
29th February 2012, 22:54 | #12406 | Link | |
If input is just TV, it outputs just TV, setting everything up to forced TV range wouldn't make any difference. And apart from this, range conversion shouldn't be visible to the human eye. |
29th February 2012, 23:00 | #12407 | Link | |
Sadly CoreAVCs options are not really self-explanatory, i would recommend to set input and output in CoreAVC to 16-235, that'll ensure it doesn't touch the values (independent of what you want to output later) For whats recommend to display, i would go with 0-255. During the YUV->RGB conversion, you end up with floating point values, if you have more integers to spread them on, you can get more precision.
1st March 2012, 07:35 | #12410 | Link |
Found a bug, if Bicubic settings are selected before Softcubic the drop down options still only show the Bicubic settings, it's not till you go to one of the other algorithms then to Softcubic that it displays properly.
1st March 2012, 07:55 | #12411 | Link | |
A sample of such a file might be useful.
1st March 2012, 08:01 | #12412 | Link | |
----------------- Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings, CABAC : Yes Format settings, ReFrames : 8 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 42mn 37s Bit rate : 546 Kbps Maximum bit rate : 2 010 Kbps Width : 720 pixels Height : 404 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.078 Stream size : 166 MiB (81%) Writing library : x264 core 120 r2164 da19765 Encoding settings : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Encoded date : UTC 2012-02-23 17:58:50 Tagged date : UTC 2012-02-23 18:19:44 Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177 |
1st March 2012, 08:07 | #12413 | Link |
That doesn't change the fact that if it was encoded directly into the video streams headers, either LAV or madVR would manage to read it from there. Therefor, its not encoded in there.
Maybe its for some reason set in the container and not in the stream, but if thats the case, there is no way to let the renderer know either way.
1st March 2012, 11:00 | #12414 | Link | |
2nd March 2012, 03:44 | #12415 | Link | |
Will these be dithered by LAV ? FFMpeg decodes at least some of them as YUV and uses swsscale to convert YUV than finally to RGB.... |
2nd March 2012, 04:09 | #12416 | Link |
Crash report + complete log-file.
Problem : if MadVR is in FSE mode, it crashes MPC-HC (+itself ?) upon switching to the next/previous file. I made a playlist from 2 files and let it play in FSE. The first file plays nice, but at the end when opening the second, I end up with a black screen. Only <ctrl>+<alt>+<del> brings back some live, nothing else works, probably because of FSE. Happens only in FSE, no problems in maxim. windowed mode. Happens both when switching is done automatic (playlist) and manual (next file using mouse or keyb.) Win7 SP1 / Nvidia gtx-570 / latest 295.73 drivers / CPU i7-970 LAV v0.48 / MPC-HC 4111 (also tested with PotP-> same issue) Things already tried : driver rollback to previous known "good" version 290.36, different vers. MPC, PotPlayer, all kind of combination for flushing modes FSE, change que-sizes,...) Crash-report + MadVR log : http://www.mediafire.com/?g7ty003uxo9k7vj Last edited by Pat357; 2nd March 2012 at 04:12. |
2nd March 2012, 04:16 | #12417 | Link |
Does it happen if you play the files a second time? (After forcing MPC-HC to be closed of course.) To me it plays OK the second time, but happens again after refresh rate change, either automatic or manual. I thought it might have been an AMD thing, happened with 5770 and 4670. Using D3D11 fixes it for me.
MSI MAG X570 TOMAHAWK WIFI, Ryzen 5900x, RTX 3070, Win 10-64. Pioneer VSX-LX503, LG OLED65C9 |
2nd March 2012, 16:10 | #12418 | Link |
MPC-HC Developer
I bought DVB-T tuner on chip IT6135 and unfortunately it isn't working with madVR as renderer in MPC-HC. With EVR or Haali Renderer works good, but with madVR it fails to load. I know that there are more important things to change in madVR, but if you could add this to your to do list, and someday maybe you will fix it
Log: http://dl.dropbox.com/u/16282309/mad/madVR.DVB-T.7z Last edited by kasper93; 2nd March 2012 at 16:45. |
2nd March 2012, 17:26 | #12419 | Link |
Hello guys...this is the first time I have tried madvr and it blew me away!
I have been using MPC for a long time with ffdshow, avisynth scripts etc... I have to try again today but unless my eyes were deceiving me yesterday, the quality is amazing! The color, detail , everything looks super. I am planning to read a lot of this thread but one thing but I was wondering if there is a recommended card or cards list? I only do 1080p bluray ripped to my main server and unless I am blind , this gives better quality than my Samsung player. So, I have a HD2400Pro (maybe HD2600Pro need to verify) and this is only for HTPC so I am trying not to break the bank of course. Any recommendations? PS The reason I ask is because, I am not sure if its a card issue but it looks more like a sync issue where it is playing very smoothly then suddenly it hiccups and then goes fine again. My projector is running at 48fps (47.9xx) and I tried with Reclock as well. It apparently could be just at the beginning or for some movies only but I did this too late so couldnt try a lot. I will have to verify. I had to use DXVA (native) for this card or it would be a stutter fest. Last edited by shaolin95; 2nd March 2012 at 19:01. |
2nd March 2012, 23:43 | #12420 | Link | |
The crashing happens also if both files have the same fps, like 2 files with 23.970 fps. Thanks for the tip about D3D11, but doesn't seem to have any influence on the crashing for me. Did it completely solve this crashing problem for you ? The other thing mentioned in this thread "flush" for "after copy to backbuff" + flush for "after last rendering step", seems to help, but does not solve the problem. It just happens less likely Last edited by Pat357; 3rd March 2012 at 00:08. Reason: clarification |
